18
Consider having a matrix whose structure is the following:
$$ A = \begin{pmatrix} a_{1,1} & a_{1,2} & a_{1,3} & 0 & 0 & 0 & 0 & 0 & 0\\ a_{2,1} & a_{2,2} & a_{2,3} & 0 & 0 & 0 & 0 & 0 & 0\\ a_{3,1} & a_{3,2} & a_{3,3} & 0 & 0 & 0 & 0 & 0 & 0\\ 0 & 0 & 0 & a_{4,4} & a_{4,5} & a_{4,6} & 0 & 0 & 0\\ 0 & 0 & 0 & a_{5,4} & a_{5,5} & a_{5,6} & 0 & 0 & 0\\ 0 & 0 & 0 & a_{6,4} & a_{6,5} & a_{6,6} & 0 & 0 & 0\\ 0 & 0 & 0 & 0 & 0 & 0 & a_{7,7} & a_{7,8} & a_{7,9}\\ 0 & 0 & 0 & 0 & 0 & 0 & a_{8,7} & a_{8,8} & a_{8,9}\\ 0 & 0 & 0 & 0 & 0 & 0 & a_{9,7} & a_{9,8} & a_{9,9}\\ \end{pmatrix} $$
Question.
What about its determinant $|A|$?.
Another question
I was wondering that maybe matrix $A$ can be expressed as a product of particular matrices to have such a structure... maybe using these matrices:
$$ A_1 = \begin{pmatrix} a_{1,1} & a_{1,2} & a_{1,3}\\ a_{2,1} & a_{2,2} & a_{2,3}\\ a_{3,1} & a_{3,2} & a_{3,3}\\ \end{pmatrix} $$
$$ A_2 = \begin{pmatrix} a_{4,4} & a_{4,5} & a_{4,6}\\ a_{5,4} & a_{5,5} & a_{5,6}\\ a_{6,4} & a_{6,5} & a_{6,6}\\ \end{pmatrix} $$
$$ A_2 = \begin{pmatrix} a_{7,7} & a_{7,8} & a_{7,9}\\ a_{8,7} & a_{8,8} & a_{8,9}\\ a_{9,7} & a_{9,8} & a_{9,9}\\ \end{pmatrix} $$
I can arrange $A$ as a compination of those: $A = f(A_1,A_2,A_3)$
Kronecker product
One possibility can be the Kronecker product:
$$ A= \begin{pmatrix} 1 & 0 & 0\\ 0 & 0 & 0\\ 0 & 0 & 0\\ \end{pmatrix} \otimes A_1 + \begin{pmatrix} 0 & 0 & 0\\ 0 & 1 & 0\\ 0 & 0 & 0\\ \end{pmatrix} \otimes A_2 + \begin{pmatrix} 0 & 0 & 0\\ 0 & 0 & 0\\ 0 & 0 & 1\\ \end{pmatrix} \cdot A_3 $$
But what about the determinant??? There are sums in this case which is not good...
hm2020
Andry
  • 1,033
    Look at the definition of the determinant that defines it in terms of the a sum over the permutation group $S_n$. This will convince you of the idea. The result is here. – John Engbers May 23 '12 at 02:42
  • @John: Thanks a lot man... didn't see it when looked for it. Please post an answer, I will accept it :) – Andry May 23 '12 at 02:46
First write $$\left[ \begin{array}{cccc} A_1 \hspace{-5pt} &&& \\ & A_2 \hspace{-5pt} && \\[-3pt] && \ddots \hspace{-5pt} & \\ &&& A_k \end{array} \right] = \left[ \begin{array}{cccc} A_1 \hspace{-5pt} &&& \\ & \text{I}_{n_2} \hspace{-5pt} && \\[-3pt] && \ddots \hspace{-5pt} & \\ &&& \text{I}_{n_k} \end{array} \right] \left[ \begin{array}{cccc} \text{I}_{n_1} \hspace{-5pt} &&& \\ & A_2 \hspace{-5pt} && \\[-3pt] && \ddots \hspace{-5pt} & \\ &&& \text{I}_{n_k} \end{array} \right] \dots \left[ \begin{array}{cccc} \text{I}_{n_1} \hspace{-5pt} &&& \\ & \text{I}_{n_2} \hspace{-5pt} && \\[-3pt] && \ddots \hspace{-5pt} & \\ &&& A_k \end{array} \right] $$ Also, $$\det \left( \left[ \begin{array}{ccccc} \text{I}_{n_1} \hspace{-5pt} &&&& \\[-3pt] & \ddots \hspace{-5pt} &&& \\ && A_j \hspace{-5pt} && \\[-3pt] &&& \ddots \hspace{-5pt} & \\ &&&& \text{I}_{n_k} \end{array} \right] \right) = \det (A_j)$$ which can be seen by using the cofactor formula and repeatedly expanding along a row or column with all 0's and one 1
$$ \implies \det \left( \left[ \begin{array}{cccc} A_1 \hspace{-5pt} &&& \\ & A_2 \hspace{-5pt} && \\[-3pt] && \ddots \hspace{-5pt} & \\ &&& A_k \end{array} \right] \right) = \det (A_1) \det (A_2) \cdots \det (A_k)$$
  1. The determinant of a block diagonal matrix is equal to the product of the determinants of the diagonal blocks. In your case, you have a block diagonal matrix of the form $$A=\left(\begin{array}{ccc} A_1 & 0 & 0\\ 0 & A_2 & 0\\ 0 & 0 & A_3 \end{array}\right)$$ so $\det(A) = \det(A_1)\det(A_2)\det(A_3)$.
