If a polynomial is given by $$y=\color{red}{a_0\left[1-\frac{l(l+1)}{2!}x^2+\frac{l(l+1)(l-2)(l+3)}{4!}x^4-\cdots\right]}+\color{blue}{a_1\left[x-\frac{(l-1)(l+2)}{3!}x^3+\frac{(l-1)(l+2)(l-3)(l+4)}{5!}x^5-\cdots\right]}\tag{1}$$ where $l$ is a constant and $a_0,a_1$ are coefficients.
The recurrence relation is given by $$a_{n+2}=-\frac{(l-n)(l+n+1)}{(n+2)(n+1)}a_n\tag{2}$$ The objective is to find the first few Legendre polynomials $P_l(x)$ such that $P_l(1)=1$ without using Rodrigues' formula:
$$\fbox{$P_l(x)=\frac{1}{2^{l}l!}\frac{\mathrm{d}^l}{\mathrm{d}x^l}{\left(x^2-1\right)}^l$}$$
The method given in my textbook states that:
If the value of $a_0$ or $a_1$ in each polynomial is selected so that $y = 1$ when $x = 1$, the resulting polynomials are called Legendre Polynomials, written $P_l(x)$. From $(1)$ and $(2)$ and the requirement $P_l(1) = 1$, we find the following expressions for the first few Legendre polynomials:
$\color{#180}{\quad P_0(x)=1,\quad P_1(x)=x}\quad \text{and}\quad \color{#180}{P_2(x)=\frac12(3x^2-1)}$
I don't understand how those polynomials marked $\color{#180}{\mathrm{green}}$ were obtained as I've only just started reading about Legendre polynomials and hence I'm not sure how to tackle this problem. But since it is mandatory that OP's show their efforts for questions of this nature
Here is my attempt anyway:
I substituted $l=0$ in the $\color{red}{\mathrm{red}}$ bracket to obtain $1=a_0(1)$ so $a_0=1$ and hence $P_0(x)=1$.
I substituted $l=1$ in the $\color{blue}{\mathrm{blue}}$ bracket to obtain $1=a_1(x)$ so $a_1=x$ and hence $P_1(x)=x$.
I substituted $l=2$ in the $\color{red}{\mathrm{red}}$ bracket to obtain $1=a_0\left[1-\dfrac{2(2+1)}{2!}x^2\right]=a_0\left[1-3x^2\right]$ so $a_0=\dfrac{1}{1-3x^2}\ne \frac12(3x^2-1)$.
Obviously I am doing something wrong. Can anyone please explain to me how to achieve the answers properly (and without using Rodrigues' formula)?
BLAZE
  • 8,458
I see three basic confusions in your question.
First: The normalization condition is that $P_l(x)$, evaluated at $x=1$, equals 1. It does not mean that, upon plugging in a given value of $l$, $y$ will equal 1 for all $x$. (The only way for that to be true is if $y=1$ identically.)
Second: You claim that the coefficients $a_0,a_1$ are found through the recurrence relation. But these two are precisely what the recurrence relation by itself can't tell you: One can find all higher coefficients in terms of them using the relation, but the leading coefficients are undetermined until one requires demands the normalization condition be satisfied.
Lastly, but perhaps most importantly: You write as though your $a_n$ is some function of $x$, but that is exactly what can never be the case for such coefficients. Otherwise, I could claim---quite absurdly---that a quadratic polynomial is of the form $A(x)x^2+B(x)x+C(x)$! So, for instance, $P_1(x)=x$ does not mean $a_1=x$ but rather $P_1(x)=a_1 x+a_0=x$ means $(a_1,a_0)=(1,0).$ In that same vein, $P_2(x)=\frac12(3x^2-1)$ does not mean $a_2=P_2(x)$; rather, $(a_2,a_1,a_0)=(\frac32,0,-\frac12)$. The point of the coefficients is to tell you what the polynomial is, not to themselves be the polynomial.
Semiclassical
  • 15,842
We consider for even $l$ the polynomial (OPs red part) \begin{align*} a_0^{(l)}\left[1-\frac{l(l+1)}{2!}x^2+\frac{l(l+1)(l-2)(l+3)}{4!}x^4-\cdots\right]\tag{1} \end{align*} and for odd $l$ the polynomial (OPs blue part) \begin{align*} a_1^{(l)}\left[x-\frac{(l-1)(l+2)}{3!}x^3+\frac{(l-1)(l+2)(l-3)(l+4)}{5!}x^5-\cdots\right]\tag{2} \end{align*}
Note, we use for convenience an upper index $(l)$ to indicate to which polynomial the index $a_0$ resp. $a_1$ belongs. (... and I suppose this helps to clarify the things ...)
Setting $l=0$ in (1) we obtain
\begin{align*} y_0(x)=a_0^{(0)} \end{align*}
We observe that all terms containing $x^2$ or higher powers of $x$ vanish, since they all contain the factor $l$.
