68
What is the difference between a direct product and a semi-direct product in group theory?
Based on what I can find, difference seems only to be the nature of the groups involved, where a direct product can involve any two groups and the semi-direct product only allows a normal subgroup $N$ of some group $G$ and another subgroup of $G$ that intersects trivially with $N$.
Is this all? What are the significance? Thank you.
Andrews
  • 3,953
retro
  • 791
    You can define an "external" semidirect product that has as input two groups $G, H$ and a homomorphism $\phi : G \to \text{Aut}(H)$ ( http://en.wikipedia.org/wiki/Semidirect_product#Semidirect_products_and_group_homomorphisms ). It reduces to a direct product if $\phi$ is trivial, so direct products are a special case of semidirect products. – Qiaochu Yuan Feb 05 '12 at 17:20
    Direct product of Abelian groups ia always abelian while even semi direct product of cyclic groups need not be abelian. Is this significant enough? –  Feb 05 '12 at 17:21
    In the direct product of $H$ and $K$, elements $h \in H$ and $k \in K$ commute, so $kh = hk$. In the semidirect product, we have $kh = \varphi(h)k$ for some automorphism $\varphi$ of $h$. Thus, as Qiaochu mentioned, we need a homomorphism from $K$ into $Aut(H)$ in order to make this action make sense. If that homomorphism is trivial, we have $kh = \varphi(h)k = hk$ and therefore have the direct product. – Carl Feb 05 '12 at 18:16
  • @Carl: Thank you. Isn't the direct product of the form $(h,k)\in H\times K$ so that the $h$'s and $k$'s are separated? But then how can they commute? – retro Feb 05 '12 at 18:28
    @retro: Note that in $H\times K$, elements of the form $(h,1)$ and $(1,k)$ commute with each other. You identify $H$ with the subgroup $H\times 1 \le H \times K$, and similarly $K$ with $1 \times K$ and see that elements in those subgroups commute with elements in the other. Conversely, if you have a group written $G$ where each element is written uniquely in the form $hk$, and $hk = kh$, then $G\cong H \times K$ – Carl Feb 05 '12 at 18:47
  • @Carl: Thanks for the explanation. – retro Feb 05 '12 at 20:01
  • @QiaochuYuan: Thanks. – retro Feb 05 '12 at 20:01
  • @KannappanSampath: Yes, it is significant enough :) Thanks. – retro Feb 05 '12 at 20:02
Let's look at three related concepts, in increasing order of complexity:
  1. Direct products. We say that $G$ is (isomorphic to) a direct product of $M$ and $N$ if and only if there exist subgroups $H$ and $K$ of $G$ such that:
    • $H\cong M$ and $K\cong N$;
    • $H\triangleleft G$ and $K\triangleleft G$;
    • $H\cap K=\{e\}$;
    • $G=HK$.
  2. Semidirect products. We say that $G$ is (isomorphic to) a semidirect product of $M$ by $N$ if and only if there exist subgroups $H$ and $K$ of $G$ such that:
    • $H\triangleleft G$;
    • $H\cap K=\{e\}$;
    • $G=HK$.
  3. Extensions. We say that $G$ is (isomorphic to) an extension of $M$ by $N$ if and only if there exists a subgroup $H$ of $G$ such that
    • $H\cong M$;
    • $G/H\cong N$.
1 and 2 look very similar. In fact, 1 is a special case of 2 (when $K$ is normal); and 2 is a special case of 3: if $G=HK$, $H\triangleleft G$, and $H\cap K=\{e\}$, then $K$ maps isomorphically onto $G/H$ via the natural projection (the intersection with the kernel is trivial, so the projection restricted to $K$ is one-to-one; and every element of $G$ can be written as $x=hk$ with $h\in H$ and $k\in K$, so $Hx = Hk$, hence the map is onto when restricted to $K$).
But each one is a more general construction than the previous one, yielding more general types of groups.
For instance, in Direct Products, the conditions immediately imply that elements of $H$ commute with elements of $K$:
Lemma. Let $G$ be a group, and let $H$ and $K$ be normal subgroups of $G$. If $H\cap K=\{e\}$, then $hk=kh$ for all $h\in H$ and $k\in K$.
