Using probability methods (characteristic function?) prove $$\prod_{i=1}^\infty\cos\left(\frac t{2^i}\right)=\frac{\sin t}t$$ I know what is characteristic function but I have no idea how use it in this task. I will grateful for help.
@GuyFsone: As far as I can tell, there's not a probabilistic method in that proposed duplicate. – Michael Seifert Feb 08 '18 at 17:58
Consider the following variable $$ Y=\sum_{j=1}^{\infty}X_j2^{-j} $$ where $X_i$'s are i.i.d. unbiased Bernoulli$\{-1,1\}$. The characteristic function of the right hand side turns out to be $$ \prod_{j=1}^{\infty}\cos(t2^{-j}) $$ On the other hand you can convince yourself that $Y$ is Uniform$(-1,1)$ (I am not doing this part of the proof, but you can think of Uniform measure as a ''uniform" binary expansion.) Then the characteristic function of $Y$ is $$ \int_{-1}^{1}\frac{e^{itx}}{2}dx=\frac{e^{it}-e^{-it}}{2it}=\frac{\sin (t)}{t} $$ and we are done.
- 1,395
For Bernoulli times $2^{-j}$, the characteristic function is $\phi(t) = 1/2(e^{it2^{-j}} + e^{-it2^{-j}}) = cos(t2^{-j})$ – gmath Dec 14 '14 at 20:19
Hint:
Let $b\in\mathbb{N}$, $b\ge2$, $Y=\{0,1,...,b-1\}$ with fair probabilities assigned, and let $F:Y^\infty\to[0,1]$ be the map defined by $$F(x_1,x_2,x_3,...)=\frac{x_1}b+\frac{x_2}{b^2}+\frac{x_3}{b^3}+..., \text{for all}~(x_1,x_2,x_3,...)\in Y^\infty;$$ that is, $F=\sum_{n=1}^\infty\frac1{b^n}f_n$ where $f_n=\sum_{k=1}^{b-1}k\chi_{A_{nk}}$ and $A_{nk}=Y\times...\times Y\times\{k\}\times Y^\infty$ with ${k}$ in the $n$th spot. If $\mu:\mathcal{S}(\mathscr{C})\to[0,1]$ is the infinite product measure, then
$A\in\mathscr{B}$ if and only if $F^{-1}(A)\in\mathcal{S}(\mathscr{C})$, in which case $\mu(F^{-1}(A))=\mathfrak{m}(A)$.
Use this result and show that $f:[0,1]\to\overline{\mathbb{R}}$ is Borel measurable if and only if $f\circ F:Y^\infty\to\overline{\mathbb{R}}$ is Borel measurable, and $$\int_{[0,1]}f(x)dx=\int_{Y^\infty}f\circ F~d\mu\tag{*}$$ provided $f$ is nonnegative or integrable; in particular, it holds when $f:[0,1]\to\mathbb{C}$ is integrable.
Fix $z\in\mathbb{C}$. Then applying (*) to the function $f(x)=e^{2zx}$, prove that $$e^z\frac{\sinh z}z=\lim_{N\to\infty}\int_{Y^\infty}\prod_{n=1}^N e^{2zf_n/b^n}d\mu$$
Write $\prod_{n=1}^N e^{2zf_n/b^n}=\prod_{n=1}^N\prod_{k=1}^{b-1}e^{2zk\chi_{A_{nk}}/b^n}$ as a simple function and use the formula to compute $\int_{Y^\infty}\prod_{n=1}^N e^{2zf_n/b^n}d\mu$. Deduce the very interesting formula $$e^z\frac{\sinh z}z=\prod_{n=1}^\infty\prod_{k=1}^{b-1}\left(1+\frac{2e^{kz/b^n}}b\sinh\left(\frac{kz}{b^n}\right)\right)$$
With $b=2$ and $z=it$, prove that $$\frac{\sin t}t=\prod_{n=1}^\infty\cos\left(\frac t{2^n}\right)$$
- 5,606
I don't know if it answers your question since I don't use characteristic function. By using $$ \sin(2\theta)=2\sin\theta\cos\theta $$ one has \begin{eqnarray} \prod_{i=1}^n\cos\left(\frac t{2^i}\right)&=&\cos\left(\frac t{2}\right)\cos\left(\frac t{2^2}\right)\cdots\cos\left(\frac t{2^{n-1}}\right)\cos\left(\frac t{2^n}\right)\\ &=&\frac{\cos\left(\frac t{2}\right)\cos\left(\frac t{2^2}\right)\cdots\cos\left(\frac t{2^{n-1}}\right)\cos\left(\frac t{2^n}\right)\sin\left(\frac t{2^n}\right)}{\sin\left(\frac t{2^n}\right)}\\ &=&\frac{\cos\left(\frac t{2}\right)\cos\left(\frac t{2^2}\right)\cdots\cos\left(\frac t{2^{n-1}}\right)2\cos\left(\frac t{2^n}\right)\sin\left(\frac t{2^n}\right)}{2\sin\left(\frac t{2^n}\right)}\\ &=&\frac{\cos\left(\frac t{2}\right)\cos\left(\frac t{2^2}\right)\cdots\cos\left(\frac t{2^{n-1}}\right)\sin\left(\frac t{2^{n-1}}\right)}{2\sin\left(\frac t{2^n}\right)} \end{eqnarray} and continue doing this, one has \begin{eqnarray} \prod_{i=1}^n\cos\left(\frac t{2^i}\right) &=&\cdots\\ &=&\frac{\cos\left(\frac t{2}\right)\sin\left(\frac t{2}\right)}{2^{n-1}\sin\left(\frac t{2^n}\right)} &=&\frac{\sin t}{2^{n}\sin\left(\frac t{2^n}\right)}. \end{eqnarray} Thus $$ \prod_{i=1}^\infty\cos\left(\frac t{2^i}\right)=\lim_{n\to\infty}\prod_{i=1}^n\cos\left(\frac t{2^i}\right)=\lim_{n\to\infty}\frac{\sin t}{2^{n}\sin\left(\frac t{2^n}\right)}=\frac{\sin t}{t}.$$
- 44,000
Maybe it would be useful if you explain how you managed the third equation. – Nathanael Skrepek Aug 14 '17 at 21:16
