90
I have studied that every normed space $(V, \lVert\cdot \lVert)$ is a metric space with respect to distance function
$d(u,v) = \lVert u - v \rVert$, $u,v \in V$.
My question is whether every metric on a linear space can be induced by norm? I know answer is no but I need proper justification.
Edit: Is there any method to check whether a given metric space is induced by norm ?
Thanks for help
Srijan
  • 12,518
  • 73
  • 115
6 Answers6
94
Let $V$ be a vector space over the field $\mathbb{F}$. A norm $$\| \cdot \|: V \longrightarrow \mathbb{F}$$ on $V$ satisfies the homogeneity condition $$\|ax\| = |a| \cdot \|x\|$$ for all $a \in \mathbb{F}$ and $x \in V$. So the metric $$d: V \times V \longrightarrow \mathbb{F},$$ $$d(x,y) = \|x - y\|$$ defined by the norm is such that $$d(ax,ay) = \|ax - ay\| = |a| \cdot \|x - y\| = |a| d(x,y)$$ for all $a \in \mathbb{F}$ and $x,y \in V$. This property is not satisfied by general metrics. For example, let $\delta$ be the discrete metric $$\delta(x,y) = \begin{cases} 1, & x \neq y, \\ 0, & x = y. \end{cases}$$ Then $\delta$ clearly does not satisfy the homogeneity property of the a metric induced by a norm.
To answer your edit, call a metric $$d: V \times V \longrightarrow \mathbb{F}$$ homogeneous if $$d(ax, ay) = |a| d(x,y)$$ for all $a \in \mathbb{F}$ and $x,y \in V$, and translation invariant if $$d(x + z, y + z) = d(x,y)$$ for all $x, y, z \in V$. Then a homogeneous, translation invariant metric $d$ can be used to define a norm $\| \cdot \|$ by $$\|x\| = d(x,0)$$ for all $x \in V$.
Henry T. Horton
  • 18,318
  • 60
  • 77
    Thank you very much. I understand now. – Srijan Jul 04 '12 at 02:42
    That is not enough as one needs to check that the so defined norm really induces the original metric and not another one: $d(\cdot,\cdot)\to|\cdot|\to d(\cdot,\cdot)$ – C-star-W-star Sep 29 '14 at 14:36
    This is an old post and it doesn't really matter much, but I have to be pedantic. So you say that if a metric comes from a norm on $\Bbb{R}$, then $d(ax,ay)=|a|d(x,y)$ but what if you just consider $\Bbb{R}$ as a vector space over ${0,1}$. Then the discrete metric IS homogeneous and translation invariant on this vector space. –  Jun 16 '15 at 00:16
  • Why does the metric need to be translation invariant? I understand that it needs to be homogeneous so it could even be considered a norm, but why should it have translation invariance? – Michael Munta Oct 11 '19 at 10:04
    @MichaelMunta If the metric is induced by a norm, then $d(x,y)=||x-y||$. So $d(x+z,y+z)=||(x+z)-(y+z)||=||x-y||=d(x,y)$. – Jamāl Feb 27 '20 at 15:30
    You should clarify that your field $F$ is normed, otherwise the notation $|a|$ is meaningless. – Moishe Kohan Jun 05 '20 at 23:24
29
Here is another interesting example: Let $|x-y|$ denote the usual Euclidean distance between two real numbers $x$ and $y$. Let $d(x,y)=\min\{|x-y|,1\}$, the standard derived bounded metric. Now suppose we look at $\Bbb{R}$ as a vector space over itself and ask whether $d$ comes from any norm on $\Bbb{R}$. Then if there is such a norm say $||.||$, we must have the homogeneity condition: for any $\alpha \in \Bbb{R}$ and any $v \in \Bbb{R}$,
$$||\alpha v || = |\alpha| ||v||.$$
But now we have a problem: The metric $d$ is obviously bounded by $1$, but we can take $\alpha$ arbitrarily large so that $||.||$ is unbounded. It follows that $d$ does not come from any norm.