Proof. Consider $hkh^{-1}k^{-1}$. Since $K$ is normal in $G$, then $$hkh^{-1}k^{-1} = (hkh^{-1})k^{-1} \in (hKh^{-1})K = KK = K;$$ and since $H$ is normal in $G$, then $$hkh^{-1}k^{-1} = h(kh^{-1}k^{-1}) \in H(kHk^{-1}) = HH = H.$$ Therefore, $hkh^{-1}k^{-1}\in H\cap K = \{e\}$, so $hkh^{-1}k^{-1}=e$. Multiplying on the right by $kh$ gives $hk=kh$, as desired. $\Box$
So, for example, if all you know are direct abelian groups, then direct products will only give you abelian groups. If both $M$ and $N$ have exponent $k$, then direct products will give you a group of exponent $k$. (In fact, any identity satisfied by both $M$ and $N$ will be satisfied by $M\times N$; but this is perhaps a little advanced for you right now, so don't worry too much about it).
By contrast, semidirect products are more complicated, because that second subgroup doesn't have to be normal. The argument above is invalid, and we don't always get that elements of $H$ and elements of $K$ commute (if they do, then you have a direct product). The smallest example is $S_3$, the nonabelian group of order $6$ viewed as the permutations of $\{1,2,3\}$, with $M=C_3$, the cyclic group of order $3$, $N=C_2$, the cyclic group of order $2$, and $H=\{I, (1,2,3), (1,3,2)\}$, $K = \{I, (1,2)\}$ (other choices of $K$ are possible).
In a semidirect product, the fact that $H$ is normal means that for every $k\in K$ you have $kHk^{-1}=H$; that is, each $k$ induces an automorphism of $H$. So we can define a homomorphism $K\to \mathrm{Aut}(H)$, by letting $k$ map to the homomorphism $h\mapsto khk^{-1}$. If this map is trivial, you get the direct product of $H$ and $K$. If the map is not trivial, then you get more interesting groups. Different homomorphisms may lead to nonisomorphic groups, so that now we have to be careful: while there is one and only one way to construct a "direct product" of two groups $M$ and $N$, there may, in general, be many (non-equivalent) ways of constructing semidirect products of $M$ by $N$.
Note that it is now possible to have a semidirect product of abelian groups that is not abelian (as in the $S_3$ example). And it is no longer true that if both $M$ and $N$ are of exponent $k$, then a semidirect product will also have exponent $k$. For example, take $M=C_2\times C_2 = \{1,x\}\times\{1,x\}$, which is of exponent $2$, take $N=\{1,n\} = C_2$, also of exponent $2$, and let the nontrivial element of $N$ act on $M$ by the rule $n^{-1}(a,b)n = (b,a)$. Then $(x,1)n$ has order $4$: $$\begin{align*} \bigl((x,1)n\bigr)^2 = (x,1)n(x,1)n &= (x,1)(n^{-1}(x,1)n) = (x,1)(1,x) = (x,x)\\ \bigl((x,1)n\bigr)^3 = (x,x)(x,1)n &= (1,x)n\\ \bigl((x,1)n\bigr)^4 = (1,x)n(x,1)n &= (1,x)(n^{-1}(x,1)n) = (1,x)(1,x) = (1,1). \end{align*}$$
Extensions are even more complex: in essence, every finite group can be viewed as a sequence of extensions of simple groups (hence, in part, the interest in classifying all finite simple groups). Not every extension is a semidirect product (or a direct product). For example, $\mathbb{Z}_4$, the cyclic group of order $4$, is an extension of $\mathbb{Z}_2$ by $\mathbb{Z}_2$: the subgroup $H=\{\overline{0},\overline{2}\}$ is cyclic of order $2$ and normal, and the quotient $\mathbb{Z}_4/H$ is of order $2$, hence cyclic of order $2$. If it were a semidirect product of $\mathbb{Z}_2$ by $\mathbb{Z}_2$, then being abelian it would necessarily be a direct product, and so would have exponent $2$; so it cannot be written as a semidirect product.
As I mentioned, every group can be expressed as a sequence of extensions using simple groups. By the Jordan-Hölder Theorem, although the sequence is not unique, the precise simple groups that occur is (counting multiplicity).
