Prove the given identity.
$$\left(\sin\frac {9\pi}{70}+ \sin\frac {29\pi}{70} - \sin\frac {31\pi}{70}\right) \left(\sin\frac {\pi}{70}-\sin\frac {11\pi}{70} - \sin\frac {19\pi}{70}\right) =\frac {\sqrt {5} -4}{4}$$
Please help, I could not gather enough ideas, even on how to get to the first step. I thought of using the transformation formula (from sum to product) but did not find a fruitful result.
UPDATE 1.:
$\left(-\frac{1 +\sqrt{5}}{8} + \frac{1}{8} \sqrt{14\left(5 - \sqrt{5} \right)}\right)\left(-\frac{ 1+ \sqrt{5}}{8} -\frac{1}{8} \sqrt{14 \left(5 -\sqrt{5} \right)}\right) $,
I noticed that Alexis had got to this point. Can anyone explain me how did he get here, with calculations. Please help.
Thanks in Advance.
dxiv
  • 76,497
pi-π
  • 7,416
  • Using Taylor expansion, I've rewritten the LHS as $\left[\sum_{n \text{ odd}}^\infty f(n)\left(9^n+29^n-31^n \right)\right]\times\left[\sum_{n \text{ odd}}^\infty f(n)\left( 1-11^n-19^n\right)\right]$ where $f(n)=(-1)^{\left(\frac{n+1}{2}-1\right)}\frac{k^n}{n!}$ with $k=\frac{\pi}{70}$, just in case someone got an idea from this. – Bobson Dugnutt Aug 17 '16 at 16:46
  • I've noticed that the expression is equivalent to $\left(-\frac{1 + \sqrt{5}}{8} + \frac{1}{8} \sqrt{14 \left(5 - \sqrt{5} \right)}\right) \left(-\frac{ 1+ \sqrt{5}}{8} - \frac{1}{8} \sqrt{14 \left(5 - \sqrt{5} \right)}\right) $, but I'm having difficulty proving this. – Alexis Olson Aug 18 '16 at 01:35
  • @ Alexis Olson, How did you get to that point? Could you please say me? – pi-π Sep 06 '16 at 12:14
  • Related: http://math.stackexchange.com/questions/1717536/proving-that-cos-frac2-pi13-cos-frac6-pi13-cos-frac8-pi13-frac http://math.stackexchange.com/questions/55120/showing-tan-frac2-pi13-tan-frac5-pi13-tan-frac6-pi13-sqrt6518-s http://math.stackexchange.com/questions/578286/how-prove-this-tan-frac2-pi134-sin-frac6-pi13-sqrt132-sqrt13 http://math.stackexchange.com/questions/279713/some-trigo-identities – lab bhattacharjee Sep 10 '16 at 15:06
  • @Lab, I could not relate those hints. Could you please provide more hints? – pi-π Sep 10 '16 at 15:36
  • @Alexis, How did you get that? Please show the calculation.? – pi-π Jan 11 '17 at 12:31
  • @LeonhardEuler Please do not vandalize your own question. Rolled back. – dxiv Mar 25 '17 at 17:36
A method using trigonometric identities, although a very long one -
For simplicity, let me put $\dfrac{\pi}{70}=A$. Now, the expression is -
$(\sin{9A}+\sin{29A}-\sin{31A})(\sin{A}-\sin{11A}-\sin{19A})$
Multiply out both the brackets completely and for each term of the type "$\sin*\sin$", convert it into sum of two cosines using the formula -
$2\sin{A}\sin{B}=\cos{(A-B)}-\cos{(A+B)}$, to get the following expression -
$\dfrac{1}{2}(\cos{8A}-\cos{10A}-\cos{2A}+\cos{20A}-\cos{10A}+\cos{28A}+\cos{28A}-\cos{30A}-\cos{18A}+\cos{40A}-\cos{10A}+\cos{48A}-\cos{30A}+\cos{32A}+\cos{20A}-\cos{42A}+\cos{12A}-\cos{50A})$
