I have fragment of code that has to rotate the camera to the direction where my cursor is as below:
float yaw = mouseSensitivity.x * Input.GetAxis("Mouse X"); float pitch = mouseSensitivity.y * -Input.GetAxis("Mouse Y"); Vector3 camRotDir = new Vector3(pitch, yaw, 0); // this works Vector3 camRot = mPlayerCamera.transform.rotation.eulerAngles + camRotDir; mPlayerCamera.transform.rotation = Quaternion.Euler(camRot); // this doesn't work //var rotation = Quaternion.Euler(camRotDir); //mPlayerCamera.transform.rotation = mPlayerCamera.transform.rotation * rotation;
WithmouseSensitivity
being an arbitrary Vector2
value representing mouse's sensitivity respectively on axis X and Y.
The problem is when I convert the current camera's rotation in Quaternion
to Euler angle
, add the camRotDir
to it and then convert the result back to Quaternion
, it works properly, the z
component in camera's rotation remains unchanged during this process. But when I first convert the camRotDir
to Quaternion
and add it to camera's current rotation by multiplying them together, I get unexpected behaviour, the z
component was somehow changed.
I have no idea why this happens, should Quaterion of (euler_a + euler_b)
== (Quaternion of euler_a) * (Quaternion of euler_b)
Code run in Unity 2018.3.12f1.
