I recently bought a very wideband SDR receiver (DX-Patrol MK4, declared covered frequencies are 100kHz-2GHz). I'm experimenting with antenna designs because unfortunately I live in an apartment building in the middle of the city and is not exactly an optimal spot for radio reception.
So far I got decent results on the VHF side with a small loop (around 1m diameter), a simple 1:1 balun (wire wrapped around a ferrite ring) and about 2m coax feedline. Since somebody asked: I have a feedline because I have access to a balcony. I thought having the loop outside and having some feedline is better than inside with no feedline.
So, assuming that:
  1. There is no way I can get the whole bandwidth with the same antenna, so I can set for two separate antennas if the need arises
  2. Because of 1. I want to keep the antenna as broadband as possible
  3. Optional: the antenna can be somewhat portable
My questions are:
  1. Is the loop (active or not) a good solution also for the 100kHz-20MHz range or should I set for another design?
  2. How can I improve the signal/noise ratio of my current loop (I already shielded the DX-Patrol with aluminium and I suppose ferrite beads along the feedline and USB cable would also help)? Would an additional amplifier help (the SDR has already an internal LNA)?
EDIT: thanks everybody for the answers! Lots to digest but I will try to keep up.
Luca
  • 329
    You sure are right about point 1. With the wideband capability of those receivers you will want specific antennas to focus on specific frequency ranges, even if the signal is very close to you. – SDsolar Jul 26 '17 at 17:36
  • Nice seeing you here, Luca! Hope I can explain @SDsolar's comment and your questions in my answer :) – Marcus Müller Jul 26 '17 at 19:28
  • @MarcusMüller you are stalking me! :) – Luca Jul 27 '17 at 10:12
  • @Luca not really, but it's good to see you around :) Anyway, I think "Feedback on these 4 antennas" would honestly warrant a separate question, as it will attract another kind of potential answerers, and also, isn't too closely related to your original question (makes sense to refer to it, but not inherently directly the same question). – Marcus Müller Jul 27 '17 at 18:39
  • @MarcusMüller fair enough. I branched it to https://ham.stackexchange.com/questions/8965/discussion-on-wideband-antenna-designs-available-online – Luca Jul 27 '17 at 19:49
Adressing your two questions first:
fractional bandwidth of antennas
Woah! 20 MHz is 200 times the frequency of 100 kHz. No, a loop antenna won't have that amount of bandwidth.
For antennas, we measure the bandwidth in multiples of the center frequency. For example, an antenna working well from 2.3 GHz to 2.5 GHz has a bandwidth of 200 MHz, with a center frequency of 2.4 GHz – that's a fractional bandwidth of $\frac{200\,\text{MHz}}{2400\,\text{MHz}} = \frac1{12}$.
wideband antennas
We tend to call antennas "wideband" as soon as their fractional bandwidth reaches $\frac15$. Really impressive wideband antennas reach fractional bandwidths of $\frac{11}{10}$ (UWB antennas) – and those really don't have the efficiency of an antenna you'd want to work with (aside from being very very costly to make).
Now, what you demand of your antenna if it has to cover 100 kHz to 20 MHz is that it has a fractional bandwidth of $\frac{19900\,\text{kHz}}{10050\,\text{kHz}}\approx 1.98$. Such antennas have not yet been invented, to my knowledge!
loop antennas
Now, a loop antenna especially has what we call high Q – it is narrowband, rather than wideband. That has a lot of advantages; for example, it can be relatively small compared¹ to the wavelength $\lambda$, and it doesn't pick up noise or interference from frequencies that you don't care about – that's primarily important to keep your first amplifier stage from becoming non-linear.
Quite luckily, you don't have to buy an infinite number of antennas – many antenna types can be tuned to a specific frequency. Downside of tuning is that it happens mechanically – e.g. by adjusting a variable capacitor – but it works. Still, this means that the 1 MHz from 100 kHz to 1100 kHz is much harder than the 100 MHz between 1 GHz and 1.1 GHz!
practice
So, most often, you'd encounter a set of antennas, working on different, usually separated, bands, instead of one antenna that tries to receive all these bands and the spectrum in between.
to amplify or not to amplify, that is the question
Gut feeling: If your receiver already has an LNA, you'd need to invest relatively much money to get an LNA with a better noise figure, so, no, that's usually not the way to go, unless your signal is below the sensitivity of your receiver, even without its input amplifier.
sensitivity, or: the magic of oversampling
Now, with SDR, defining sensitivity is a bit challenging – after all, the receiver is not only the thing doing the RF reception, the mixing, and the analog to digital conversion, the actual extraction of the signal of interest from the received signal (for example, the FM-modulated voice, or the PSK31 data) happens in software. The trick usually employed by SDR receivers is oversampling, which means that you have a signal of a given bandwidth $b$, but you sample it with a multiple of that, let's say $f_s = n\cdot b$. Then, through digital signal processing, namely filtering and decimation by $n$, you can get an SNR increase by $n$ (only applies to white noise)².
