From "Linear Partial Differential Equations for Scientists and Engineers", Tyn Myint U..
In deriving D'Alemberts formula for the one dimensional wave equation the following equations occur on page 123:
Given the general solution
$$u(x,t) = \phi(x+ct)+\psi(x-ct) \tag{5.3.4}$$
and the initial conditions $$u(x,0) = f(x) = \phi(x)+\psi(x) \tag{5.3.5}$$
$$u_t(x,0) = g(x) = c\phi '(x)-c\psi '(x). \tag{5.3.6}$$
Then integrating the previous equation gives:
$$\phi(x)-\psi(x) = \frac{1}{c}\int_{x_0}^{x}g(\tau)d\tau + K \tag{5.3.7}$$
I am having problems deriving the last equation, 5.3.7. In the derivation, the previous equation, 5.3.6, appears to be integrated with respect to two different variables on the left and right sides. I think maybe separation of variables is being used, but if so I need help in understanding how it is used in this case. I would really appreciate being shown in small (simple) steps how this integral is produced.
Although I have referenced a particular book, all the D'Alembert formula derivations that I have seen are similar to this particular derivation, and leave me with the same question:
My Question is: How is the integral derived? That is: how is equation 5.3.7 derived from equation 5.3.6?
Except for this I understand the derivation of D'Alemberts Formula.
References for D'Alemberts formula:
http://mathworld.wolfram.com/dAlembertsSolution.html
https://en.wikipedia.org/wiki/D%27Alembert%27s_formula
http://www.jirka.org/diffyqs/htmlver/diffyqsse32.html
http://people.uncw.edu/hermanr/pde1/dAlembert/dAlembert.htm
References for separation of variables:
Integrating each side of an equation w.r.t. to a different variable?
Integrating with respect to different variables
Can anyone explain the intuitive meaning of 'integrating on both sides of the equation' when solving differential equations?
sepvar.pdf
Links to other related questions on math.stackexchange:
How to separate variables to integrate on both side
Integrating both sides of an equation with respect to different variables
Why are the limits of the integral $0$ and $s$, and not $-\infty$ and $+\infty$??
user45664
  • 807
The second initial conditions is given by
$$g(x)=c\phi'(x)-c\psi'(x)$$
whereupon integrating $g(\tau)=c\phi'(\tau)-c\psi'(\tau)$ from $\tau=x_0$ to $\tau =x$ becomes
$$\begin{align} \phi(x)-\psi(x)&=\phi(x_0)-\psi(x_0)+\int_{x_0}^x \left(\phi'(\tau)-\psi'(\tau)\right)\,d\tau\\\\ &=\frac1c\int_{x_0}^xg(\tau)\,d\tau+\underbrace{\phi(x_0)-\psi(x_0)}_{K} \tag 1 \end{align}$$
Adding $(1)$ to, and subtracting $(1)$ from the first initial condition, $f(x)=\phi(x)+\psi(x)$ yields
$$\begin{align} \phi(x)&=\frac12 f(x)+\frac{1}{2c}\int_{x_0}^xg(\tau)\,d\tau+\frac12(\phi(x_0)-\psi(x_0))\tag 2\\\\ \psi(x)&=\frac12 f(x)-\frac{1}{2c}\int_{x_0}^xg(\tau)\,d\tau-\frac12(\phi(x_0)-\psi(x_0))\tag 3 \end{align}$$
Finally, evaluating $(2)$ at $x= x+ct$ and $(3)$ at $x=x-ct$ and adding the results, we find that
$$\begin{align} u(x,t)&=\phi(x+ct)+\psi(x-ct)\\\\ &=\frac12\left(f(x+ct)+f(x-ct)\right)+\frac{1}{2c}\int_{x-ct}^{x+ct}g(\tau)\,d\tau \end{align}$$
And we are done!
