It's a question of a some time ago test, I've found a way to solve the problem using calculus, but always I've thought that exist a solution with algebra and geometry.
Thank you for your time.
A.Γ.
  • 29,518
5 Answers5
Hint: $$ \frac{\log(x)}x $$ is monotonically decreasing for $x\gt e$.
Pre-calculus Approach
We will use the fact that $e^h\ge1+h$ for $h\ge0$.
If $x\ge1$ and $h\ge0$, then $$ \begin{align} \frac{x+h}{e^{x+h}}-\frac{x}{e^x} &=\frac{x+h-xe^h}{e^{x+h}}\\ &=\frac{\overbrace{\vphantom{\left(e^h\right)}\ \ \ \ x\ \ \ \ }^{\ge1}\overbrace{\left(1+h-e^h\right)}^{\le0}+\overbrace{\vphantom{\left(e^h\right)}(1-x)}^{\le0}\overbrace{\vphantom{\left(e^h\right)}\ \ \ \ h\ \ \ \ }^{\ge0}}{e^{x+h}}\\\\ &\le0 \end{align} $$ Thus, $\frac x{e^x}$ is monotonically decreasing for $x\ge1$. Since $\log(x)$ is monotonically increasing, substituting $x\mapsto\log(x)$ says that $\frac{\log(x)}x$ is monotonically decreasing for $x\ge e$.
robjohn
  • 345,667
  • I hypothesize this is somehow what the OP showed "using calculus"; perhaps the hint should point him towards an "algebraic or geometric proof" of this fact. –  Aug 16 '15 at 18:55
    @G.Sassatelli: I finally found a pre-calculus approach that uses the fact that $e^x\ge1+x$. This can be proven using Bernoulli's Inequality. – robjohn Aug 16 '15 at 21:02
  • Oh dear... you beat me. +1 – Vim Aug 17 '15 at 00:52
Warning: not pretty.
Since $3^{47}\times 7^{45} \approx 2.85\times 10^{60}$ and $22^{45}\approx 2.56\times 10^{60}$, it follows that $3^{47}\times 7^{45} > 22^{45}$, and hence $$ 3^{\frac{47}{15}} > \left(\frac{22}{7}\right)^{\frac{45}{15}} = \left(\frac{22}{7}\right)^3. $$ Since $\frac{47}{15}<\pi<\frac{22}{7}$, the result follows.
EDIT: A slightly less bashy way to get the result $3^{47}\times 7^{45} > 22^{45}$:
Note the inequalities \begin{matrix} 17010 > 16384 &\implies& 3^5\times7\times10 &>& 2^{14} \\ 4000 > 3993 &\implies& 2^2\times10^3 &>& 3\times11^3 \\ 2401 > 2400 &\implies& 7^4 &>& 2^3\times3\times10^2 \\ 243 > 242 &\implies& 3^5 &>& 2\times11^2 \end{matrix} Raising the first inequality to the 1st power, the second to the 7th, the third to the 11th, the fourth to the 12th, and multiplying, we have $$ 2^{14}\times 3^{65}\times 7^{45}\times 10^{22} > 2^{59}\times 3^{18}\times 10^{22}\times 11^{45}$$ which simplifies to $3^{47}\times 7^{45} > 22^{45}$.
Joey Zou
  • 8,466
Now you want $$3^{\pi}>\pi^3$$ Taking logarithm, it suffices to show $$\frac{\ln3}{3}>\frac{\ln\pi}{\pi}$$ It again suffices to show that $$f(x)=\ln x/x$$ is strictly decreasing at least when $x\ge3$.
From a geometric point of view, $\ln x/x$ is equal to the slope $k(x)$ of the line that connects the origin and the point $(x,\ln x)$ located on the curve $y=\ln(x)$. Now from the graph it is obvious that $k(x)$ assumes maximum at some $x_0$ where the line is tangent to the curve, and $k(x)$ is strictly decreasing when $x>x_0$ (strictly speaking it is due to concavity of the logarithm function). Thus all you have to do is to find the $x_0$ (how? Well, try to give it a shot!) and you'll find out that $x_0=e<3$, so...
EDIT @robjohn pointed out that finding the exact value of $x_0$ requires calculus, so I'm "de-calculizing" this part:
Well, you don't have to find the exact value, just making sure $x_0\le3$ is sufficient. Thus, if you have a calculator at hand, by verifying the following $$\ln2.8/2.8>\ln2.9/2.9$$ You can verdict that $x_0\le 2.9$. If not, $f(x)$ should be strictly increasing when $x<2.9$ and hence contradiction. (However this trick is a little bit empirical I confess).