20
As Henry states above, metrics induced by a norm must be homogeneous. You can see that they must also be translation invariant: $d(x+a,y+a)= d(x,y).$ So any metric not satisfying either of those can not come from a norm.
On the other hand, it turns out that these two conditions on the metric are sufficient to define a norm that induces that metric: $d(x,0)=\| x \|.$
Ragib Zaman
  • 35,127
    Thank you sir. I am fully satisfied with two answers given by you and Henry.:) – Srijan Jul 04 '12 at 02:44
    Did you mean instead that any metric not satisfying either of those can not come from a norm? And not the other way around? And also, these two conditions on the metric are sufficient to define a norm..? – T. Eskin Jul 04 '12 at 06:27
  • @ThomasE. Sorry, you are right, I muddled up the words. Thanks. – Ragib Zaman Jul 04 '12 at 08:43
Every homogeneous metric induces a norm via: $$\|x\|:=d(x,0)$$ and every norm induces a homogeneous and translation-invariant metric: $$d(x,y):=\|x-y\|$$
The clue herein lies in wether the induced norm really represents the metric as: $$d(\cdot,\cdot)\to\|\cdot\|\to d(\cdot,\cdot)$$ which is the case only for the translation-invariant metrics: $$d'(x,y)=d(x-y,0)=d(x,y)$$ whereas the induced metric always represents the norm as: $$\|\cdot\|\to d(\cdot,\cdot)\to\|\cdot\|$$ as a simple check shows: $$\|x\|'=\|x-0\|=\|x\|$$
C-star-W-star
  • 16,275
Personal Note:
Good question, I remember wondering the same thing myself back when I new to real analysis. Here's a counter example:
Counter Example
\begin{equation} d(x,y):=I_{\{(x,x)\}}(x,y):=\begin{cases} 1 &:\, \,x=y\\ 0 &:\, \,x\neq y. \end{cases} \end{equation} This is indeed a metric (check as an exercise).
Where $I_A$ is the indicator function of the set $A$; where here the set $(x,x)\in V\times V$.
If $r\in \mathbb{R}-\{0\}$, then $d(rx,ry)\in \{0,1\}$ hence $rd(x,y)\in \{0,r\}$ which is not in the range of $d:V\times V \rightarrow \mathbb{R}$.
So, the metric $d$ fails the property that any metric induced by a norm must have, ie: \begin{equation} \mbox{it fails to have the property that: } \|rx-ry\| =r\|x-y\|. \end{equation}
Interpretation & Some Intuition:
The problem is that the topology is too fine, so all this topology can do is distinguish between things being the same or different.
As opposed to a norm topology which distinguised between object being, or not being on the same line (for some appropriate notion of line) (as well as them being different).
Hope this helps :)
ABIM
  • 6,695
One possible way of showing that a metric does not arise from a norm is to show that it is bounded, as it then cannot be homogeneous.
Proof: Take $d$ a bounded metric on a space $X$: i.e. $\exists D \in \mathbb{R}_+$ such that $\forall (x,y) \in X^2, d(x,y) \leq D$. Suppose now for contradiction that $d$ arises from a norm, i.e. the exists a norm $ \|\cdot\|$ such that $d(x,y) = \|x - y\|$. Recall that the distance must then must be homogeneous, for we have $d(\lambda x, \lambda y) = \|\lambda x - \lambda y\| = |\lambda| \cdot \|x - y\| = |\lambda| d(x,y)$.
Take now $(x_0, y_0) \in X\times X$ such that $d(x_0, y_0)\neq0$ , then we must have that $d\left( \frac{D+1}{d(x_0, y_0)} \cdot x_0, \frac{D+1}{d(x_0, y_0)} \cdot y_0 \right) = \frac{D+1}{d(x_0, y_0)} \cdot d(x_0, y_0) = D + 1 > D $ which contradicts the upper bound of the metric.
jet
  • 467
