$\newcommand{LogI}{\operatorname{Li}}$ I know that $\LogI_{2}(-1)=-\frac{\pi^2}{12}$, but I have never seen a proof of this result without using a functional identity of the Dilogarithm or a series expansion. I would like to know how calculate $\LogI_{2}(-1)$ using the integral representation of the Dilogarithm function: $\LogI_{2}(z)=\int_{z}^{0}\frac{\ln{(1-t)}}{t}dt$ or $\LogI_{2}(z)=-\int_{0}^{1}\frac{\ln{(1-zt)}}{t}dt$. This amounts to calculating either of the following integrals: $$\LogI_{2}(-1)=\int_{-1}^{0}\frac{\ln{(1-t)}}{t}dt$$ $$\LogI_{2}(-1)=-\int_{0}^{1}\frac{\ln{(1+t)}}{t}dt$$ I am interested in seeing how to evaluate these integrals without using series expansion or functional identities of the Dilogarithm. Methods involving the use of Complex Analysis are welcome with some explanation.
- 74,685
- 436
1Apply the residue theorem to $\lim_{N \to \infty} \int_{|z|=N+1/2}\frac{z^{-2}}{e^{2i \pi z}-1}dz= 0$ – reuns Oct 27 '17 at 23:52
2https://math.stackexchange.com/questions/890872/the-other-ways-to-calculate-int-01-frac-ln1-x2xdx?rq=1 1st answer – DanielC Oct 27 '17 at 23:58
@reuns I like your approach, but my knowledge of complex variables is extremely lacking. I understand that the residue theorem will yield $2i\pi$ times the residue at the pole $z=0$ which is $\frac{i\pi}{6}$, but that value is off by a factor of $\frac{1}{4}$. If you could explain your choice of contour and how it relates to one of the given integral representations I would be very grateful. – Biggs Oct 28 '17 at 01:37
@reuns You have now utterly confused me. Aren't the odd Bernoulli numbers equal to $0$? WA gives this for the residue: https://www.wolframalpha.com/input/?i=residue+of+(z%5E-2)%2F(e%5E(2i(pi)z)-1)+at+z+%3D+0 Am I missing something here? – Biggs Oct 28 '17 at 03:34
The residue at $ z=0$ is $2i \pi \frac{B_2}{2}$ (the Bernouilli number). Note how $\frac{z}{e^z−1}$ appears when integrating by parts followed by $t=e^{-z}$ in your integral representation. – reuns Oct 28 '17 at 03:39
This value can be calculate if you know the value of $\text{Li}2(1)$ see below. Therefore your question is to evaluate $\displaystyle \sum{n=1}^{\infty}\frac{1}{n^2}$ read https://math.stackexchange.com/questions/8337/different-methods-to-compute-sum-limits-k-1-infty-frac1k2 – FDP Oct 28 '17 at 06:46
Enforce the substitution $x\to x^2$. Then,
$$\begin{align} \int_0^1\frac{\log(1-x)}{x}\,dx&=2\int_0^1\frac{\log(1-x^2)}{x}\,dx\\\\ &=2\int_0^1 \frac{\log(1-x)}{x}\,dx+2\int_0^1\frac{\log(1+x)}{x}\,dx\tag1 \end{align}$$
Hence, we see from $(1)$ that
$$\begin{align} -\int_0^1\frac{\log(1+x)}{x}\,dx&=\frac12\int_0^1\frac{\log(1-x)}{x}\,dx\tag2\\\\ &=-\frac12 \int_0^1 \int_0^1 \frac{1}{1-xy}\,dx\,dy\tag3 \end{align}$$
Next, in THIS ANSWER, I evaluated the integral in $(3)$ by using the transformation of coordinates $x=s+t$ and $y=s-t$ and using elementary integral analysis. The result as given in that answer was
$$\int_0^1 \int_0^1 \frac{1}{1-xy}\,dx\,dy=\frac{\pi^2}{6}\tag 4$$
Using $(4)$ in $(3)$ reveals
$$-\int_0^1\frac{\log(1+x)}{x}\,dx=-\frac{\pi^2}{12}$$
as expected! And we are done!
- 39,111
- 179,405
@reuns I presume we know the value of the dilogarithm at $1$. This can be calculated without appealing to series analysis. Rather, one can transform the single integral to a double integral and then making a coordinate transformation in which the double integral can be evaluated (see Tom Apostle's Method). – Mark Viola Oct 28 '17 at 01:15
@reuns I've edited and provided a link to an answer I posted HERE in which I evaluated the double integral $\int_0^1\int_0^1 \frac{1}{1-xy},dx,dy$ by transforming coordinates with $x=s+t$ and $y=s-t$ then applying straightforward elementary integral analysis to carry out the double integral. – Mark Viola Oct 28 '17 at 16:01
