I'm going wrong with the calculation of CDF for the ratio $\frac{Y}X$ where $X$ and $Y$ are follow uniform distribution in range (0,1).
Let $ T = \frac{Y}X $
CDF of T is $F_T(t) = P(\frac{Y}X <t)$
To calculate $F_T(t)$ condition on $X$ and then apply Law of total probability
$P(\frac{Y}X <t) = \int P(Y<tx|X=x)P(X=x)dx$ and $P(X=x)=1$ since $X$ and $Y$ are independent
$P(\frac{Y}X <t) = \int P(Y<tx)dx$
Range of $tx$ can be either $0<tx<1$ or $tx>1$
Then calculate $F_T(t)$ for above two cases of $tx$
For $0<tx<1$ integral becomes $P(\frac{Y}X <t) = \int_0^1 P(Y<tx)dx = \int_0^1 txdx = \frac{t}2$
For $tx>1 P(Y<tx)$ becomes 1,so $P(\frac{Y}X <t) = \int_0^1 1dx = \int_0^1 txdx = 1$
I know that the problem is with the limits of integral, this post answers the same question, but doesn't explain how those limits were arrived at.
As you say, $\mathsf P(Y<tx) = \begin{cases} tx &:& 0\leq tx<1\\ 1 &:& tx\geq 1 \\ 0 &:& tx<0\end{cases}$
However, consider when does this happen if you are integrating with respect to $x\in [0;1]$ ?
$\begin{align}F_T(t)~&=~\mathsf P(Y<tX)\\ &=~ \int_0^1 \mathsf P(Y<tx\mid X=x)f_X(x)\operatorname d x \\ &=~ \int_0^1 \mathsf P(Y<tx)\operatorname d x\\ &=~\int_0^1 \min\{1,tx\}\operatorname d x \\ &=~\begin{cases}\int_0^{1/t}tx\operatorname d x+\int_{1/t}^1 1\operatorname d x &:& 0\leq 1/t< 1\\ \int_0^{1}tx\operatorname d x &:& 1\leq 1/t\end{cases} \\ &~~\vdots\end{align}$
Graham Kemp
  • 129,094
