Problem. Show that a bounded function $ f: [a,b] \to \Bbb{R} $ is Riemann-integrable if and only if for every $ \epsilon > 0 $, there exists a $ \delta > 0 $ such that for any partition $ \mathcal{P} = (x_{0},\ldots,x_{n}) $ of $ [a,b] $ satisfying $ \| \mathcal{P} \| < \delta $, we have $ U(f;\mathcal{P}) - L(f;\mathcal{P}) < \epsilon $.
Note: $ \| \mathcal{P} \| \stackrel{\text{df}}{=} \max(\{ x_{i} - x_{i - 1} \mid i \in \{ 1,2,\ldots,n \} \}) $.
I know that the condition for Riemann-integrabiliy means that for every $ \epsilon > 0 $, there exists a $ \mathcal{P} $ such that $$ U(f,\mathcal{P}) - L(f,\mathcal{P}) < \epsilon. $$ How does this relate to using $ \delta $ in the problem above?
I am reading Page $ 172 $ of Pete Clark’s notes, and the dicing lemma seems like something I may need. Can anyone point me to good references regarding this question?
grayQuant
  • 2,619
Well the question which you have mentioned is pretty easy. It is the converse which is bit hard to prove. Thus your accepted criteria of Riemann integrability is as follows:
(1) Let $f$ be bounded on $[a, b]$. Then $f$ is Riemann integrable on $[a, b]$ if for any $\epsilon > 0$ we can can find a partition $\mathcal{P}$ of $[a, b]$ such that $U(f, \mathcal{P}) - L(f, \mathcal{P}) < \epsilon$.
Thus for integrability check we need to find one partition $\mathcal{P}$ for every $\epsilon > 0$ which meets the above condition.
Now consider your question which asks to prove Riemann integrability of $f$ on $[a, b]$ provided that $f$ satisfies the following condition:
(2) For any $\epsilon > 0$ there is a number $\delta > 0$ such that for any partition $\mathcal{P}$ of $[a, b]$ with $||\mathcal{P}|| < \delta$, we have $U(f, \mathcal{P}) - L(f, \mathcal{P}) < \epsilon$.
Thus for any $\epsilon > 0$ we have a $\delta > 0$ which satisfies the condition written above. Let $n$ be a positive integer such that $0 < (b - a)/n < \delta$. Then we can see that the partition $\mathcal{P}$ defined by $$\mathcal{P} = \{x_{0}, x_{1}, x_{2}, \dots, x_{n}\},\,\, x_{i} = a + \frac{i(b - a)}{n}$$ has the norm $||\mathcal{P}|| = \dfrac{b - a}{n} < \delta$ and hence we have $$U(f, \mathcal{P}) - L(f, \mathcal{P}) < \epsilon$$ So for any $\epsilon > 0$ we have found a partition $\mathcal{P}$ which satisfies the accepted criteria $(1)$ for Riemann integrability. This proves that $f$ is Riemann integrable on $[a, b]$.
Note that the following converse is a bit difficult to prove.
(3) Let $f$ be bounded on $[a, b]$ and suppose that for every $\epsilon > 0$ there is a partition $\mathcal{P}$ of $[a, b]$ for which $$U(f, \mathcal{P}) - L(f, \mathcal{P}) < \epsilon$$ Then for every number $\epsilon > 0$ there is a number $\delta > 0$ such that for any partition $\mathcal{P}$ of $[a, b]$ with $||\mathcal{P}|| < \delta$ we have $$U(f, \mathcal{P}) - L(f, \mathcal{P}) < \epsilon$$
I did check the Pete Clark notes which you have linked in your post. The dicing lemma mentioned there is a slightly more general result than the result $(3)$ above and the proof is slightly more difficult so you may just use the simpler result I mentioned above and it is sufficient for our purpose here.
You can follow the proof in my blog post (taken from Tom Apostol's Mathematical Analysis). The basic idea is to choose a partition $\mathcal{P}_{\epsilon}$ such that $$U(f, \mathcal{P}_{\epsilon}) - L(f, \mathcal{P}_{\epsilon}) < \frac{\epsilon}{2}$$ and then let $N$ be number of points in partition $\mathcal{P}_{\epsilon}$. We can choose $\delta = \epsilon/(4KN)$ where $K = \sup\,\{|f(x)|\} + 1$. Now if $\mathcal{P}$ is any partition of $[a, b]$ with $||\mathcal{P}|| < \delta$ then we can split the expression $$\Delta(f, \mathcal{P}) = U(f, \mathcal{P}) - L(f, \mathcal{P}) = \sum_{i = 0}^{n}(M_{i} - m_{i})(x_{i} - x_{i - 1})$$ into two parts $S_{1}, S_{2}$ such that $S_{1}$ has the terms corresponding to the subintervals $[x_{i - 1}, x_{i}]$ which contain no points of the partition $\mathcal{P}_{\epsilon}$ and $S_{2}$ has terms corresponding to the remaining subintervals made by $\mathcal{P}$. Thus each subinterval in $S_1$ is contained in some subinterval created by $P_{\epsilon} $ and $S_2$ consists of remaining subintervals.
