To be more clear, write $N(t)$ instead of $N$, write $\frac{dN(t)}{dt}$ instead of $\frac{dN}{dt}$. Also, it is more ideal to write $N'(t)$ than $\frac{dN(t)}{dt}$ in the answer, since we are talking the annoying Leibniz's mis-leding notation, right?
$\begin{alignedat}{3}\frac{dN(t)}{dt}=-\lambda N(t) &\Longrightarrow \forall t,~N'(t)=-\lambda N(t)&\text{rewrite to a rigorous notation}\\ &\Longrightarrow \forall t,~\frac{1}{N(t)}N'(t)=-\lambda&\text{move the term $N(t)$ to LHS}\end{alignedat}$
I added a quantifier $\forall t$ in front. Since the true thing happens here is that the equation $N'(t)=-\lambda N(t)$ and $\dfrac{1}{N(t)}N'(t)=-\lambda$ not only hold for one particular, but rather all $t\in\mathbb{R}$. (we here ignore the little issue that when $t=0$, the equality might be problematic, since this is another(more little) question, off the topic.)
To repeat, the equation above, are something like: if we first defined $f:\Bbb R\to \Bbb R;x\mapsto x^2+1$, then we can say:
- $\forall x,~f(x)=x^2+1$
- $\forall y,~f(y)=y^2+1$
- $\forall t,~f(t)=t^2+1$
- $\forall t,~f(t)-1=t^2$
- $\forall t,~(f(t))^2=t^4+2t^2+1$
- $\forall t,~\dfrac{f(t)}{f(t)}=1$
- $\forall t,~f'(t)=2t$,
... etc.
Here these all expression all have a quantifer in it, specifying the fact that not only the equation(say $\dfrac{f(t)}{f(t)}=1$) hold for one particular $t$(say $t=1.467$), but also all $t$ in the real numbers.
Why do I stress on this point? Because due to it, we can integrate both side.
$\begin{alignedat}{3} \left(\forall t,~\frac{1}{N(t)}N'(t)=-\lambda\right)\Longrightarrow \int\left(\frac{1}{N(t)}N'(t)\right) dt=\int (-\lambda)dt&\quad\text{integrate both side w.r.t. $t$}\end{alignedat}$.
$(\star)$ It should be notice that, if we are dealing with a equation in precalculus, like $2x^2+x+1=0$. To integrate both side with respect to the variable, getting that $\int (2x^2+x+1) dx = \int 0 dx$, is meaningless, and totally wrong. Here the reason that I can integrate the both side, with respect to $t$, is that we have known that the equation holds for all $t\in\Bbb R$ (or at least on some interval). And since the two expressions are identical (at least on some interval), there is nothing more or less to integrate $\dfrac{1}{N(t)}N'(t)$ than to integrate $-\lambda$. For example, the result of $\int (x^3+2x-5x+7)dx$ is the same of $\int (x^3+2x-5x+7)dx$, of course!
Now keep going.
$\begin{alignedat}{2}
&\int\left(\frac{1}{N(t)}N'(t)\right) dt=\int (-\lambda)dt\\
&\Longrightarrow \underbrace{\ln |N(t)|+c_1}_{\dagger}=-\lambda t+c_2\\
&\Longrightarrow \ln |N(t)|=-\lambda t+c\\
&\Longrightarrow e^{-\lambda t+c}=N(t)\\
&\Longrightarrow N(t)=Ce^{-\lambda t}~~\text{(I forgot the reason why we can throw away abs-sign now :P}\\
\end{alignedat}$
$(\dagger)$ The integration by substitution used in the LHS is very classic, and rigorous; it doesn't require any annoying differential operations, such as canceling the $dt$'s or $dx$'s.
And get the answer. You may wonder why different constant $c_1$ and $c_2$ arises, this is because $\int d(\cdot)$ it not truly some kind of function(same input, same output), in fact, it produce a family of functions, each of these are distinct from a constant, as stressed in the calculus books.
But you are absolutely right, what I have used in step 3 is circular. Any ideas how to proceed instead?
– Mike Aug 12 '17 at 18:17From the rest of your comment, I see how your computation could provide a proof, and the textbook's argument could provide an intuitive approach for how somebody saw it.
– Mike Aug 12 '17 at 18:25
