39
Could someone take me through the steps of decomposing $$\frac{2x^2+11x}{x^2+11x+30}$$ into partial fractions?
More generally, how does one use partial fractions to compute integrals $$\int\frac{P(x)}{Q(x)}\,dx$$ of rational functions ($P(x)$ and $Q(x)$ are polynomials) ?
This question is asked in an effort to cut down on duplicates. See Coping with *abstract* duplicate questions.
Also see List of Generalizations of Common Questions.
Aryabhata
  • 82,206
Finzz
  • 1,069
What you are trying to do is a partial fraction decomposition.
Idea. Imagine your calculator is broken and a bunch of hoodlums stop you on the street, and demand at knifepoint that you compute $\frac{191}{105}$ as a decimal (part of their initiation into the Mathies Gang, you see), or else they will slit your throat. Unfortunately, since your calculator is broken, you can really only do divisions if the divisor is a single digit number (so you can use your fingers to do the operations; you're very good with those, because you know the multiplication tables of single digit numbers...). Luckily, you do notice that $105 = 3\times 5 \times 7$. Is there some way you can save your neck using this observation?
Well, you do know that $191 = 105 + 86$, so at least you know that $\frac{191}{105} = 1 + \frac{86}{105}$, so that takes care of the integer part of the fraction. What about $\frac{86}{105}$? Aha! Here's a clever idea: maybe $\frac{86}{105}$ is really the result of a sum of fractions! If you had a sum of fractions of the form $$\frac{A}{3} + \frac{B}{5} + \frac{C}{7}$$ then to write it as a single fraction you would find the common denominator, $105$, and then do a bunch of operations, and end up with a fraction $\frac{\mathrm{something}}{105}$. If you can find an $A$, $B$, and $C$ so that the something is $86$, then instead of computing $\frac{86}{105}$ you can do $\frac{A}{3}$, $\frac{B}{5}$, and $\frac{C}{7}$ (which you can do, since the denominators are single digit numbers), and then add those decimals to get the answer. Can we? We do a bit of algebra: $$\frac{A}{3} + \frac{B}{5} + \frac{C}{7} = \frac{35A + 21B + 15C}{105}$$ so you want $35A + 21B + 15C = 86$. As luck would have it, $A=B=1$ and $C=2$ works, so $$\frac{86}{105} = \frac{1}{3} + \frac{1}{5} + \frac{2}{7}.$$ And now, all is well: \begin{align*} \frac{191}{105} &= 1 + \frac{86}{105}\\\ &= 1 + \frac{1}{3} + \frac{1}{5} + \frac{2}{7}\\\ &= 1 + (0.3333\ldots) + (0.2) + (0.285714285714\overline{285714}\ldots) \end{align*} and you can give those dangerous hoodlums their answer, and live to derive another day.
**Your problem.** You want to do something similar with the polynomial quotient, with denominators that "easy"; in this case, degree $1$. The first task is to make the fraction "less than $1$", by making sure the denominator has degree greater than the numerator. You do this with polynomial long division (see also this recent answer). Doing the long division mentally, we have: to get $2x^2$ from $x^2+11x+30$ we multiply by $2$: $$2x^2 + 11x = (x^2+11x+30)(2+\cdots)$$ that produces unwanted $11x + 60$, (well, you get $22x + 60$, but you *do* want $11x$ of those, so you only have a leftover of $11x+60$); nothing to do about them, except cancel them out after the product is done. So you have $$2x^2 + 11x = (x^2+11x+30)(2) - (11x+60).$$ So you can write $$\frac{2x^2+11x}{x^2+11x+30} = 2 + \frac{-(11x+60)}{x^2+11x+30}.$$ Now we got the "integer part", and we work on the "fraction part". The denominator factors as $(x+5)(x+6)$, so we want to think of that fraction as the end result of doing a sum of the form $$\frac{A}{x+5} + \frac{B}{x+6}.$$ Because the sum is "smaller than $1$" (numerator of degree smaller than the denominator) each of these fractions should also be "smaller than one". So both the $A$ and $B$ will be constants.
So we have: \begin{align*} \frac{-11x - 60}{x^2+11x+30} &= \frac{A}{x+5} + \frac{B}{x+6} \\\ &= \frac{A(x+6)}{(x+5)(x+6)} + \frac{B(x+5)}{(x+6)(x+5)}\\\ &= \frac{A(x+6) + B(x+5)}{(x+5)(x+6)}\\\ &= \frac{Ax + 6A + Bx + 5B}{x^2+11x+30} = \frac{(A+B)x + (6A+5B)}{x^2+11x+30}. \end{align*} For this to work out, you need $(A+B)x + (6A+5B) = -11x-60$. That means we need $A+B=-11$ (so the $x$s agree) and $6A+5B = -60$ (so the constant terms agree).
