I recently came across this problem of finding the limit of a function in two variables as we approach the origin, defined as follows:
$$\lim_{(x,y)\to (0,0)} \frac{\arcsin(x+2y)}{\arctan(2x+4y)}$$
This was on the mid-term test on our course of Multivariable Calculus. While, all the paths that pass through the origin I have tested, seems to give the limit $\frac{1}{2}$, which seems reasonable through recognizing the fact that the argument of arctan is twice as that of arcsin and the logic of single variable limit: $\lim_{x\to 0} \frac{\arcsin(x)}{\arctan(2x)}$. It is, however, not sufficient to prove that the limit is indeed, $\frac{1}{2}$ since the two-path test is a test for the non-existence of limit and not the existence of one. I have even tried Sandwich Theorem and evaluating the limit by converting to polar coordinates but have reached to no conclusion, of course.
I am wondering if setting (x+2y) as some parameter t followed by tending t to zero would work, but then again that would be the same as testing along the path x=-2y.
I am truly dumbfounded by this problem and after long efforts at solving it, I have no answer. Any kind of hint towards which direction I should be proceeding or a solution would be highly appreciated.