Example
I don't know the MK4, but I think it's based on an RTL2832. That chip will happily give you (I think) up to 3.2 million samples per second, $f_s=3.2\,\frac{\text{MS}}{\text s}$.
Now, let's say you want to hear a CW/morse station whose bandwidth you can limit to let's say $b=1\,\text{kHz}$; therefore, our $n= \frac{f_s}{b}= 3200$; assuming perfect filtering (we can't, really, make that assumption without a bit of mathematical justification, but bear with me for the time being), that's an SNR win of $3200\approx 35\,\text{dB}$. Now, assume your actual morse decoder (might be your ear) needs an SNR of $6\,\text{dB}$ – then you can still work with an input SNR of $-29\,\text{dB}$ That's nearly thousand times the signal energy in noise!
We can see that in action every time we activate our GPS receivers: The GPS signal reaching earth is really weak – in fact, it's weaker than the thermal noise in any non-cryogenically-cooled receiver. But: due to the high processing gain (correlation) of GPS receivers, that's no problem.
advantages of SDR and their limits
Also note that it's digitally trivial to select any 1 kHz from your sampled bandwidth – building an analog filter that could do the same would be terribly complicated, and that filter would be much worse in all relevant aspects (suppression, steepness, loss)!
Basically, that's why we rather do high-sampling-rate SDR than analog narrowband receivers these days. As hinted at above, this hits limits when the RX chains becomes nonlinear (meaning that the amplified signal amplitude at every time instant isn't really the same factor times the input signal amplitude), because then you get intermodulation. This can happen, for example, if you put your receiver to maximum gain (to receive a weak signal), but your antenna also picks up a strong signal, which isn't filtered out before it reaches the amplifiers. The amplifier does its best, but it can only scream so loud, and suddenly, things that aren't actually there "on the air" get mixed into the signal of interest. But: that can often be countered with relatively relaxed analog bandpass filters (or bandstop filters, to suppress known narrowband interferers) and gain limitation.
Since frequency-selective antennas basically are bandpass filters, that explains SDSolar's comment:
Since your SDR receiver can receive such a huge swath of spectrum (100 kHz to 2 GHz), it's impossible it has a narrow bandselection filter in front of the LNA³, thus it's likely that an interferer much stronger than your signal of interest will get picked up by your receiver. If that interferer is sufficiently strong to bring your receiver into nonlinearity, you get problems. Notice that the spurious free range of LNAs is often not that small – but I haven't tested the MK4 myself, and I generally have learned not to trust marketing brochures and manuals, so I can't say at which interferer power that will happen. But: the LNA will definitely be much nicer to your signal than the RTL2832-integrated amplifiers, so do try to keep the LNA active (and if it has adjustable gain, as close as possible to maximum), and use the gain of the RTL only to make the signal "fit" the whole ADC range. You'll probably notice when you're overdriving any amplifier in the chain – you'll see "ghost" frequencies becoming stronger faster than the real-world signals.
¹: $\lambda(f) = \frac{c_0}{f}\implies \lambda(100\,\text{kHz}) \approx \frac{3\cdot10^8\,\frac{\text m}{\text s}}{10^5\,\text{s}^{-1}}= 3\cdot10^{3}\,\text m=3\,\text{km}$, by all means, that's HUGE!
²: Beinaymé formula
³: In fact Dynamic Range-optimized special-purpose SDRs (e.g. for localization) do have exactly that, a bank of band-selection filters, but that's really expensive; good filters are actually what makes things like professional wideband measurement equipment so freaking expensive.