That means $A=-11-B$ (from the first equation). Plugging into the second equation, we get $$-60 = 6A+5B = 6(-11-B)+5B = -66 -6B + 5B = -66-B.$$ So that means that $B=60-66 = -6$. And since $A+B=-11$, then $A=-5$.
(An alternative method for finding the values of $A$ and $B$ is the Heaviside cover-up method; from the fact that $$-11x - 60 = A(x+6)+B(x+5)$$ we know that the two sides must take the same value for every value of $x$; if we plug in $x=-6$, this will "cover up" the $A$ on the right and we simply get $B(-6+5) = -B$; this must equal $-11(-6)-60 = 6$; so $6 = -B$, hence $B=-6$. Then plugging in $x=-5$ "covers up" the $B$ to give us $-11(-5)-60 = A(-5+6)$, or $-5=A$. So we obtain $A=-5$, $B=-6$, same as before.)
That is, $$\frac{-11x-60}{x^2+11x+30} = \frac{-5}{x+5} + \frac{-6}{x+6}.$$
Putting it all together, we have: $$\frac{2x^2+11x}{x^2+11x+30} = 2 + \frac{-11x-60}{x^2+11x+30} = 2 - \frac{5}{x+5} - \frac{6}{x+6}.$$ And <triumphant trumpet cue>ta da!</triumphant trumpet cue> Your task is done. You've decomposed the quotient into partial fractions.
Caveat. You need to be careful if the denominator has repeated factors, or has factors that are of degree $2$ and cannot be further factored (e.g., $x^2+1$); I talk about that below in the general discussion.
Now, let's hope the Mathies Gang doesn't ask for a proof of Goldbach's Conjecture from its next batch of pledges...
General Idea.
So let's discuss this idea for the general problem of integrating a rational function; that is, a function of the form $$\frac{P(x)}{Q(x)}$$ where $P(x)=a_nx^n+\cdots +a_1x+a_0$ and $Q(x)=b_mx^m+\cdots + b_1x+b_0$ are polynomials.
Integrating polynomials is easy, so the first task is to do long division in order to write the fraction as a polynomial plus a rational function in which the numerator has degree smaller than the denominator. So we will consider only the case where $n\lt m$ going forward.
First, let us make sure we can actually do those fractions with "easy denominators." To me, "easy denominator" means (i) linear, $ax+b$; (ii) power of a linear polynomial, $(ax+b)^n$; (iii) irreducible quadratic; (iv) power of an irreducible quadratic. So let's talk about how to integrate those:
  1. When $Q(x)$ has degree $1$ and $P(x)$ is constant. For example, something like $$\int \frac{3}{2x-5}\,dx.$$ These integrals are very easy to do: we do a change of variable $u=2x-5$, so $du=2dx$. We simply get $$\int\frac{3}{2x-5}\,dx = 3\int\frac{dx}{2x-5} = 3\int\frac{\frac{1}{2}du}{u} = \frac{3}{2}\ln|u|+C = \frac{3}{2}\ln|2x-5|+C.$$
  2. In fact, the idea above works whenever the denominator is a power of a degree $1$ polynomial and the numerator is a constant. If we had something like $$\int\frac{3}{(2x-5)^6}\,dx$$ then we can let $u=2x-5$, $du=2dx$ and we get $$\begin{align*} \int\frac{3}{(2x-5)^6}\,dx &= 3\int\frac{\frac{1}{2}du}{u^6} = \frac{3}{2}\int u^{-6}\,dx \\&= \frac{3}{2}\left(\frac{1}{-5}u^{-5}\right)+C\\ &= -\frac{3}{10}(2x-5)^{-5} + C.\end{align*}$$
  3. What if the denominator is an irreducible quadratic? Things get a little more complicated. The simplest example of an irreducible quadratic is $x^2+1$, and the easiest numerator is $1$. That integral can be done directly: $$\int\frac{1}{x^2+1}\,dx = \arctan(x)+C.$$ If we have an irreducible quadratic of the form $x^2+a$, with $a\gt 0$, then we can always write it as $x^2+b^2$ with $b=\sqrt{a}$; then we can do the following: factor out $b^2$ from the denominator, $$\int\frac{dx}{x^2+b^2} = \int\frac{dx}{b^2((\frac{x}{b})^2 + 1)};$$ and now setting $u=\frac{x}{b}$, so $du = \frac{1}{b}\,dx$, we get: $$\int\frac{dx}{x^2+b^2} = \frac{1}{b}\int\frac{1}{(\frac{x}{b})^2+1}\left(\frac{1}{b}\right)\,dx = \frac{1}{b}\int\frac{1}{u^2+1}\,du,$$ and now we can do the integral easily as before. What if we have a more general irreducible quadratic denominator? Something like $x^2+x+1$, or something else with an $x$ term?
