Referring to this lecture , I want to know what is the difference between supremum and maximum. It looks same as far as the lecture is concerned when it explains pointwise supremum and pointwise maximum
In a finite set, it is interesting to consider this case : http://math.stackexchange.com/questions/259893/every-finite-set-contains-its-supremum-proof-improvement – Jan 12 '16 at 00:21
A maximum of a set must be an element of the set. A supremum need not be.
Explicitly, if $X$ is a (partially) ordered set, and $S$ is a subset, then an element $s_0$ is the supremum of $S$ if and only if:
- $s\leq s_0$ for all $s\in S$; and
- If $t\in X$ is such that $s\leq t$ for all $s\in S$, then $s_0\leq t$.
By contrast, an element $m$ is the maximum of $S$ if and only if:
- $s\leq m$ for all $s\in S$; and
- $m\in S$.
Note that if $S$ has a maximum, then the maximum must be the supremum: indeed, if $t\in X$ is such that $s\leq t$ for all $s\in S$, then in particular $m\in S$, so $m\leq t$, proving that $m$ satisfies the conditions to be the supremum.
But it is possible for a set to have a supremum but not a maximum. For instance, in the real numbers, the set of all negative numbers does not have a maximum: there is no negative number $m$ with the property that $n\leq m$ for all negative numbers $n$. However, the set of all negative numbers does have a supremum: $0$ is the supremum of the set of negative numbers. Indeed, $a\leq 0$ for all negative numbers $a$; and if $a\leq b$ for all negative numbers $a$, then $0\leq b$.
The full relationship between supremum and maximum is:
- If $S$ has a maximum $m$, then $S$ also has a supremum and in fact $m$ is also a supremum of $S$.
- Conversely, if $S$ has a supremum $s$, then $S$ has a maximum if and only if $s\in S$, in which case the maximum is also $s$.
In particular, if a set has both a supremum and a maximum, then they are the same element. The set may also have neither a supremum nor a maximum (e.g., the rationals as a subset of the reals). But if it has only one them, then it has a supremum which is not a maximum and is not in the set.
- 398,050
Spivak while trying to define the integral with Lower and Upper Sums, says that $m_i$ and $M_i$ would better be defined as infimum and supremum instead of minimum and maximum because we haven't yet clear out whether the function is continuous. Why? – George Smyridis Oct 18 '16 at 01:03
In terms of sets, the maximum is the largest member of the set, while the supremum is the smallest upper bound of the set.
So, consider $A=\{1,2,3,4\}$. Assuming we're operating with the normal reals, the maximum is 4, as that is the largest element. The supremum is also 4, as four is the smallest upper bound.
However, consider the set $B=\{x | x < 2\}$. Then, the maximum of B is not 2, as 2 is not a member of the set; in fact, the maximum is not well defined. The supremum, though is well defined: 2 is clearly the smallest upper bound for the set.
You will find many points in real analysis (har har har) where it is easier and more profitable to consider the supremum of a given set (or construct the supremum) than it would be to consider or construct the maximum.
- 1,913
The short answer is that if the maximum exists, there is no difference. But it is possible for a supremum to exist where the maximum does not.
- 31,960
Taken directly from the wikipedia page:
In mathematics, given a subset S of a totally or partially ordered set T, the supremum (sup) of S, if it exists, is the least element of T that is greater than or equal to every element of S. Consequently, the supremum is also referred to as the least upper bound (lub or LUB). If the supremum exists, it is unique. If S contains a greatest element, then that element is the supremum; otherwise, the supremum does not belong to S (or does not exist). For instance, the negative real numbers do not have a greatest element, and their supremum is 0 (which is not a negative real number).
- 5,503
- 8
- 41
- 62
- 3,455
1I didn't get it in the case of negative real numbers the supremum could be -0.0000000001 and it belongs to the set. I know that there is not bound to that I mean it will go on which means the supremum could go like -0.000000000000000000.................1. So is this the reason why supremum is not in the set? – user31820 Jun 19 '12 at 19:32
@user31820: I think you are missing the concept of boundedness. You should probably review some introductory analysis material. – AnonSubmitter85 Jun 19 '12 at 20:39
1Late to the party, but @user31820 - if you're still curious, no such number exists in the real numbers, but such a number does exist in the surreal numbers. It's certainly worth a look! – Apr 20 '16 at 19:08