  2. You can, though it is a bit ad-hoc. For example, note that if we let $$T_1 = \left(\begin{array}{ccccccccc} 1 & 0 & 0 & 0 & 0 & 0 & 0 & 0 & 0\\ 0 & 1 & 0 & 0 & 0 & 0 & 0 & 0 & 0\\ 0 & 0 & 1 & 0 & 0 & 0 & 0 & 0 & 0 \end{array}\right)$$ then $T_1^tA_1T_1$ is the block diagonal matrix $$\left(\begin{array}{ccc} A_1 & 0 & 0\\ 0 & 0 & 0\\ 0 & 0 & 0 \end{array}\right).$$ Likewise, if we let $$\begin{align*} T_2 &=\left(\begin{array}{ccccccccc} 0 & 0 & 0 & 1 & 0 & 0 & 0 & 0 & 0\\ 0 & 0 & 0 & 0 & 1 & 0 & 0 & 0 & 0\\ 0 & 0 & 0 & 0 & 0 & 1 & 0 & 0 & 0 \end{array}\right)\\ T_3 &= \left(\begin{array}{ccccccccc} 0 & 0 & 0 & 0 & 0 & 0 & 1 & 0 & 0\\ 0 & 0 & 0 & 0 & 0 & 0 & 0 & 1 & 0\\ 0 & 0 & 0 & 0 & 0 & 0 & 0 & 0 & 1 \end{array}\right) \end{align*}$$ then the resulting matrix is $$f(A_1,A_2,A_3) = T_1^tA_1T_1 + T_2^tA_2T_2 + T_3^t A_3 T_3.$$
Arturo Magidin
  • 398,050
As stated as a comment, the result is here. It really makes block diagonal matrices wonderful, hence finding canonical forms important.
John Engbers
  • 1,118
A "functorial approach" using the exterior product: If $\phi: V \rightarrow V$ is an endomorphism of a vector space, you may calculate the determinant of the endomorphism $\phi$ as the induced map
$$\wedge^n (\phi): \wedge^n V \rightarrow \wedge^n V$$
where $n:=\dim(V)$. Since $\wedge^n$ is a functor you get a canonical map $\wedge^l (\phi)$ for any integer $l \geq 1$.
It follows $\wedge^n (\phi)$ is an endomorphism of a one dimensional vector space $\wedge^n V$ and hence it is given as multiplication with a number $a$. The number $a$ is the determinant: $a=\det(\phi)$ of the map $\phi$. If you choose a basis $B$ of $V$ and the matrix of $\phi$ in this basis is a matrix $A$, it follows $a=det(A)$ is the determinant of the matrix $A$.
There is a formula:
$$\wedge^{n_1+n_2}(V_1\oplus V_2) \cong \wedge^{n_1}V_1 \otimes \wedge^{n_2}V_2,$$
where $n_i:=\dim(V_i)$. Let
\begin{align*} \phi= \begin{pmatrix} \phi_1 & 0 \\ 0 & \phi_2 \end{pmatrix} \end{align*}
where $\phi_i$ is an endomorphism of $V_i$. It "follows"
$$\det(\phi)=\wedge^{n_1+n_2}(\phi) \cong \wedge^{n_1}(\phi_1) \otimes \wedge^{n_2}(\phi_2)$$
But the tensor product $\wedge^{n_1}V_1 \otimes \wedge^{n_2}V_2$ is a one dimensional vector space and any linear endomorphism of such a space is given (in a basis) as multiplication with a number. Choosing a basis it follows the endomorphism $\wedge^{n_1}(\phi_1) \otimes \wedge^{n_2}(\phi_2)$ is multiplication with the number
$$\det(A_1)\det(A_2),$$
where $A_i$ is a matrix of $\phi_i$ in a basis $B_i$ for $V_i$.
Question: "But what about the determinant???"
By induction it follows that if $M$ is a matrix with square matrices $A_i$ along the diagonal, you get the formula
$$\det(M)=\det(A_1) \cdots \det(A_n).$$
hm2020