The magic phrase here is *Completing the square". We can write $x^2+x+1$ as $$x^2 + x + 1 = \left(x^2 + x + \frac{1}{4}\right) + \frac{3}{4} = \left(x+\frac{1}{2}\right)^2 + \frac{3}{4}.$$ Then setting $w=x+\frac{1}{2}$, we end up with an integral that looks just like the previous case! For instance, $$\int\frac{dx}{x^2+x+1} = \int\frac{dx}{(x+\frac{1}{2})^2+\frac{3}{4}} = \int\frac{dw}{w^2+\frac{3}{4}},$$ and we know how to deal with these.
So: if the denominator is an irreducible quadratic, and the numerator is a constant, we can do the integral.
  1. What if the denominator is an irreducible quadratic, but the numerator is not constant? Since we can always do the long division, then we can take the numerator to be of degree $1$. If we are lucky, it's possible we can do it with a simple substitution; for example, to do $$\int\frac{2x+3}{x^2+3x+4}\,dx$$ (note the denominator is irreducible quadratic), we can just let $u=x^2+3x+4$, since $du = (2x+3)\,dx$, exactly what we have in the numerator, so $$\int\frac{2x+3}{x^2+3x+4}\,dx = \int\frac{du}{u} = \ln|u|+C = \ln|x^2+3x+4|+C = \ln(x^2+3x+4) + C.$$ If we are not lucky? Well, we can always make our own luck. For instace, if we had $$\int\frac{3x}{x^2+3x+4}\,dx$$ then we can't just make the substitution $u=x^2+3x+4$; but if we wanted to do that anyway, we would need $2x+3$ in the numerator; so we play a little algebra game: $$\begin{align*} \frac{3x}{x^2+3x+4} &= 3\left(\frac{x}{x^2+3x+4}\right)\\ &= 3\left(\frac{\frac{1}{2}(2x)}{x^2+3x+4}\right)\\ &=\frac{3}{2}\left(\frac{2x}{x^2+3x+4}\right) &\text{(still not quite right)}\\ &= \frac{3}{2}\left(\frac{2x+3-3}{x^2+3x+4}\right)\\ &= \frac{3}{2}\left(\frac{2x+3}{x^2+3x+4} - \frac{3}{x^2+3x+4}\right). \end{align*}$$ What have we accomplished? The first summand, $\frac{2x+3}{x^2+3x+4}$, is an integral we can do with a simple substitution; and the second summand, $\frac{3}{x^2+3x+4}$, is an integral that we just saw how to do! So in this way, we can solve this kind of integral. We can always rewrite the integral as a sum of an integral that we can do with a substitution, and an integral that is as in case 3 above.
  2. What if the denominator is a power of an irreducible quadratic? Something like $(x^2+3x+5)^4$? If the numerator is of degree at most $1$, then we can play the same game as we just did to end up with a sum of two fractions; the first one will have numerator which is exactly the derivative of $x^2+3x+5$, and the second will have a numerator that is constant. So we just need to figure out how to do an integral like $$\int\frac{2dx}{(x^2+3x+5)^5}$$ with constant numerator and a power of an irreducible quadratic in the denominator.
By completing the square as we did in 3, we can rewrite it so that it looks like $$\int\frac{dw}{(w^2+b^2)^5}.$$ Turns out that if you do integration by parts, then you get a Reduction formula that says: $$\int\frac{dw}{(w^2+b^2)^n} = \frac{1}{2b^2(n-1)}\left(\frac{w}{(w^2+b^2)^{n-1}} + (2n-3)\int\frac{dw}{(w^2+b^2)^{n-1}}\right)$$ By using this formula repeatedly, we will eventually end up in an integral where the denominator is just $w^2+b^2$... and we already know how to do those. So all is well with the world (with a lot of work, at least).
Okay. Do we now need to go and discuss what to do when the denominator is a cubic polynomial, then a fourth degree polynomial, then a fifth degree polynomial, etc.?
No! We can play the same game we did with fractions above, and take an arbitrary rational function and rewrite it as a sum of fractions, with each fraction a power of a degree 1 or an irreducible quadratic polynomial. The key to this is the Fundamental Theorem of Algebra, which says that every polynomial with real coefficients can be written as a product of linear and irreducible quadratic polynomials. In fact, one of the major reasons why people wanted to prove the Fundamental Theorem of Algebra was to make sure that we could do integrals of rational functions in the manner we are discussing.
