Re-write the main given equation in index notation (following the Einstein summation convention)
$$ D_t \Omega_{ij} + \Omega_{ik}\mathcal{D}_{kj} + \mathcal{D}_{ik}\Omega_{kj} = \nu\triangle \Omega_{ij} \tag{1}$$
Small $\omega$ is defined by
$$ \Omega_{ik}h^k = \frac12 \epsilon_{ijk}\omega_j h^k \tag{2}$$
which is the cross product definition. The $\epsilon_{ijk}$ is the Levi-Civita symbol (or fully antisymmetric tensor with $\epsilon_{123} = 1$).
Plugging in (2) (which implies that $\Omega_{ij} = \frac12 \epsilon_{ikj}\omega_k$) into (1) we have that
$$ \epsilon_{ilj} D_t\omega_l + \epsilon_{ilk}\mathcal{D}_{kj}\omega_l + \mathcal{D}_{ik}\epsilon_{klj}\omega_l = \nu \epsilon_{ilj}\triangle \omega_l \tag{3}$$
Next we use the property of the Levi-Civita tensor,
$$ \epsilon_{jik}\epsilon_{jlk} = 2 \delta_{jl} \tag{4}$$
which means that multiplying (3) by $\epsilon_{imj}$ gives
$$ 2D_t\omega_m + \left(\epsilon_{ilk}\epsilon_{imj}\mathcal{D}_{kj} + \epsilon_{klj}\epsilon_{imj}\mathcal{D}_{ik}\right) \omega_l = \nu \triangle \omega_m \tag{5}$$
The antisymmetry properties of the Levi-Civita tensor, as well as the symmetry of the tensor $\mathcal{D}$ can be used to show that
$$ \epsilon_{ilk}\epsilon_{imj}\mathcal{D}_{kj} = \epsilon_{klj}\epsilon_{imj}\mathcal{D}_{ik} $$
So by another property of the Levi-Civita tensor,
$$ \epsilon_{ijk}\epsilon_{imn} = \delta_{jm}\delta_{kn} - \delta_{jn}\delta_{km} \tag{6}$$
we conclude that (5) is equivalent to
$$ D_t\omega_m + \omega_m (\delta_{kj}\mathcal{D}_{kj} - \mathcal{D}_{jm}) = \nu \triangle \Omega_m ~.$$
Which shows that you in fact omitted one necessary condition for your equation to hold, which is that $\mathcal{D}$, in addition to being symmetric, is also trace-free.
If you have learned about differential forms, one should treat $\Omega$ as a differential two form on $\mathbb{R}^3$ and $\omega$ as a differential one form on $\mathbb{R}^3$ related by the Hodge star operator $\Omega = *\omega$. From this point of view the equation you want (the one for $\omega$) is merely obtained by taking the Hodge dual of the equation you are given (the one for $\Omega$) plus a little bit of multilinear algebra.
