I just want to know the difference between this two symbols and what are the semantic meaning ?? And what is the difference betwwen this two formulas ????
A → B ⊢ ¬B → ¬A
A → B ⊨ ¬B → ¬A
Lilo
  • 143
In very general terms, without getting into the specifics of models, languages, the difference is one of syntax vs. semantics:
[Syntax] $P \vdash Q$ means that there is a proof (in whatever formal system you are using) of $Q$ assuming $P.$
[Semantics] $P \models Q$ means that in every situation where $P$ is true, $Q$ also is true; typically this means that, in terms of models, every model of $P$ is also a model of $Q.$
If your formal system is consistent and logically sound, then $P \vdash Q$ implies $P \models Q$ (since if you've proven something, it must be right).
On the other hand, it's conceivable for $P \models Q$ to be true but for there to be no proof of this fact in your formal system, so that $P \not\vdash Q.$ Intuitively, this can happen if your formal system isn't strong enough to capture the actual reason that any model of $P$ is also a model of $Q.$ (For first-order logic, this can't happen; that's the Completeness Theorem.)
I suppose it's also conceivable that $P\models Q$ "accidentally"; that is, it just so happens that any model of $P$ is also a model of $Q,$ but there's no reason for it. It's hard to formalize this precisely (the word "reason" is vague), and it certainly can't happen for first-order logic; I don't know of any examples at all, and I'm not sure how you would even demonstrate such a thing if it were ever true of some language. ("Demonstrating" it would seem to involve providing a reason it's true, after all.)
Mitchell Spector
  • 9,917
  • 34