So here is a method for integrating a rational function:
To compute $$\int\frac{P(x)}{Q(x)}\,dx$$ where $P(x)$ and $Q(x)$ are polynomials:
  1. If $\deg(P)$ is equal to or greater than $\deg(Q)$, perform long division and rewrite the fraction as a polynomial plus a proper fraction (with numerator of degree strictly smaller than the denominator). Integrate the polynomial (easy).
  2. Completely factor the denominator $Q(x)$ into linear terms and irreducible quadratics. This can be very hard to do in practice. In fact, this step is the only obstacle to really being able to do these integrals always, easily. Factoring a polynomial completely and exactly can be very hard. The Fundamental Theorem of Algebra says that there is a way of writing $Q(x)$ that way, but it doesn't tell us how to find it.
  3. Rewrite the fraction as a sum of fractions, each of which has a denominator which is either a power of linear polynomial or of an irreducible quadratic. (More about this below.)
  4. Do the integral of each of the fractions as discussed above.
How do we rewrite as a sum?
Write $Q(x)$ as a product of powers of distinct polynomials, each linear or irreducible quadratic; e.g., $Q(x) = x(2x-1)(x+2)^3(x^2+1)(x^2+2)^2$.
For each power $(ax+b)^n$, use $n$ fractions of the form: $$\frac{A_1}{ax+b} + \frac{A_2}{(ax+b)^2} + \cdots+\frac{A_n}{(ax+b)^n},$$ where $A_1,\ldots,A_n$ are constants-to-be-determined-later.
For each power of an irreducible quadratic, $(ax^2+bx+c)^m$, use $m$ fractions of the form: $$\frac{C_1x+D_1}{ax^2+bx+c} + \frac{C_2x+D_2}{(ax^2+bx+c)^2} + \cdots + \frac{C_mx+D_m}{(ax^2+bx+c)^m},$$ where $C_1,D_1,\ldots,C_m,D_m$ are constants-to-be-determined-later.
So in the example above, we $Q(x) = x(2x-1)(x+2)^3(x^2+1)(x^2+2)^2$, we would get: $$\begin{align*} &\quad+\frac{A}{x} &\text{(corresponding to the factor }x\text{)}\\ &\quad+\frac{B}{2x+1} &\text{(corresponding to the factor }2x-1\text{)}\\ &\quad+\frac{C}{x+2} + \frac{D}{(x+2)^2}+\frac{E}{(x+2)^3} &\text{(corresponding to the factor }(x+2)^3\text{)}\\ &\quad+\frac{Gx+H}{x^2+1} &\text{(corresponding to the factor }x^2+1\text{)}\\ &\quad+\frac{Jx+K}{x^2+2} + \frac{Lx+M}{(x^2+2)^2}&\text{(corresponding to the factor }(x^2+2)^2\text{)} \end{align*}$$
And now, the final step: how do we figure out what all those constants-to-be-determined-later are? We do the operation and compare it to the original! Let's say we are trying to calculate $$\int\frac{3x-2}{x(x+2)^2(x^2+1)}\,dx$$ (not the same as above, but I want to do something small enough that we can do it).
We set it up as above; then we do the algebra. We have: $$\begin{align*} \frac{3x-2}{x(x+2)^2(x^2+1)} &= \frac{A}{x} + \frac{B}{x+2} + \frac{C}{(x+2)^2} + \frac{Dx+E}{x^2+1}\\ &= \frac{\small A(x+2)^2(x^2+1) + Bx(x+2)(x^2+1) + Cx(x^2+1) + (Dx+E)x(x+2)^2}{x(x+2)^2(x^2+1)}. \end{align*}$$ Now we have two options: we can do the algebra in the numerator and write it as a polynomial. Then it has to be identical to $3x-2$. For example, the coefficient of $x^4$ in the numerator would be $A+B+D$, so we would need $A+B+D=0$; the constant term would be $4A$, so $4A=-2$; and so on.
The other method is the Heaviside cover-up method. Since the two expressions have to be the same, the numerator has to be the same as $3x-2$ when evaluated at every value of $x$. If we pick $x=0$ and plug it into the left numerator, we get $-2$; if we plug it into the right hand side, we get $A(2)^2(1) = 4A$, so $4A=-2$, which tells us what $A$ is. If we plug in $x=-2$, th left h and side is $3(-2)-2 = -8$, the right hand side is $C(-2)((-2)^2+1) = -10C$, so $-10C = -8$, which tells us what $C$ is; we can then simplify and continue doing this (you'll note I selected points where a lot of the summands on the right simply evaluate to $0$) until we get the value of all the coefficients.
And once we've found all the coefficients, we just break up the integral into a sum of integrals, each of which we already know how to do. And so, after a fair amount of work (but mainly just busy-work), we are done.