Marcus Müller
  • 15,910
  • 23
  • 45
  • Heh, heh. That would sure pick up a lot of noise. I no longer own a Dentron Super Tuner, either. I think you just proved the point that resonant antennas are best. – SDsolar Jul 26 '17 at 23:52
  • Woah! Lots to digest but thanks a lot for the answer. Yes the DX-patrol is aslo based on the RTL28xx chip. Regarding sampling I can comfortably keep it at around 1-2 Mbps but higher tends to ruin signals (my PC isn't exactly the cutting edge). I messed around with the gain settings. The autogain is complete rubbish and, as you said, I keep it manual on the border before getting the "ghost" signals. The RTL also generally only makes the noise floor higher without any real advantage. – Luca Jul 27 '17 at 10:03
    @SDsolar not quite! In practice, I very rarely see nonlinearities actually becoming a problem. It's a problem that seems to be very stressful to the ham community, from what I gather from talks at conventions, but for comm engineers, it's not really all that present – think about it, if the deafining effects were so strong, you couldn't be using multiband antennas in phones. So, believe me, a high antenna selectivity is really not necessary with modern receivers. But of course, if you need to maximize SNR, you take all the filtering effects you can get. – Marcus Müller Jul 27 '17 at 12:41
When I was investigating antenna geometries for 2.4 GHz, looking for extremely wideband antennas that wouldn't need tuning, I came across (article) a very simple wideband antenna. Picture two discs (pizza pans?) as elements of a dipole. One connected to the coax shield and the other connected to the center conductor; this is NOT the antenna I was simulating, but it is a similar one:
PCB antenna
In simulation using XfDTD it worked out quite well, and was very resistant to detuning by nearby metal surfaces. "nearby" of course being relative to wavelength.
At 2.4 GHz I was only looking for a fraction of the bandwidth you are, but I suspect you could experiment with this and have some fun.
Marcus Müller
  • 15,910
  • 23
  • 45
user103218
  • 319
  • Where's the connection between center conductor and disk? Does this maybe look like a mickey mouse, a bit? (my real question is: this sounds interesting, would you mind making a quick & dirty drawing, and upload it? Or a photo(I'd actually prefer the drawing) (maybe both)? (if you can't add images to your answer yet, just upload to imgur.com and add the link to your answer)) – Marcus Müller Jul 26 '17 at 19:31
  • Here's a link: https://turbofuture.com/misc/How-to-Build-Your-Own-Planar-Disk-Antenna – user103218 Jul 26 '17 at 21:32
    took the freedom to integrate one of the pictures from the article and a link to the article into your answer. Ha, WA5VJB is Kent :) he's known for his PCB antenna, and professional radio companies sell his antennas as accessories to their SDRs (though that afaik only applies to his logper, not to his vivaldi and dual-constant-curvature aperture (double-circle) antennas)! – Marcus Müller Jul 26 '17 at 21:42
    Nice :) this is really what I was expecting. The trick basically is that the "gap" between the two circular "dipole elements" allows for waves at a whole range of different wavelengths to "become free" from the conductor, whilst the circular shape at least partially restores matching to the feedline impedance :) This is pretty similar to how Vivaldi antennas work (of which you can see some examples in the article you've linked to, bottom image, the five similar antennas on the right of the photo, or on his website) – Marcus Müller Jul 26 '17 at 21:49
  • This is interesting. In simulation using XfDTD it worked out quite well, ... Do you have any data or charts you can share here? Also, since this is a balanced antenna, feeding it with anything but parallel line will cause the feedline to both radiate and pick up signals and noise. – Mike Waters Jul 26 '17 at 22:10
  • That's pretty cool, Markus. When I see really wide conductors I always think of increased bandwidth, but this takes it to a whole new level. – SDsolar Jul 26 '17 at 23:16
  • Is there any "cookbook" indication on the size of the discs and the space between them to get a specific band? I assume that this design would be also quite impractical at LF range where I would probably need a moon-sized disc (actually two) – Luca Jul 27 '17 at 09:55
  • @Luca yes – the article that is linked here doesn't mention it for some reason (it's actually pretty close to plagiarism) that the original article describing these antennas was also written by Kent and is available online. But yes, disk diameter is $\frac\lambda4$ of lowest frequency. – Marcus Müller Jul 27 '17 at 12:36
  • The design was proprietary, and all the info is back on the computer for the company I was working for. A balun might be better, but the simulation I was running was single ended feed, and essentially zero feedline length. YMMV Etc. At LF this would be a highly impractical antenna! :) I would consider it for probably 100 MHz and up though. – user103218 Jul 27 '17 at 14:57
I'm assuming that you're space-constrained and entirely indoors — if that's not correct, please update your question with more details.