Now, convert all those cosines whose angles are greater than 90 degrees (i.e. greater than $35A$ here), into cosines of angles less than a 90 degrees (i.e. less than $35A$ here), by using the fact that $\cos{(180-A)}=-\cos{A}$, to get the following simplified expression -
$\dfrac{1}{2}(\cos{8A}-3\cos{10A}-\cos{2A}+3\cos{20A}+3\cos{28A}-3\cos{30A}-\cos{18A}-\cos{22A}+\cos{32A}+\cos{12A})$, which further becomes -
$\dfrac{1}{2}((\cos{8A}-\cos{22A})-(\cos{2A}+\cos{18A})+(\cos{32A}+\cos{12A})-3\cos{10A}+3\cos{20A}-3\cos{30A}+3\cos{28A})$
$\dfrac{1}{2}((\cos{8A}-\cos{22A})-2\cos{10A}\cos{8A}+2\cos{22A}\cos{10A}-3\cos{10A}+3\cos{20A}-3\cos{30A}+3\cos{28A})$
$\dfrac{1}{2}((\cos{8A}-\cos{22A})(1-2\cos{10A})-3\cos{10A}+3\cos{20A}-3\cos{30A}+3\cos{28A})$
$\dfrac{1}{2}((2\sin{15A}\sin{7A})(1-2\cos{10A})-3\cos{10A}+3\cos{20A}-3\cos{30A}+3\cos{28A})$
$\dfrac{1}{2}((2\sin{7A})(\sin{15A}-2\sin{15A}\cos{10A})-3\cos{10A}+3\cos{20A}-3\cos{30A}+3\cos{28A})$
$\dfrac{1}{2}((2\sin{7A})(\sin{15A}-\sin{25A}-\sin{5A})-3\cos{10A}+3\cos{20A}-3\cos{30A}+3\cos{28A})$
Now use: $\sin{15A}=\cos{20A},\sin{25A}=\cos{10A},\sin{5A}=\cos{30A}$ (Complementary angle pairs, check for yourself!) to write the above expression as -
$\dfrac{1}{2}((2\sin{7A})(\cos{20A}-\cos{10A}-\cos{30A})+3(\cos{20A}-\cos{10A}-\cos{30A})+3\cos{28A})$
$\dfrac{1}{2}((2\sin{7A}+3)(\cos{20A}-\cos{10A}-\cos{30A})+3\cos{28A})$
Now use: $\cos{20A}=-\cos{50A}$ (supplementary angle pairs, check for yourself!) and rewrite the above expression as -
$\dfrac{1}{2}((2\sin{7A}+3)(-\cos{10A}-\cos{30A}-\cos{50A})+3\cos{28A})$ ... (1)
$\cos{10A}+\cos{30A}+\cos{50A}=\dfrac{\cos{30A}\times\sin{30A}}{\sin{10A}}=\dfrac{\sin{60A}}{2\sin{10A}}=\dfrac{1}{2}$. Put this in expression (1) to get -
$\dfrac{1}{2}(-\dfrac{1}{2}(2\sin{7A}+3)+3\cos{28A})$
But $\cos{28A}=\sin{7A}=\dfrac{\sqrt{5}-1}{4}$. Finally put these to get your answer!
Fawad
  • 2,034
seavoyage
  • 556
  • Ahh i was writing the same answer, :( –  Aug 17 '16 at 19:49
  • That's okay...but the point still remains....can we have a better solution? :\ – seavoyage Aug 17 '16 at 19:50
  • I tried doing it with transformation formulae but it did not get anywhere, we still have to multiple the brackets. –  Aug 17 '16 at 19:57
    Wauw, nice (and cumbersome) work! Just some latex tips: Use \times ($\times$) or \cdot ($\cdot$) instead of $*$. Also, to make parenthesis that "fits" what's inside of them, use \left( \right). Cheers :) – Bobson Dugnutt Aug 17 '16 at 20:31
  • Can you explain the line after the equation labeled $(1)$? I'm having difficulty following. – Alexis Olson Aug 18 '16 at 01:25
    @AlexisOlson: For that, i used the formula for the "sum of cosines of angles in an arithmetic progression".....you can see it here: http://math.stackexchange.com/questions/117114/sum-cos-when-angles-are-in-arithmetic-progression – seavoyage Aug 18 '16 at 19:31