Arturo Magidin
  • 398,050
    I logged in specifically to upvote this. – Harry Stern Feb 09 '11 at 03:55
    This is fantastic. I will point my calc students to this in the future! – Patch Mar 07 '12 at 08:42
  • @Arturo Well it didn't take long before I could no longer follow what was happening, when introducing partial fractions you state that A = B = 1 and C = 2. Why? I can't see why this is true or how you came to that conclusion. –  Jun 04 '12 at 19:56
  • @Jordan: Because they work. Plug them in, see that they work. How do you find them? You solve a system of linear equations. – Arturo Magidin Jun 04 '12 at 19:58
  • I don't think I know how to do systems of linear equations. –  Jun 04 '12 at 20:00
    @Jordan: Solving $35A + 21B + 15C = 86$ with positive integers is not terribly difficult, even by trial and error ($A$ cannot be more than $2$, $B$ cannot be more than $4$, $C$ cannot be more than $5$). But in any case, it's not the important point here. And this is not the place to teach you to solve systems of linear equations (neither is Calculus II, for that matter). The point of that particular example was not to actually solve the equation, but to understand the ideas behind partial fraction decompositions. – Arturo Magidin Jun 04 '12 at 20:04
  • @ArturoMagidin Why can't A be more than 2? I do not understand that. –  Jun 04 '12 at 20:09
  • @Jordan: If we are restricting to positive integers (as we would if we were working with fractions as in that particular portion of the narrative, which is not the important part of the post, it's just a part where I try to explain, in what I hope is an amusing fashion, the idea behind partial fraction decomposition: breaking up a complicated "fraction" into a sum of simpler ones), then you cannot have $A$ bigger than $2$, because $35\times 3 = 105$ is already bigger than $86$, but you are trying to get $35A+21B+15C=86$ with none of $A$, $B$, and $C$ negative. – Arturo Magidin Jun 04 '12 at 20:16
  • This is incredible. Really, truly beautiful. I am going to share this with the world. – Ziggy Jul 16 '12 at 19:07
  • Could you do one of these for The Frobenius Method (my constant foe...). – Ziggy Jul 16 '12 at 19:20
  • @Arturo Magidin would explain more about fundamental theorem of algebrs . for example how can i factor $x^4+1$ to product of linear and irreducible quadratic polynomials unless i use complex numbers . – KFkf Oct 08 '15 at 20:42
  • @ArturoMagidin How can someone do all these calculations in such a bad condition :) – User Jun 07 '20 at 15:22
  • Are you sure there should be "making sure the denominator has degree less than the numerator" not the other way around? – Karina Oct 13 '20 at 18:47
  • @SAT: You are correct; the other way around. – Arturo Magidin Oct 13 '20 at 20:10
  • This post is genuinely great. May I ask one more question: my professor said that proving that we can’t apply partial fractions to improper fractions (as it’s given before), the reason why: it’s because if we take the limit x to infinity, it will go to infinity. However, I don’t see a straightforward link between not being able to find A,B,C and that x goes to infinity. Could you elaborate on that? – Karina Oct 14 '20 at 18:22
  • @SAT: Each fraction in the partial fraction decomposition has a denominator with degree strictly greater than the numerator, so the limit as $x\to\infty$ is zero. A sum of things that go to $0$ cannot be equal to something that goes to infinity. That’s why you must first do the devision to get the quotient, and deal with only the remainder divided by the divisor. – Arturo Magidin Oct 14 '20 at 18:53
  • Bit why is it such a strict requirement? What would happen if the x approaching infinity would be infinity? – Karina Oct 14 '20 at 20:18
  • @SAT: Who is requiring anything? A partial fraction decomposition is a decomposition into fractions where the denominators are powers of irreducibles, and the irreducibles have degree smaller than the denominator. They are done that way because those are the rational functions that we can integrate easily. The limit issue is not that "something happens", it shows that you cannot accomplish such a decomposition if your original function has numerator with degree greater than its denominator. Because then that functions is not equal to a partial fraction decomposition. – Arturo Magidin Oct 14 '20 at 20:28
