I need to find the p value for which every n: $n \ge p$ and $n \in \mathbb{N}$
I am given:
$n! \ge 2^n$
I'm really not sure how to approach this question. Say my base proof is $p=4$ so $n \ge 4$ and then I tried:
$(n+1)! \ge 2^n \times 2^1$ (what was originally $2^{n+1}$)
$n! \times (n+1) \gt 2^n \times 2^1$
But this is where I get stuck.. By the way, is there any other way to find $p$ other than just trying numbers?
Thanks!
bm1125
  • 1,427
  • Where does $n!\ge 2^n$ come from? – Shuri2060 Aug 07 '17 at 16:29
  • @Shuri2060 I believe it's the problem statement ("Find $p$ for which, $\forall n \geq p$, $n! \geq 2^n$"). – platty Aug 07 '17 at 16:31
    If $n!\geq2^n$ and $n\geq4$ then $(n+1)!=n!\times(n+1)\geq2^n\times4>2^n\times2^1=2^{n+1}$. – drhab Aug 07 '17 at 16:33
  • See answers to this question about how to write a clear induction proof. Do not fall into the (very bad) habit of starting with what you hope is true and then making simplifications to reach a tautology. Instead, start with what you know is true and use that to prove what you hope is true. – JMoravitz Aug 07 '17 at 16:49
  • @platty is correct. Thanks everyone . I will try to write clear induction next time! – bm1125 Aug 08 '17 at 07:22
If you take $p=4$, then you have $p!=24>16=2^p$, so you only need to prove that for $n\geq 4$, you have $n!\geq 2^n$.
So, you already have step 1 of the induction proof, so let's suppose that you have for $k\geq 4$ that
$$k!\geq2^k.$$
Then
$$(k+1)!=k!(k+1)\geq2^k(k+1)\geq2^k(4+1)\geq2^k2=2^{k+1}.$$
$$p=1, 1!=1 <2^1$$
$$p=2, 2!=2 <2^2$$
$$p=3, 3!=6 <2^3$$
$$p=4, 4!=24>2^4$$
So, for $n\ge 4$ we can prove using induction that $n!\ge 2^n $.
$$(n+1)!=n! (n+1)\ge 2^n (n+1) $$ but $$n\ge 4\implies (n+1)\ge 2$$ thus $$(n+1)!\ge 2^n.2=2^{n+1} $$
Done!.