Clearly this will ensure that subintervals used in making $S_{1}$ are contained in subintervals made by partition $\mathcal{P}_{\epsilon}$. Hence we have $$S_{1} \leq U(f, \mathcal{P}_{\epsilon}) - L(f, \mathcal{P}_{\epsilon}) < \frac{\epsilon}{2}$$ For sum $S_{2}$ we can see that the subintervals used here do contain points of $\mathcal{P}_{\epsilon}$ and hence the number of such subintervals will not be greater than the number of points in $\mathcal{P}_{\epsilon}$. Also length of each subinterval is less than $\delta$. Thus we can see that $$S_{2} < 2K \cdot N \cdot \delta = \frac{\epsilon}{2}$$ Thus we have $$\Delta(f, \mathcal{P}) = U(f, \mathcal{P}) - L(f, \mathcal{P}) = \sum_{i = 0}^{n}(M_{i} - m_{i})(x_{i} - x_{i - 1}) = S_{1} + S_{2} < \epsilon$$
Update: Since the question has been updated I am adding some more details. We have to prove that
If $f$ is bounded on $[a, b]$ then $f$ is Riemann integrable on $[a, b]$ if and only if there for every $\epsilon > 0$ there is a number $\delta > 0$ such that if $\mathcal{P}$ is a partition of $[a, b]$ with $||\mathcal{P}|| < \delta$ then $$U(f, \mathcal{P}) - L(f, \mathcal{P}) < \epsilon$$
In view of statement $(1)$ in my answer this proposition is same as showing that the following two statements are equivalent:
(A) For every $\epsilon > 0$ there is a partition $\mathcal{P}$ of $[a, b]$ such that $$U(f, \mathcal{P}) - L(f, \mathcal{P}) < \epsilon$$
(B) For every $\epsilon > 0$ there is a $\delta > 0$ such that for any partition $\mathcal{P}$ with $||\mathcal{P}|| < \delta$ we have $$U(f, \mathcal{P}) - L(f, \mathcal{P}) < \epsilon$$
We need to show that both $(A)$ and $(B)$ are equivalent i.e. $(A) \Leftrightarrow (B)$. Proof of $(B)\Rightarrow (A)$ is given after statement $(2)$. Proof of $(A) \Rightarrow (B)$ is given after statement $(3)$.
  • Great answer, actually lot more clear than several sources. Just found out that my original proposition is an if and only if.. can you add to your answe r how to prove f is Riemann integrable given there exists $\delta$ such that.. – grayQuant Apr 28 '15 at 05:24
  • @grayQuant: you need to update your question with "if and only if". Then I will update my answer also so that things remain in sync. – Paramanand Singh Apr 28 '15 at 05:29
  • updated, thanks! – grayQuant Apr 28 '15 at 05:46
  • @grayQuant: I have updated my answer. Note that all the arguments are contained in the previous answer itself and I have pointed out arguments for "if" and "only if". – Paramanand Singh Apr 28 '15 at 07:36
  • It took me a while to see this message. Just a comment: the "Dicing Lemma" from my notes is a more general statement than your (3) above: it applies to any bounded function. Your (3) is what you need to show that Darboux Integrability implies Riemann Integrability. Now you may say that the staement of the Dicing Lemma is more complicated than necessary for that application....and I would agree with you. I found the stronger statement to be of some interest in itself though, and the proof is not so bad. – Pete L. Clark Apr 22 '17 at 13:50
  • @PeteL.Clark: Perhaps I have chosen my phrases a bit harsh. And yes I meant that your lemma is more than what is needed here and perhaps that led me to the conclusion that the proof itself is "convoluted". The right word would have been "difficult" and it is expected to be so because it proves a more general result. Will edit my post accordingly. – Paramanand Singh Apr 22 '17 at 14:24
  • @PeteL.Clark: It is a happy coincidence that I also established a result equivalent to dicing lemma and all the while I had forgotten about your notes. You can check this formulation in the answer https://math.stackexchange.com/a/2047959/72031 I agree with your statement that the result "is of some interest in itself". – Paramanand Singh Apr 22 '17 at 14:51
  • This is a minor point, but shouldn't the number of subintervals in $S_{2}$ not exceed $2N$ since a point of $\mathcal{P}_{\epsilon}$ may be a boundary point of two adjacent subintervals? – Karthik Kannan Apr 26 '21 at 11:51
  • @ParamanandSingh, if I understand correctly, the subintervals of $S_{1}$ don't contain points of $\mathcal{P}{\epsilon}$ according to the chosen convention. Two adjacent subintervals of $S{2}$ may contain a point of $\mathcal{P}_{\epsilon}$. – Karthik Kannan Apr 27 '21 at 01:30
  • @KarthikKannan: sorry for the previous comment (now deleted). The case you mention is possible. I think the key difference between $S_1$ and $S_2$ is each subinterval in $S_1$ is contained in ($\subseteq$) some subinterval generated by $P_{\epsilon} $ and $S_2$ consists of remaining subintervals. The argument in the answer then holds without changing $N$ into $2N$. I will update the answer to explicitly state this. – Paramanand Singh Apr 27 '21 at 01:57
  • @ParamanandSingh just to be sure, I believe the statement should be ''$S_1$ has the terms corresponding to the subintervals $[x_{i−1},x_i]$ which contain no points of the partition $\mathcal{P}_{\epsilon}$ in their interior''. I think the proof would then be correct without changing $N$ to $2N$. – Karthik Kannan Apr 27 '21 at 03:07
  • @ParamanandSingh can u plz look at here the question related to reimann integration. https://math.stackexchange.com/questions/4520874/which-equivalent-definition-used-in-below-theorem – Meet Patel Aug 29 '22 at 12:22
We have $0\leq R(f,P,\tau)-L(f,P)<U(f,P)-L(f,P)<\epsilon$ and because whis works for every epsilon, then we have that $R(f,P,\tau)=L(f,P)=\int_a^b f(x)dx.$
Im not sure if is this what you are asking for. If not, let me know.
HeMan
  • 3,119