  • @SAT: so, simply, you can't go looking for something that doesn't exist, so you should not be trying a partial fraction decomposition for a function that cannot possibly have one. That's not a "requirement", that's just common sense. – Arturo Magidin Oct 14 '20 at 20:29
  • So basically you are saying that by definition it simply can’t happen. Am I right? – Karina Oct 14 '20 at 20:52
  • @SAT: Definition of what? Of a partial fraction decomposition? Yes. You cannot have a partial fraction decomposition of a rational function $\frac{P(x)}{Q(x)}$ if $\deg(P)>\deg(Q)$. – Arturo Magidin Oct 14 '20 at 20:58
  • @ArturoMagidin What if the degrees were to be much different, e. g. $\deg(P) = 8 < \deg(Q) = 13$? Which besides, all coefficients in the polynomials are different from zero. On the forum, I had given an engineering-like answer. Moreover, some integrals may not have close form. However, my integral where the numerator is quadratic polynomial and the denominator is of 4 degree. As you say, the main thing is that denominator must allow factorization, otherwise we must integrate numerically or in the complex plain, or apply other trick, depending on which polynomials in the fraction are present. – sergei ivanov Jan 17 '21 at 23:29
  • @sergeiivanov: It doesn’t matter if the degrees are “much different”. All you need is for the degree of the numerator to be less than that of the denominator. And all the resulting integrals have closed form, as the post itself states. So... what exactly are you claiming or saying? The only bottleneck is factoring the denominator into irreducibles. Finally: the denominator definitely admits a factorization (it always exists); the only question is whether you can actually find it. – Arturo Magidin Jan 17 '21 at 23:44
  • @ArturoMagidin I am not going to waster your time, because I just forgot about the is A to Q, so no other information should be present. For this purpose, MSE introduced Chat. Anyway, take as an example $$\int \frac{x^3+x+1}{x^5 - 3x^4 + 7x^3 + x^2 - 5x + 1}dx$$. The denominator may have both real and complex roots. So, you are right factorisation is allowed. Then, yes such a rational function can be integrated – sergei ivanov Jan 18 '21 at 07:56
  • You are brilliant. I have to bookmark this page. – Rita Geraghty Jan 25 '21 at 08:07
I can't really TeX out polynomial long division in the normal sense, but essentially you want to solve $$ 2x^2+11x=g(x)\cdot (x^2+11x+30)+r(x) $$ by finding polynomials $g(x)$ and $r(x)$ such that $\deg(r)=0$ or $\deg(r)<\deg(x^2+11x+30)$.
You want to get the leading terms to match on both sides, right? So the leading term of $g(x)$ should be $2$.
This is the constant term of the polynomial, so you've reached the end of the line in a sense. So $$ 2x^2+11x=2\cdot (x^2+11x+30)+r(x) $$ which implies $$ r(x)=2x^2+11x-2\cdot (x^2+11x+30)=-11x-60. $$ It follows that $$ \frac{2x^2+11x}{x^2+11x+30}=2+\frac{-11x-60}{x^2+11x+30}. $$ You can check that $$ \frac{-11x-60}{x^2+11x+30}=-\frac{6}{x+6}-\frac{5}{x+5}. $$ To actually get the remainder in that desired form, you could use the method of partial fractions to split the your remainder with quadratic denominator into a sum of terms with linear denominators. I can expand more on that if you're not familiar with it. It also may be quite helpful to follow the nice example given on wikipedia.
yunone
  • 22,333
  • Where does the -11x -60 come from when you begin solving for r(x)? – Finzz Feb 08 '11 at 09:39
    @Finzz, do you understand how I reached the line above it? I just subtracted $2\cdot (x^2+11x+30)$ from each side and then simplified. – yunone Feb 08 '11 at 09:43
  • Alright, I was looking at it wrong and I got confused because you went from having 2 equal signs to 3, but you were just simplifying lol. – Finzz Feb 08 '11 at 23:26
Here are some formal aspects of the delightful answer ( by Arturo Magidin ) above.
Let $ f(x), g(x) $ be polynomials ( $ g \neq 0 $ ). Our goal now is to integrate $ \frac{f}{g} $.
Dividing $ f $ by $ g $ gives that $ f = qg + r $ with $ \deg(r) < \deg(g) $, so $ \frac{f}{g} $ is a polynomial $ q $ plus a proper fraction $ \frac{r}{g} $ [ We'll call a fraction $ \frac{p}{q} $ of polynomials "proper" if $ \deg{p} < \deg{q} $ ]. Since the $ q, r $ here are unique, we'll call $ q $ the "polynomial part" and $ \frac{r}{g} $ the "proper fraction part" of $ \frac{f}{g} $.
Now we need only figure out how to integrate proper fractions, so let's take $ \deg(f) < \deg(g) $ to begin with.
