20
Let $M,N$ be $R$-modules with $M$ finitely generated and let $S\subseteq R$ be multiplicatively closed. Then there exists a module isomorphism $$S^{-1}\text{Hom}_R(M,N) \xrightarrow{\sim} \text{Hom}_{S^{-1}R}(S^{-1}M,S^{-1}N).$$
As homework, I found a 'proof' of this statement. However, Does localisation commute with Hom for finitely-generated modules? claims to prove me wrong. I am having trouble in finding the error in my proof. Could someone help me out?
I did prove there exists a map $\phi:S^{-1}\text{Hom}_R(M,N) \to\text{Hom}_{S^{-1}R}(S^{-1}M,S^{-1}N)$ defined by $f/s\mapsto(m/t\mapsto f(m)/st)$, and I am fairly confident that it contains no mistake.
Proof: Let $m_1,\dotsc,m_n$ be the generators for M. Let $f\in \text{Hom}_{S^{-1}R}(S^{-1}M,S^{-1}N)$ be given. Choose $n_i\in N$ and $s_i\in S$ such that $f(m_i/1)=n_i/s_i$. Define $\pi_f = s_1\dotsm s_n$. Then $$\pi f(m/1) = \pi f\left( \sum_{i=1}^n r_i m_i \right) = \pi \sum_{i=1}^n r_i f(m_i) = \pi \sum_{i=1}^n r_i n_i/s_i = \left(\sum_{i=1}\left(\prod_{j=1, j\neq i}^n s_i\right)r_in_i\right)/1,$$ so $\pi f(m/1) \in N$ using the canonical embedding in $S^{-1}N$, so $m\mapsto \pi f(m/1)$ is a map $M\to N$ and is clearly an homomorphism.
If we define the map $\psi:\text{Hom}_{S^{-1}R}(S^{-1}M,S^{-1}N)\to S^{-1}\text{Hom}_{R}(M,N)$ as $$ f \mapsto (m\mapsto \pi_f f(m)) / \pi_f,$$ then we clearly have a homomorphism if it is well-defined.
Proof: It remains to check that the element we map to does not depend on choice of $\pi_f$. But if we have both $\pi_f$ and $\pi_f'$ for which $\pi_f f$ and $\pi_f' f$ are homomorphisms to $N$, then $$(\pi_f f(m))/\pi_f = (\pi_f\pi_f' f(m))/(\pi_f\pi_f') = (\pi_f' f(m))/(\pi_f')$$ for all $m\in M$, so $\psi$ is in fact well defined.
It is now easy to check that $\psi$ and $\phi$ are inverses, which makes them homomorphisms.
    This works for finitely presented modules, but not in general for finitely generated modules. – Pedro Oct 05 '15 at 19:54
The problem with your argument is quite subtle: you can't say $\pi f(m/1)\in N$, because the canonical homomorphism $i:N\to S^{-1}N$ may not be injective (because elements of $S$ might annihilate elements of $N$). That is, there is always some element $n\in N$ such that $i(n)=\pi f(m/1)$, but that $n$ might not be unique, and it is not clear that you can choose such an $n$ for each $m$ such that the map $M\to N$ you obtain is a homomorphism. This problem does not occur if $S$ acts on $N$ by non-zero divisors (i.e., $sn=0$ implies $n=0$ for $s\in S$, $n\in N$), because then $i$ is injective.
In general, in fact, there might not be any way to choose an $n$ for every $m$ such that you get a homomorphism. For instance, let $R=k[x,y_1,y_2,y_3,\dots]$ be a polynomial ring in infinitely many variables, let $M=R/(y_1,y_2,y_3,\dots)$, let $N=R/(xy_1,x^2y_2,x^3y_3,\dots)$, and let $S=\{1,x,x^2,\dots\}$. Then it is not too hard to see that there are no nonzero homomorphisms $M\to N$ (for an element of $N$ to be annihilated by every $y_n$, it would need to be infinitely divisible by $x$). But $S^{-1}M$ and $S^{-1}N$ are actually canonically isomorphic: both can be identified with $k[x,x^{-1}]$ with every $y_n$ acting trivially. In particular, this means $\operatorname{Hom}_{S^{-1}R}(S^{-1}M,S^{-1}N)$ is nonzero (it contains an isomorphism), whereas $S^{-1}\operatorname{Hom}_R(M,N)=S^{-1}0=0$. It is a good exercise to run through your proof with this example and see exactly how it breaks down.
To make the proof work in general, you need $M$ to be finitely presented, not just finitely generated. The idea behind the proof is then to choose an $n_i\in N$ lifting $\pi f(m_i/1)$ for each generator $m_i$ of $M$, where you choose $\pi\in S$ not just such that such a lift exists but also such that these $n_i$ will satisfy all of the finitely many relations between the $m_i$. This implies that the map $m_i\mapsto n_i$ extends to a well-defined homomorphism $M\to N$.
Eric Wofsey
  • 330,363
  • I appreciate your extensive answer and the fact that you found a counterexample that I can understand (ultrafilters are still pure magic to me). I never considered that $S^{-1}N$ could be 'smaller' than $N$, as adding invertable elements should intuitively enlarge a ring. I am also surprised this proof could be mended by adding the condition that $S$ acts on $N$ by non-zero divisors. If I am correct, this is not necessarily a stronger or weaker condition than $M$ being finitely presented, right? – MadPidgeon Oct 06 '15 at 08:28
    Yeah, whether $S$ acts on $N$ be non-zero divisors is totally independent of whether $M$ is finitely presented. The result is true if either $M$ is finitely presented or $M$ is finitely generated and $S$ acts on $N$ by non-zero divisors. – Eric Wofsey Oct 06 '15 at 16:06
The mistake is in the sentence: 'and is clearly a homomorphism' (there is a choice of the $r_i$, they are not unique).
SlavaM
  • 443
    But $\pi f(m/1)$ on the left is a unique element in $S^{-1} N$, so the scary sum of products should also be always the same element, regardless of whether there are more ways to write $m$ as a linear combination of generators? And with that, the map $m\mapsto \pi f(m/1)$ should be well defined. – MadPidgeon Oct 05 '15 at 21:45
  • Yes, MadPigeon is correct; you don't have a problem with non-uniqueness of the $r_i$ because you know that $f$ is a homomorphism already. The error is in concluding that $\pi f(m/1)\in N$; see my answer. – Eric Wofsey Oct 05 '15 at 22:04
    @MadPidgeon No, you have chosen a representant (depending on the choice of the $r_i$) in $N$ of $\pi f(m/1)$. Of course the composition of this map with $N \to S^{-1}N$ is a homomorphism, but it is not at the level of $N$. In other words, you lift $\pi f:M \to S^{-1}M \to S^{-1}N$ to a map (but not a homomorphism) $M \to N$ giving a homomorphism after composing with $N \to S^{-1}N$. If you choose other $r_i$ you will get in general other images in $N$ (though after composing with $N \to S^{-1}N$ you will get always the same element). – SlavaM Oct 05 '15 at 23:18
  • @Eric Wofsey The problem is indeed with the choice of the $r_i$, but your answer is clearly right: both answers are the same with different words (see my last comment to MadPidgeon). – SlavaM Oct 05 '15 at 23:22
  • Ah, fine, we're just reading that line differently. If you read the line with the $r_i$ as already taking place inside $N$, then there is a problem; if you read it as taking place inside $S^{-1}N$ then there is no problem (but the next line has a problem). – Eric Wofsey Oct 05 '15 at 23:48