The definitions look quite similar: we just drop the condition of normality for one factor when going from direct product to semidirect product; we just exchange "there is a subgroup isomorphic to $N$ that maps isomorphically onto the quotient" with "the quotient is isomorphic to $N$" in going from semidirect product to extension. But the consequences of these "little changes" is large. Much like the difference between "finite abelian group" and "finite group" looks very small (just a single line dropped), but the implications in our ability to classify/understand the objects in question are enormous.
Arturo Magidin
  • 398,050
    Wow! Thanks for the very detailed explanation!! – retro Feb 07 '12 at 05:33
  • @Arturo, Is there a general expression for the exponent of the semidirect product? – Omar Shehab Dec 15 '15 at 09:33
    Fantastic. Great... Thanks for this impressive answer... – MR_BD Oct 13 '16 at 07:48
  • Shouldn't $G$ be an extension of $N$ by $M$ in 3? – user92156 Dec 11 '16 at 18:07
  • @user92156: see http://math.stackexchange.com/questions/64573/history-of-the-vocabulary-for-group-extensions/64580#64580 – Arturo Magidin Dec 11 '16 at 23:33
  • It would help to include how they're denoted in your definitions. – Shaun Aug 11 '17 at 11:08
    @Shaun: Sorry, but what are you talking about? I do say what I mean; I'm including the definition of "extension of $M$ by $N$" as I use the term. So what exactly is it you want me to include beyond exactly the definition I am using? – Arturo Magidin Aug 11 '17 at 17:40
  • @ArturoMagidin No, I mean perhaps you could include some standard notation, like $\times$ for the direct product. – Shaun Aug 11 '17 at 17:43
    @Shaun: The standard notation is for external constructions (external direct product, external semidirect product), not for internal ones; and extensions have no standard notation. – Arturo Magidin Aug 11 '17 at 17:48
  • @ArturoMagidin Where do internal direct products fit into your definitions? Are they included in direct products (first definition)? – Junglemath Apr 24 '19 at 10:56
    @Junglemath: The definition given under "direct products" is the definition of an internal direct product of $H$ and $K$. The distinction is, ultimately, utterly useless. Internal direct products and external direct products are naturally isomorphic. – Arturo Magidin Apr 24 '19 at 15:12
  • @ArturoMagidin: By assumptions in 1 of your answer, does $G=HK$ isomorphic to $K\times H$? – C.F.G Apr 30 '20 at 20:43
  • @C.F.G. Of course; because $H\cong M$ and $K\cong N$, so $H\times K\cong M\times N$. – Arturo Magidin Apr 30 '20 at 20:44
  • What do you mean, G=HK? Is it 'for all $h\in H$ and $k \in K$, $h k $ produces all G?' or is it 'for all $h\in H$ and $k \in K$, $h k$ AND $k h$ produce all G?' – Mondo Duke Oct 12 '21 at 19:38
  • @MondoDuke: Exactly what it says: that the group $G$ is equal to the set $HK={hk\mid h\in H,k\in K}$. What is unclear about that? Neither of the things you write makes any sense whatsoever: they are both utterly nonsensical. – Arturo Magidin Oct 12 '21 at 19:42
    @ArturoMagidin does that imply that if H and N form a semidirect product, then N and H form one too (in the same order)? Also I think you answered all I needed to know with that comment, thanks. Sorry for being nonsensical. But you do realize that G=HK is a complete shorthand, and its not obvious that the definition with a set you gave is the one used, right? – Mondo Duke Oct 12 '21 at 19:44
  • @MondoDuke: The definition has four parts. To talk about the semidirect product of $H$ by $K$, you need $H$ to be a normal subgroup and $K$ to be a subgroup. To talk about the semidirect product of $K$ by $H$ you need $K$ to be a normal subgroup and $H$ to be a subgroup. Why would that imply that if you can form the semidirect product of $H$ by $K$, then you can also form the semidirect product of $K$ by $H$? Why do you think you can just ignore a condition (normal subgroup)? – Arturo Magidin Oct 12 '21 at 20:10
  • @MondoDuke: "But you do realize that $G=HK$ is a complete shorthand and its[sic] not obvious that the definition with a set you gave is the one used, right?" No, wrong. It is standard notation. If you don't know it, then it's because you don't know standard notation, not because it is not obvious. And even if you don't know standard notation, what you wrote was utter nonsense, and that has nothing to with notation; it has to do with what the words mean. – Arturo Magidin Oct 12 '21 at 20:11
