According to >this proof<, the author is saying that
$g=\gcd(a,b)$, $g'\in\mathbb{N}$, and $g'=\gcd(a,b)$.
The author then states that $g'|g$ and $g|g'$.
From my understanding, $g'*k_1=a$ and $g*k_2=a$ [where $k_1$ and $k_2$ are integers].
It follows that $g'*k_1=g*k_2$.
But from that, how can one reach the conclusion that $g'|g$ and $g|g'$?
Edit:
The given definition of Greatest Common Divisor:
$g$ is the greatest common divisor of a and b, where $a$ and $b$ are non-zero integers if:
  1. $g|a$ and $g|b$
  2. if $c$ is any integer such that $c|a$ and $c|b$, then $c\leq{g}$
Edit2:
I'm assuming that $g$ and $g'$ are some greatest common divisors of $a$ and $b$.
FD_bfa
  • 3,989
    g and g' are same numbers... – windircurse Oct 09 '16 at 22:04
  • @DietrichBurde But we don't know that the GCD is unique. Maybe a pair of integers has two GCD. I think the OP is trying to prove it's unique. – Stefan4024 Oct 09 '16 at 22:07
  • When proving the uniqueness of a number (like $g = \gcd(a, b)$), for the purpose of contradiction, one supposes that another number exists ($g' = \gcd(a, b)$) and then goes on to conclude that the two numbers are, in fact, equal ($g = g'$) – amWhy Oct 09 '16 at 22:08
  • @Stefan4024 I only commented on the first line: $g=gcd(a,b)=g'$. There is no way to avoid the conclusion $g=g'$, and hence $g\mid g'$, $g'\mid g$. – Dietrich Burde Oct 09 '16 at 22:10
  • Ignoring that $g$ and $g'$ are obviously equal because there exists only one gcd for any two numbers, I'm looking for how the conclusion is reached from the point that one only knows that $g=gcd(a,b)$ and $g'=gcd(a,b)$. How is it proven, that $g'|g$ and $g|g'$ from that point? – luis_garibay Oct 09 '16 at 22:11
  • @DietrichBurde I agree that the question is poorly worded, but I think the OP is considering $g$ and $g'$ to be some greatest common divisors of $a,b$. – Stefan4024 Oct 09 '16 at 22:12
  • @luis_garibay How do you know that there exists only one gcd for any two numbers, when you're actually trying to prove that? – Stefan4024 Oct 09 '16 at 22:12
  • Stefan4024 Yes, you are probably right. The question should be edited then. @luis_garibay: could you make the question a bit more clear? – Dietrich Burde Oct 09 '16 at 22:13
Your statement is rather ambiguous. You probably want to show that if $g$ and $g'$ both satisfy the requirements for being a greatest common divisor of $a$ and $b$, then $g=g'$. (You cannot use $g=\gcd(a,b)$ until you have proved uniqueness, so this is why your statement is ambiguous.)
This depends on what definition of greatest common divisor you use. There are two common ones, when restricting ourselves to the natural numbers.
First definition. The greatest common divisor of $a$ and $b$ (not both $0$) is the largest common divisor of $a$ and $b$.
With this definition, there is no problem in stating uniqueness.
Second definition. A number $g$ is a greatest common divisor of $a$ and $b$ if
  1. $g\mid a$ and $g\mid b$
  2. for all $c$, if $c\mid a$ and $c\mid b$, then $c\mid g$
With this definition, uniqueness must be proved. Thus, since you're asking, I'll assume this is your definition.
Now, suppose $g$ and $g'$ both satisfy the requirements above.
Since $g\mid a$ and $g\mid b$ by 1 applied to $g$, we get, from 2 applied to $g'$ with $c=g$, that $g\mid g'$.
Since $g'\mid a$ and $g'\mid b$ by 1 applied to $g'$, we get, from 2 applied to $g$ with $c=g'$, that $g'\mid g$.
From here the proof of $g=g'$ follows easily.
egreg
  • 238,574
As $g'$ is a greatest common divisor of $a,b$ we have that $g' \mid a$ and $g' \mid b$, by definition. Now by the definition of a greatest common divisor $g$ is divided by any number that divides both $a$ and $b$, hence $g' \mid g$. Similarly we prove that $g \mid g'$, which implies that $g = g'$.
Stefan4024
  • 35,843
  • The definition of a greatest common divisor is only that d=gcd(a,b) if: 1) d|a and d|b; and 2) if c is any integer such that c|a and c|b, then c≤d. So, how does one reach the point that the gcd d is divisible by any integer that divides a and b? – luis_garibay Oct 09 '16 at 22:15
  • @luis_garibay
    The definition of a greatest common divisor is only that d=gcd(a,b) if: 1) d|a and d|b; and 2) if c is any integer such that c|a and c|b, then $c$ divides $d$
    – Stefan4024 Oct 09 '16 at 22:19
The proof shows that a gcd exists, then goes on to show that there can only be one gcd. He says to suppose that both $g$ and $g'$ are gcd's of $a$ abd $b$.
As egreg stated, the normal definition of gcd(a,b) is
If that's the case, it follows that $g \mid g'$ and $g' \mid g$. He argues that, clearly then, $g = g'$. Well, to be truely picky, he's wrong. If we are using the set of all integers, then it follows that $ g = \pm g'$. In a ring $R$, $u \in R$ is a unit if $u^{-1}$ exists in $R$. The units of the set of integers are $1$ and $-1$. If $x,y \in R$ can be expressed as $s = uy$, where $u$ is a unit in $R$, then $x$ and $y$ are called associates. So it would be more correct to say that any two gcd's of $a$ and $b$ are associates of each other.
To be honest, I have never seen your definition before:
  2. for all $c$, if $c\mid a$ and $c\mid b$, then $c \le g$
but it does work for the set of integers. And we could argue that,if $g$ and $g'$ are gcd's of $a$ and $b$, then $g \le g'$ and $g' \le g$. It would follow that $g=g'$.
If we employ the universal definition of the gcd then this uniqueness of the gcd (up to associates) follows immediately, as for all universal specified objects. Since this viewpoint is not mentioned in other answers it is instructive to explicitly present it, since this method applies widely, and it is quite simple here, namely
the OP gcd definition is equivalent to $\ d\mid a,b \!\!\color{#c00}{\overset{\rm def\!\!}\iff} d\mid \gcd(a,b),\ {\rm for\ all}\,\ d\in \Bbb N$
therefore: $\ \color{#0af}{g=}\gcd(a,b)\color{#0a0}{=g'}\:$ implies $\ \color{#0af}{d\mid g} \!\color{#c00}{\overset{\rm def\!\!}\iff}\, d\mid a,b \!\color{#c00}{\overset{\rm def\!\!}\iff}\, \color{#0a0}{d\mid g'},\:$ so $\:g\mid g'\mid g.\ \ \small\bf QED$
Remark $ $ If ideals are familiar then by $\Bbb Z$ isEuclidean $\Rightarrow$ PID the hypothesis is equivalent to
$$ (g) = (a,b) = (g')\qquad $$
hence by contains = divides in a PID $\ (g)\supseteq (g')\Rightarrow g\mid g'\:\!;\,$ reversely $\,g'\mid g\,$ by symmetry.
Bill Dubuque
  • 272,048
