Just as the title says, I'm asked to prove the following:
For $\alpha\in\mathbb{T}$, where $\mathbb{T}=\{z\in\mathbb{C}:|z|=1\}$, prove that $\alpha^n=\alpha^m=1$, only if $\alpha^d=1$, where $d=\gcd{(m,n)}$.
Here is my attempt at the proof.
If $d=\gcd{(m,n)}$, then we can write $d$, as $d=rm+sn$, for some $r,s\in\mathbb{Z}$. Hence we can write $\alpha^d=\alpha^{rm+sn}=\alpha^{rm}\alpha^{sn}$. Then, using the fact that $|\alpha|=1$, because $\alpha\in\mathbb{T}$, we can let $\alpha=e^{ix}$. Then we have that $\alpha^{rm}\alpha^{sn}=e^{ix(rm+ns)}=e^{irmx}e^{isnx}=1$.
At this point, I'm not sure exactly how to proceed, or even if I am ont the correct track. Any help would be appreciated.
quanticbolt
  • 1,746
  • No need to use the exponential form: just notice that $\alpha^{rm}=(\alpha^m)^r=1^r$, and similarly with $\alpha^{sn}$. – Leo163 Oct 01 '17 at 19:15
This is just a property of cyclic groups, as pointed out in the comments. Then if $m = du, n = dv$ we have $\alpha^{m} = (\alpha^d)^u = 1^u = 1$, and for the other implication, namely if $\alpha^m = \alpha^n = 1$, use Bezout's lemma as you did.
StefanH
  • 18,086
You're close. As Leo said in his comment, you don't need $\alpha = e^{ix}$; just use $d = rm + sn$:
$\alpha^d = \alpha^{rm + sn} = \alpha^{rm} \alpha^{sn} = (\alpha^m)^r (\alpha^n)^s = 1^r \cdot 1^s = 1. \tag 1$
That $\alpha^d = 1 \Longrightarrow \alpha^n = \alpha^m = 1$ is almost self-evident, since $d \mid m$ and $d\mid n$.
Robert Lewis
  • 71,180
  • I understand how to prove this. but what is the intuition for this to be true? can you explain the intuition please – user20194358 Mar 06 '23 at 22:10
