In our school, we learned that proving using induction has three steps:
  1. Prove it for the smallest number of $n$. (Usually, $n=1$)
  2. Think it is true for $n$.
  3. Prove it is true for $n+1$.
But recently, when I was watching Olympiad video series, it told me that it is not a right way and you should follow this way:
  1. Prove it for the smallest $n$.
  2. Think it is true for $n+1$.
  3. Prove it is true for $n$.
  4. You proved it is true for $n$. Now from that, prove it for $n+1$.
Now I am really confused that how to use induction? Can you tell me what is the best way to use introduction, and give me a guarantee that it always works?
Taha Akbari
  • 3,559
A rigourous proof by induction is the following : you need to prove two things :
  • $P(0)$ is true
  • $\forall n \geq 0, P(n) \Rightarrow P(n+1)$ is true
Then, you apply the axiom of induction, and that allow you to conclude that $\forall n \geq 0, P(n)$ is true
Of course, in practice, to prove $P(n) \Rightarrow P(n+1)$, you just prove that if $P(n)$ is true, then $P(n+1)$ is true
Tryss
  • 14,310
The second method used in the video was probably this. When one is struggling with proving the inductive step $\,P_n\,\Rightarrow\, P_{n+1},\,$ it is often convenient to look not only at things that are implied by $\,P_n,\,$ but also at what things are equivalent to $\,P_{n+1}.\,$ For example, we might prove $\,P_n\,\Rightarrow\,A\,\Rightarrow\, A'\,$ and also $\,P_{n+1}\!\iff B\iff B' \iff A',\,$ so connecting the arrows
$$P_n\Rightarrow A\Rightarrow A'\Rightarrow B' \Rightarrow\ B\Rightarrow P_{n+1}$$
we obtain a complete proof of the inductive step. To do this we can assume that $\,P_{n+1}\,$ is true and then deduce the chain of equivalent statements $\,B^{(k)}\,$ by using only reversible steps, e.g. applying an invertible operation such as adding or subtracting some value to both sides of an equation (e.g. see this recent question). Note in particular that it does not suffice to deduce the wrong-direction unidirectional inferences $\,P_{n+1}\!\Rightarrow B\Rightarrow B'\Rightarrow\cdots$ since they do not allow us to connect the inferences to obtain the sought complete inference displayed above.
For an example of such deductions see this answer, where I deduce that the inductive step is equivalent to the truth of a recurrence $\,g_{n+1}- g_n = f_{n+1}\,$ when analyzing inductive proofs equivalent to telescopic sums (it will prove instructive to write out that equivalence in more detail to examine how the inferences reverse using addition and subtraction).
Such proof methods exploiting simultaneous forward and backward deduction is sometimes called (forward and) backward chaining, or more generally, (inductive) analysis and synthesis.
Bill Dubuque
  • 272,048
  • This is my suspicion too. I think it is a trick to help the student thing about the problem. – Git Gud Aug 06 '16 at 18:38
  • @Git I wouldn't call it a trick. These methods are useful very generally, e.g. in high school I figured out that forward and backward chaining was very handy when proving trig identities and my high school teacher liked it so much that he started teaching the same method. Of course for symmetric relations like equality we should have no preference from which side to start inferring things.Imposing a preference would stymie deduction. – Bill Dubuque Aug 06 '16 at 18:47
  • @Bill Dubuque +1 also In the video he sayed that the first method is wrong.Why? – Taha Akbari Aug 06 '16 at 19:09
  • @Taha The first method seems to be standard induction, so it is not clear what was claimed wrong. Maybe they were analyzing a faulty instance of that method? – Bill Dubuque Aug 06 '16 at 19:14
The first method you have shown only says "prove that if the $n$ case holds then the $n+1$ case holds". The second method says "prove that the $n$ case holds if and only if the $n+1$ case holds".
Mathematical induction in general deals with a set of cases $P_n$. It then shows an implication between $P_a$ and $P_b$, where $a$ and $b$ are related in a well-defined way, then proves a particular base case separately.
That this base case is true, by the relation proven earlier, implies that a second case is true. That this second case is true implies that a third case is true, and so on and so forth.
Induction isn't restricted to the natural numbers. The second method you have said, proving both ways, is actually necessary if the case indices $n$ are to span the integers, and a further modification allows case indices over rational numbers. Still, the base case must always be present, else you end up with paradoxes like "all horses are the same colour..."
Parcly Taxel
  • 103,344
