Obviously, if $F$ is a field, and $I$ is it's nonzero ideal, then it contains an invertible element of $F$(any nonzero element of $F$). Denote this element as $a$. Since $I$ is ideal, $aa^{-1} = 1 \in I$. Hence, $I = F$.
But I'm not sure how to prove that any commutative ring with identity without nonzero proper ideals is a field.
Jxt921
  • 4,458
Just think backwards:
If you have a commutative ring $R$ with identity, the only missing property to be a field is, that any element is invertible.
So let's assume $R$ is no field. You have some non-invertible element $r \neq 0$ and thus $rR$ is a proper ideal, since $1 \notin rR$.
MooS
  • 31,390
If $\{0\}$ is the only proper ideal, is a maximal ideal and $R/\{0\}\approx R$ is a field.
  • Well, OK, but I I would tend to think of "commutative rings with no nontrivial ideals are fields" as the essential reason why "the quotient of a commutative ring by a maximum ideal is a field", not the other way around... – Mike F Feb 15 '16 at 08:19