$ g $ can be broken into a product consisting of linear factors, and quadratic factors with negative discriminant [ Proved here, for instance ]. Also, any proper fraction $ \displaystyle \frac{f}{g_1 \ldots g_k} $ where $ g_i $s are mutually coprime can be written as a sum of proper fractions with denominators $ g_1, \ldots, g_k $ [ Let's show it for $ k = 2 $, the general case follows by induction. Since $ g_1, g_2 $ are coprime, by Euclidean algorithm $ g_1 u_1 + g_2 u_2 = 1 $ for some polynomials $ u_1, u_2 $. Now $ \displaystyle \frac{f u_1}{g_2} + \frac{f u_2}{g_1} = \frac{f}{g_1 g_2} $, and since right hand side is proper the polynomial parts of $ \displaystyle \frac{f u_1}{g_2}, \frac{f u_2}{g_1} $ sum up to $ 0 $. So ( proper fraction part of $ f u_1 / g_2 $ ) + ( proper fraction part of $ f u_2 / g_1 $ ) = $ f / g_1 g_2 $ , done. ]
So $ \displaystyle \frac{f}{g} $ breaks into a sum of proper fractions of the form $ \displaystyle \frac{s(x)}{t(x) ^l} $ and $ \displaystyle \frac{p(x)}{h(x) ^k} $, where the $ t(x) $s are linear polynomials and $ h(x) $s are negative discriminant quadratics .
The terms here can be broken down further. Any proper fraction of the form $ \displaystyle \frac{f}{g^k} $ is a sum of proper fractions, with denominators $ g, \ldots, g^k $ and numerators having lower degree than $ g $ ( The $ f, g $ here are separate from the original problem. Notation repeated to try keep things more readable ). This is because : Division gives $ f = qg + r $ with $ \deg(r) < \deg(g) $, so $ \displaystyle \frac{f}{g^k} = \frac{q}{g^{k-1}} + \frac{r}{g^k} $. All the terms here are proper and $ \deg(r) < \deg(g) $. Now continuing onto $ \displaystyle \frac{q}{g^{k-1}} $, we're done.
So our original proper fraction $ \displaystyle \frac{f}{g} $ is a sum of proper fractions, of the form $ \displaystyle \frac{m}{(x+p)^l} $, and of the form $ \displaystyle \frac{ax+b}{(x^2 + cx + d)^k} $ where $ x^2 + cx + d $ has negative discriminant.
Proper fractions of the form $ \displaystyle \frac{m}{(x+p)^l} $ are easily integrated, for instance by substituting $ u = x + p $.
So finally, the problem is reduced to integrating fractions of the form $ \displaystyle \frac{ax+b}{(x^2 + cx + d)^k} $ where $ x^2 + cx + d $ has negative discriminant. Writing $ x^2 + cx + d $ as $ \displaystyle (x + \frac{c}{2})^2 + (d - \frac{c^2}{4}) $ and substituting $ u = x + \frac{c}{2} $ makes the integral take the form $ \displaystyle \int \frac{Au + B}{(u^2 + C^2)^k} du $. We can integrate the $ \displaystyle \frac{Au}{(u^2 + C^2)^k} $ part by substituting $ v = u^2 + C^2 $. And the $ \displaystyle \frac{B}{(u^2 + C^2)^k} $ part, as mentioned in the above answer, can be handled using integration by parts.
    Your claim that $\frac{f}{g}$ breaks into fractions of the form $\frac{A}{(x-a)}$ and $\frac{p(x)}{h^k}$ is incorrect. For example there is no such decomposition for $\frac{1}{x^3(x-1)^3}$. – Arturo Magidin Jan 18 '21 at 13:40
  • Yes ! It should've been "$ \frac{f}{g} $ is sum of proper fractions of form $ \frac{a(x)}{b(x)^l} $ and $ \frac{p(x)}{h(x)^k} $, where $ b $s are linear polynomials and $ h $s are negative discriminant quadratics". Thanks a lot for pointing it out, I'll try to edit the answer accordingly. – Venkata Karthik Bandaru Jan 18 '21 at 23:33
$\color{brown}{\textbf{Preliminary notes.}}$
Partial fractions is a way to present rational expression as the sum of the more simple terms, which allow to use the standard integration technics.
For example, expression $$\dfrac2{x+2}+\dfrac1{x+3}$$ is more suitable for the integration, than the equivalent rational expression in the form of $$\dfrac{3x+5}{x^2+5x+6}.$$
Obvious preliminary steps are:
  • separation of the ceil polynomial part;
  • factorization of the denominator.
The given example allows the simple separation in the form of $$f_1(x) = \dfrac{2x^2+11x}{x^2+11x+30}=2+\dfrac{2x^2+11x-2(x^2+11x+30)}{x^2+11x+30},$$ $$f_1(x) = 2-\dfrac{11x+60}{x^2+11x+30}.$$ In the common case, technic of the polynomial dividing can be used.