Mark Viola
  • 179,405
  • I have edited this to more clearly state my specific question. I understand the overall derivation of the D'Alembert Formula :) – user45664 Aug 06 '16 at 02:00
  • The Equations $(5.36)$ is not correct. Note the appearance of $t$ in the arguments of $\phi$ and $\psi$ whereas the initial condition on the left-hand side is evaluated at $t=0$. And Equation $(5.37)$ is incorrect and should be replaced with the equation $(1)$ herein this post. I hope this clarifies that the answer I have posted provides the correct way forward. -Mark – Mark Viola Aug 06 '16 at 02:27
  • Thanks--fixed those errors. I still do not see how to get from 5.3.6 to 5.3.7 though. The left side appears to be integrated wrt t whereas the right side seems to be integrated wrt x? If so does that require separation of variables? Would appreciate details of the steps required. – user45664 Aug 06 '16 at 02:46
  • @user45664 As I stated, $(5.37)$ is wrong. Now, I edited my answer to show how to arrive at the corrected version of $(5.37)$, which is $(1)$ in my answer. Does that make sense? -Mark – Mark Viola Aug 06 '16 at 02:48
  • I think my (5.3.7) now is the same as your (1)--tell me if I'm missing something. Looking at the edited answer now :) – user45664 Aug 06 '16 at 02:54
  • Yes, your edit corrected the error. Have you read my answer with edits and if so, do you see now how the integration is executed? – Mark Viola Aug 06 '16 at 02:56
  • I assume that the right side of 5.3.6, $\phi$ ' and $\psi$ ' are time derivatives, and the integration is wrt $\tau$ which I assume is a dummy variable for x, ie a spatial variable. So I'm still confused. It seems the integration is temporal on one side and spatial on the other--wrt two different variables :) – user45664 Aug 06 '16 at 03:06
  • The derivatives in $(5.36)$ are derivatives on the single-variable functions $\phi$ and $\psi$. They are agnostic to the dummy variable. So, it doesn't matter whether you view the variable as spatial, temporal, or otherwise. – Mark Viola Aug 06 '16 at 12:21
  • But the time derivatives are first applied to $\phi(x+ct)$ and $\psi(x-ct)$ yielding $c\phi'(x+ct)$ and $-c\psi'(x-ct)$ and then afterward $t$ is set to zero resulting in $c\phi'(x)$ and $-c\psi'(x)$. How can they be integrated with respect to $x$ to produce $c\phi(x)$ and $-c\psi(x)$? That is the way i understand it. Where have i gone wrong? :) – user45664 Aug 06 '16 at 22:50
  • That is, they were two variable functions, later with one, $t$, set to zero. So they were derivatives on two-variable functions (not single-variable functions) at the time the derivatives were taken. – user45664 Aug 06 '16 at 22:59
  • It doesn't matter that $F(x,t)=\phi(x\pm ct)$ is a function of two variables. $F(x,0)=\phi(x)$ is a function of one variable. And $F(0,t)=\phi(\pm ct)$ is a function of one variable. The point is that $\phi(\text{anything})$ is a single variable function of the $\text{anything}$. I hope that this finally helps settle the confusion. – Mark Viola Aug 07 '16 at 01:18
  • Thanks for exploring that issue with me +1. Done for now. :) – user45664 Aug 07 '16 at 17:11
  • You're welcome. My pleasure. -Mark – Mark Viola Aug 07 '16 at 17:17
  • And feel free to best vote as you see fit. – Mark Viola Aug 07 '16 at 17:17
The original question was equation 5.3.6 appears to be integrated with respect to two different variables on the left and right sides to get equation 5.3.7.
But this is an illusion. Although the derivatives in equation 5.3.6 appear the be time derivatives, they are actually spatial derivatives as is shown in the following. Leibniz notation and the chain rule help clarify things.
Given $$u(x,t) = \phi(x+ct)+\psi(x-ct) \tag{5.3.4}$$ Differentiating with respect to t, using the chain rule since $\phi$ and $\psi$ have arguments that are functions rather than single variables, yields $$ \frac{\partial u(x,t)}{\partial t}\; =\; \frac{ \partial \psi(x-ct)}{\partial (x-ct) } \frac{ \partial (x-ct)}{\partial t }\; + \;\frac{ \partial \phi(x+ct)}{\partial (x+ct) } \frac{ \partial (x+ct)}{\partial t }\tag{a}$$
$$= \; c\left[-\frac{ \partial \psi(x-ct)}{\partial (x-ct) }\;+ \; \frac{ \partial \phi(x+ct)}{\partial (x+ct) }\right] \;\tag{b} $$ Then setting $t=0$: $$\frac{\partial u(x,0)}{\partial t}\;= \; -c\frac{ \partial \psi(x)}{\partial (x) }\;+ \; c\frac{ \partial \phi(x)}{\partial (x) } \;\tag{c}$$
$$=\; -c\psi'(x)+c\phi'(x)\;\;\;\tag{d}$$
Equation d is the same as equation 5.3.6 but here the primes clearly indicate differentiation with respect to the spatial variable, not the temporal variable.
Defining $g$ :
$$ g(x,t)=\frac{\partial u(x,t)}{\partial t}\; \tag{e}$$ so $$ \frac{\partial u(x,0)}{\partial t}\; =g(x,0)=g(x)\ \tag{f}$$ we get equation 5.3.6 $$ g(x)=\; -c\psi'(x)+c\phi'(x)\;\;\; \tag{g}$$ Then both sides can be integrated with respect to the spatial variable x to get equation 5.3.7 $$\phi(x)-\psi(x) = \frac{1}{c}\int_{x_0}^{x}g(\tau)d\tau + K \tag{h}$$
So this shows how equation 5.3.7 is derived from equation 5.3.6 which answers the question.
user45664
  • 807