Setting $l=1$ in (2) we obtain
\begin{align*} y_1(x)=a_1^{(1)}x \end{align*}
We observe that all terms containing $x^3$ or higher powers of $x$ vanish, since they all contain the factor $l-1$.
Similarly to the first case we obtain with $l=2$:
\begin{align*} y_2(x)=a_0^{(2)}\left[1-\frac{2\cdot 3}{2!}x^2\right]=a_0^{(2)}\left(1-3x^2\right) \end{align*} since all other terms in (1) contain the factor $l-2$.
We also know that $y_l(1)=1$ for all polynomials $y_l(x)$. We obtain
\begin{align*} y_0(1)&=a_0^{(0)}=1\\ y_1(1)&=a_1^{(1)}=1\\ y_2(1)&=-2a_0^{(2)}=1 \end{align*}
We conclude $a_0^{(2)}=-\frac{1}{2}$ and obtain finally
\begin{align*} y_0(x)&=a_0^{(0)}=1\\ y_1(x)&=a_1^{(1)}x=x\\ y_2(x)&=a_0^{(2)}\left(1-3x^2\right)=\frac{1}{2}\left(3x^2-1\right) \end{align*}
[2016-03-22]: Update according to OPs comment: Why can we restrict the consideration to $a_0^{(l)}$ when $l$ is even and restrict the consideration to $a_1^{(l)}$ when $l$ is odd?
The short answer is: Since the other series diverges when considering the boundary condition at $x=1$ we can set $a_1^{(l)}=0$ when $l$ is even and we can set $a_0^{(l)}=1$ when $l$ is odd.
Some details: We start with the Legendre differential equation \begin{align*} (1-x^2)y^{\prime\prime}-2xy^{\prime}+l(l+1)y=0\tag{3} \end{align*} and we want to find polynomials as solution which additionally fulfill the boundary condition
\begin{align*} y(1)=1 \end{align*}
We make an Ansatz with generating functions \begin{align*} y(x)=a_0+a_1x+a_2x^2+\cdots \end{align*} With the help of the differential equation (3) and via comparing coefficients we obtain \begin{align*} y(x)&=a_0^{(l)}\left[1-\frac{l(l+1)}{2!}x^2+\frac{l(l+1)(l-2)(l+3)}{4!}x^4-\cdots\right]\\ &+a_1^{(l)}\left[x-\frac{(l-1)(l+2)}{3!}x^3+\frac{(l-1)(l+2)(l-3)(l+4)}{5!}x^5-\cdots\right] \end{align*} with $a_0^{l}$ and $a_1^{l}$ being two degrees of freedom.
We next apply the boundary condition $y(1)=1$.
First case: $l=2k$ even. In this case $y$ has the shape \begin{align*} y(x)&=a_0^{(0)}\left[1-\frac{l(l+1)}{2!}x^2-\cdots \pm\frac{l(l+1)\cdots(l-2k+2)(l+2k-1)}{(l-2k)!}x^{l-2k}\right]\\ &+a_1^{(l)}\left[x-\frac{(l-1)(l+2)}{3!}x^3+\frac{(l-1)(l+2)(l-3)(l+4)}{5!}x^5-\cdots\right] \end{align*}
We see the $a_0^{(l)}$ series contains only finitely many terms, since all terms having factor $l-2k$ vanish. If we now consider $y(1)=1$, it can be shown that the other $a_1^{(l)}$ series diverges for $x=1$. To overcome this, we set $a_1^{(l)}=0$.
The second case is symmetrically. Here we correspondingly set $a_0^{(l)}=0$ since the $a_0^{(l)}$ series diverges, while the $a_1{(l)}$ series is a polynomial.
Markus Scheuer
  • 108,315
  • Thank you for a superb answer. I have one question: Can you explain why we only substitute say $l=1$ in $(2)$? Why not substitute $l=1$ in $(1)$ also? I know that $1$ is odd, but why does that mean we can only substitute odd numbers of $l$ in the odd part of the polynomial $(2)$? – BLAZE Mar 18 '16 at 23:12
    @Blaze: I've added some additional information which could be helpful. Regards, – Markus Scheuer Mar 19 '16 at 13:37
  • Thank you very much for your time. Perfect answer. – BLAZE Mar 23 '16 at 20:14
    @Blaze: You're welcome! Thanks for granting the bounty and your nice comment! :-) – Markus Scheuer Mar 23 '16 at 22:39
  • Since you gave such a good answer to this question I was wondering if you would take a look at this question which also involves Legendre polynomials but what I'm asking is much more simple. Best regards. – BLAZE Mar 25 '16 at 11:57
    @BLAZE: GEdgar provided a nice answer and according to your own answer it seems, that the essentials are clear to you.+1 for your answer and your mindful question. The upvote of GEdgar belongs to you. Best regards, – Markus Scheuer Mar 26 '16 at 19:23
  • Hi, I have another question involving Legendre Polynomials and was wondering if you could take a look at it. Best regards :) – BLAZE Mar 28 '16 at 04:57