First, the simplest thing: you talk about feed line, ferrite beads, LNAs. The simplest effective thing to do is skip the feed line and connect your receiver directly to the antenna feed point, or with as short a piece of coax as you can acquire (and use an active USB extension cable if you need one to make it reach). This minimizes loss and prevents feedline radiation/reception because there isn't any.
You also don't need an amplifier that way unless the signals you're looking for are weak compared to the inherent noise floor of your receiver. Amplifiers are always a last resort because they add noise.
Ferrites on the USB cable may be useful to prevent noise from the computer from reaching the receiver, but:
  • Try different computers (or e.g. an Android phone if you have one) to check if your chosen computer is particularly noisy, and use a different one for the purpose if so.
  • If you do use ferrites, it is a much more efficient use of ferrite material if the hole is large enough to pass the cable through multiple times; the suppression increases with turns squared (to a point), whereas multiple beads strung on the cable are merely linear in dB.
As to designing suitable antennas: having an antenna of the proper configuration makes a big difference. Trying to make a broadband LF-HF antenna that's also very small just doesn't work very well.
What I recommend you do is acquire a generous supply of insulated stranded wire and mess around with antenna configurations — see what works for you in your environment. Watch the SDR waterfall as you experiment. and remember that more signal is better whether it's a wanted signal or if it's atmospheric noise. (On the other hand, for specific interference sources that you can identify, it's reasonable to try to fiddle your antenna to null them out.)
One design I'd suggest you try is to string a wire in a loop around your apartment's ceiling — as much open area as you can find, even if it ends up with all sorts of bends around corners.
Also, buy or build a simple cheap manual antenna tuner (I got the MFJ-902B) and use it to play with matching at the feed point. This is something you have to adjust for different frequencies, but a tuner can make a significant difference for receiving when you're using a badly-chosen-for-the-band antenna.
Kevin Reid AG6YO
  • 24,506
  • 51
  • 103
  • Ditto. I have a little MFJ-971 and you can always find some combination of settings that will help. Even if all you do at first is tune it for loudest "noise" – SDsolar Jul 26 '17 at 23:18
    "suppression increases with turns squared" this is only true until the arrangement's self-resonant frequency moves below the target suppression frequency. – Phil Frost - W8II Jul 27 '17 at 00:58
    Are the antenna tuners essentially different tank circuits that you can choose from depending on the band you need? I have two old air variable capacitors laying around, making coils for LW will get extremely frustrating but would be doable. How does the antenna matching work? – Luca Jul 27 '17 at 10:10
  • "antenna matching" is really just reactance cancellation. Radios want an antenna that presents as a purely resistive load because the capacitance and inductance are balanced out. That's good for the transceiver yet may not be best for capturing signals. The ideal antenna, however, is truly resonant on the frequency of interest, But often "good enough" is good enough. Tuners are great for utilizing a 75-meter phone antenna on the 80-meter CW band, no doubt. It gets a little dicier when trying to use a 40-meter antenna on the 15-meter band. – SDsolar Aug 10 '17 at 09:38
  • One thing people do with mobile antennas is to use a 9-foot CB whip with a large loading coil at the bottom to provide inductance that can bring it to near resonance. However, coils don't radiate the same so you lose a lot of signal strength. If you took that same design upside down (the coil on top) you are more likely to make it work better. AM broadcast antennas have the same problem. They rarely resonant (as in, I have never seen one that didn't require a matching network). And the network is right next to the transmitter, soaking up power that never gets put out to the listeners. – SDsolar Aug 10 '17 at 09:42
  • @Luca, that is a very good question. And yes, lots of people like to build their own tuners. My little one has a much narrower range than the Dentron Super Tuner I let go years ago. Wikipedia has a fairly decent article on antenna tuners. Many difference in designs. Here is a link to the article, pointing to the losses section and the next paragraph that talks about where they can be located in the antenna system. You might find it interesting to skim the whole article and see if it answers your question: https://en.wikipedia.org/wiki/Antenna_tuner#Loss_in_Antenna_tuners – SDsolar Aug 10 '17 at 09:50
  • @SDsolar Please don't write answers in comments. If it deserves three comments' worth of text, it deserves to be a post of its own — you could even post the question quoting Luca. – Kevin Reid AG6YO Aug 10 '17 at 14:51
  • I get your point, @Kevin. I did get a bit long-winded responding to the previous comments. None of it was responsive to the OP question, so would have been better off written in chat. – SDsolar Aug 10 '17 at 20:32
