I have a commercially manufactured ground plane antenna for 2 meters. It will be fed with about 150 feet of RG 8/U . I've seen pictures of a coil of the feed line going to a 2 meter ground plane; this is used as a balun.
I'm wondering if anyone can give me the suggested number of turns and diameter of the coax coil?
Phil Frost - W8II
  • 51,701
  • 88
  • 212
timbo20
Having a 50Ω unbalanced output radio feeding a 50Ω unbalanced ground plane antenna through a 50Ω unbalanced coax feeder, there is nothing more you would need to do other than raise the antenna height for improved performance.
vu2nan
  • 757
Attempting to make a balun by coiling coax is a tricky business.
The idea with these baluns is to make an inductor with the coil. Because an inductor has an impedance that increases with frequency, it's hoped they will look like a high impedance to common-mode currents on the coax.
Unfortunately, a real coil also has capacitance between the turns which counters this effect.
Furthermore, this approach does not take into account the common-mode impedance of the feedline, which could take all kinds of values depending on the length and placement of the feedline. Adding a reactive impedance in series with this unknown impedance might actually make things worse by creating a resonant LC circuit with a lower impedance at the operating frequency.
As such, I would first recommend you do nothing. The ground plane already presents a low impedance to the common mode. If the feedline exits below the ground plane and away from the antenna, common mode current on the feedline should be low without taking any particular action.
After installing the antenna, you can measure the common-mode current. See How to detect common-mode currents or “RF in the shack”?
If then you still have issues, you can try adding a balun. And because you have a mechanism for measuring the common mode current, you can find the ideal number of turns by trial and error. If you can't get that to work sufficiently well, you can try other balun designs which may be more suited to VHF.
Phil Frost - W8II
  • 51,701
  • 88
  • 212