After the preliminary steps, we have: $$f_1(x) = 2-\dfrac{11x+60}{(x+5)(x+6)}.\tag1$$
$\color{brown}{\textbf{Partial fractions technic.}}$
Using the presentation in the form of $$f_2(x)=\dfrac{11x+60}{(x+5)(x+6)}=\dfrac A{x+5}+\dfrac B{x+6},\tag2$$ easily to get: $$A=\lim\limits_{x\to-5}\,(x+5)f_2(x)=\lim\limits_{x\to-5}\,\dfrac{11x+60}{x+6} = 5,$$ $$B=\lim\limits_{x\to-6}\,(x+6)f_2(x)=\lim\limits_{x\to-6}\,\dfrac{11x+60}{x+5} = 6,$$ and from $(1),(2)$ should $$f_1(x)=2-\dfrac5{x+5}-\dfrac6{x+6}.$$
In the more hard case $$g(x)=\dfrac{(3x+4)(2x^2+3x+3)}{(x+1)(x+2)(x^2+1)}=\dfrac A{x+1}+\dfrac B{x+2}+ \dfrac{Cx+D}{x^2+1}$$ one can get $$A=\lim\limits_{x\to-1}(x+1)g(x) = \lim\limits_{x to-1}\dfrac{(3x+4)(2x^2+3x+3)}{(x+2)(x^2+1)} = 1;$$ $$B=\lim\limits_{x\to-2}(x+2)g(x) = \lim\limits_{x to-2}\dfrac{(3x+4)(2x^2+3x+3)}{(x+1) (x^2+1)} = 2;$$
$$A+B+C=\lim\limits_{x\to\infty}x\,g(x) = 6,\quad C=3;$$ $$A+\dfrac12B+D=\lim\limits_{x\to0}g(x) = 6,\quad D=4.$$ Therefore, $$g(x)=\dfrac{(3x+4)(2x^2+3x+3)}{(x+1)(x+2)(x^2+1)}=\dfrac1{x+1}+\dfrac2{x+2}+ \dfrac{3x+4}{x^2+1}$$ Considered technic allows to simplify calculation of the unknown coefficients.
See also Example1.
Non-standard using of the partial fractions see in Example2.
Non-standard generalization of partial fraction technic is presented in Example3.
$\color{brown}{\textbf{Partial fractions for the antiderivative.}}$
If $$h(x)=\dfrac{P(x)}{(x^2+a^2)^n},$$ where the order of $\;P(x)\;$ is less then $\;2n,\;$ then can be applied the integral representation in the form of
$$\int h(x)\,\text dx = \sum\limits_{k=1}^{n-1}\dfrac{A_k x+B_k}{(x^2+a^2)^k}+C\ln(x^2+a^2)+D\arctan\dfrac xa+\text{constant}.\tag3$$ Differentiation of $(3)$ leads to the identity with unknown coefficients in the form of $$h(x) = \sum\limits_{k=1}^{n-1}\dfrac{A_k(x^2+a^2)-2kx(A_k x+B_k)}{(x^2+a^2)^{k+1}} + \dfrac{2Cx+D}{x^2+a^2}.\tag4$$ Eliminating the denominators, we should get the identity for the polynomials. And this allows to get the coefficiens $\;A_k,B_k,C,D.\;$
In particular, this possibility allows to use the presentation $$I(x)=\int\dfrac{(2x+1)(2x^4+17x^2+31)}{(x^2-1)(x^2+4)^2}$$ $$ = A\ln|x-1|+B\ln|x+1|+\dfrac{Cx+D}{x^2+4}+E \ln(x^2+4)+ F\arctan\dfrac x2,$$
$$\dfrac{(2x+1)(2x^4+17x^2+31)}{(x^2-1)(x^2+4)^2} = \dfrac A{x-1}+\dfrac B{x+1}+\dfrac{C+2Ex+2F}{x^2+4}- \dfrac{2Cx^2+2Dx}{(x^2+4)^2},$$ $$A=\lim\limits_{x\to1}\dfrac{(2x+1)(2x^4+17x^2+31)}{(x+1)(x^2+4)^2} = 3,$$ $$B=\lim\limits_{x\to-1}\dfrac{(2x+1)(2x^4+17x^2+31)}{(x-1)(x^2+4)^2} = 1,$$ $$A+B+E=\lim\limits_{x\to\infty}\dfrac{x(2x+1)(2x^4+17x^2+31)}{(x^2-1)(x^2+4)^2} = 4,\quad E=0;$$ $$\dfrac A{x-1}+\dfrac B{x+1} = \dfrac{4x+2}{x^2-1}$$ $$\dfrac{2x+1}{(x^2+4)^2} = \dfrac{C+2F}{x^2+4}-\dfrac{2Cx^2+2Dx}{(x^2+4)^2},$$ $$2x+1 = (2F-C)x^2 -2 Dx + 4(C+2F),$$ $$C=\dfrac18,\quad D=-1,\quad F=\dfrac1{16}.$$
Therefore, $$I = 3\ln|x-1|+\ln|x+1|+\dfrac{\frac18 x-1}{x^2+4} +\dfrac1{16}\arctan\dfrac x2,$$ Differentiation confirms obtained result.