NOTE Although it seems to be a de-calculized answer now, it is, strictly speaking, still implicitly based on calculus - without calculus, we won't even have the notion of the concavity of a graph, or the geometrical intuition that $k(x)$ hits max at the tangent position. So if you are really in search of a literally non-calculus answer, @robjohn sure has the best one.
Vim
  • 13,640
  • A bit confused about the use of terminology, should I say "due to the concavity" in place of convexity here? Concave up convex down or..? – Vim Aug 16 '15 at 18:46
  • Yeah, $\log$ is concave. – A.Γ. Aug 16 '15 at 19:10
  • @A.G. Fixed. Thanks for pointing out. – Vim Aug 16 '15 at 19:11
  • @Vim You can say either "concave" or "concave down", vs. "convex" or "concave up". I agree the two parallel conventions are a bit confusing. – Ian Aug 16 '15 at 19:18
Hint: $$\pi >3\log _{ 3 }{ \pi } \\ \log _{ 3 }{ \pi } >1\\ \pi >3\log _{ 3 }{ \pi } >3$$
haqnatural
  • 21,578
    The first inequality doesn't seem obvious (and is exactly the given inequality). Could you explain where that comes from? – Michael Burr Aug 16 '15 at 18:28
    @MichaelBurr The logarithm function is monotonically increasing. But I am very sure that you know this. – Mark Viola Aug 16 '15 at 18:29
    @Dr.MV Perhaps I'm being silly, but monotonicity doesn't seem to be enough (the first inequality could be found by taking the log of the original inequality, but that would make a circular proof.) In fact, knowing $\pi>3\log_3\pi$ is enough to prove the desired inequality. It may be that (without words), I'm not following the order / logic of the argument. – Michael Burr Aug 16 '15 at 18:34
    @MichaelBurr Well, it is only a hint. And that hint is precisely your observation (i.e., the equivalence of the original statement and the first inequality of the hint). – Mark Viola Aug 16 '15 at 18:39
    @Dr.MV In fact it's not very easy to show the monotonicity. – Vim Aug 16 '15 at 18:41
  • @Vim The monotonicity is easy if you know that it's the inverse of the $3^x$ function which, is, itself increasing. – Michael Burr Aug 16 '15 at 18:47
  • @Vim $f(x) = \log x\implies f'(x)=x^{-1}$. What is the challenge? – Mark Viola Aug 16 '15 at 18:47
  • @Dr.MV Sorry. I mean that of $\ln x/x$. The first inequality I think is based on this function or something like. – Vim Aug 16 '15 at 18:49
  • That was not relevant here. But, $\frac{d}{dx}\left(\frac{\log x}{x}\right)=\frac{1-\log x }{x^2}\le 0 $ when $x\ge e$ is evident. – Mark Viola Aug 16 '15 at 18:53
Here's a proof using the inequalities $3.14\lt\pi\lt3.1416$.
We start with some seemingly random observations:
$$0.0475\times21=0.95+0.0475=0.9975\lt1\implies0.0475\lt{1\over21}\implies1.0475\lt{22\over21}$$
$$1.0475\lt{22\over21}\implies(1.0475)^2\lt{484\over441}=1+{43\over441}\lt1.1$$
(Alternatively you could simply compute $(1.0475)^2=1.0972562\lt1.1$, but I'm trying to stick to arithmetic that can be easily checked by eye.)
$$1.1^2=1.21\lt1.25={5\over4}$$ $$1.1^3=1.331\lt1.333\ldots={4\over3}$$
Putting all this together, we have
$$(1.0475)^{22}\lt(1.1)^{11}=(1.1)^{2+3+3+3}\lt{5\over4}\left(4\over3\right)^3={80\over27}\lt3$$
Now we're getting somewhere:
$${\pi\over3}\lt{3.1416\over3}=1.0472\lt1.0475\implies\left(\pi\over3\right)^{22}\lt3$$
This in turn implies
$$\left(\pi\over3\right)^{150}\lt\left(\pi\over3\right)^{154}=\left(\pi\over3\right)^{22\cdot7}\lt3^7$$ hence $$\left(\pi\over3\right)^{3}\lt3^{7/50}=3^{0.14}$$ and thus
$$\pi^3\lt3^3\cdot3^{0.14}=3^{3.14}\lt3^\pi$$
as desired.
Needless to say, all the trial and error of the sausage making has been swept under the rug; the presentation here pretty much unwinds the thought process that went into it. Also, no justification is given for the inequalities $3.14\lt\pi\lt3.1416$. A proper proof would truly start from scratch.
Barry Cipra
  • 79,832
