Given:
  • An arbitrary circular cylinder (defined by startpoint, endpoint, and radius). An Infinite cylinder is acceptable as well, as long as it passes through those points and has the same radius.
  • An axis-aligned box (defined by its minimum and maximum point)
  • The box being completely inside the volume of the cylinder should also count as an intersection
To test if the cylinder and the box intersect.
Does such a test exist?
EDIT: I found this on the mathmatics stack exchange, though at the moment I do not follow it. If there is an example of it in code form that would be fantastic.
Tyler Shellberg
  • 203
  • The key observation from the mathematics stack exchange link is that, if the two touch, either the center of the (infinite) cylinder goes through the box or an edge of the box intersects the cylinder. Does that help? –  Feb 25 '20 at 17:19
  • @DanielMGessel Well the center is easy, I already have a ray-box intersection test. The edge of the box I'm not sure. I could manually calculate all the startpoint/endpoints of the box's edges, but then I guess I would be looking for a line-segement and cylidner intersection test? – Tyler Shellberg Feb 25 '20 at 17:24
  • Yes, I was thinking a line segment vs cylinder intersection test too. When you do the math, you might find each of the 4 parallel lines along one axis, with the same extent, share/simplify computation. On the other hand, I also think a bounded cylinder is a little more challenging. –  Feb 25 '20 at 17:33
  • To be honest, the fact that the cylinder is bounded is not a requirement. Infinite works too! I should specify that in the question. I thought bounded would be easier. – Tyler Shellberg Feb 25 '20 at 17:35
  • @DanielMGessel What about the case where the box is much smaller than the radius of the cylinder and is inside it. It could not intersect with the lines of the box, while the center would miss the box as well. – Tyler Shellberg Feb 25 '20 at 20:45
  • @TylerShelberg Think of clipping the box edges to the volume of the cylinder then checking to see if anything is left, instead of seeing if the edges intersect the surface of the cylinder. –  Feb 25 '20 at 21:36
  • What do you mean by "clipping the box edges to the volume of the cylinder"? I don't follow. – Tyler Shellberg Feb 25 '20 at 21:39
As mentioned the problem of cylinder box intersection reduces to the problem of line-parallelogram intersection, and line segment-cylinder intersection.
I will assume that you know how to intersect a line and a parallelogram. Here is a sketch for solving the line segment-cylinder intersection:
The canonical equation of an elliptic cylinder aligned with the $Z$ axis and having center $(c_x, c_y, c_z)$ is given as: $$\frac{(x-c_x)^2}{a^2} + \frac{(y-c_y)^2}{b^2} = 1$$ The parametric form of a ray is given as: $$\vec{r}(t) = \vec{o} + t\vec{d}$$ Then by plugging r into the canonical equation one gets: $$\frac{(o_x + td_x -c_x)^2}{a^2} + \frac{(o_y + td_y -c_y)^2}{b^2} = 1$$ Solve the quadratic equation for $t$ and you have your intersection. If the discriminant is negative then there is no intersection. To get a rotated cylinder, the easiest way is to apply the inverse rotation to the ray (the equation may be modified however too). Note that for a line segment, you simply need to check whether $t \in [t_0, t_1]$, where $\vec{a} = \vec{o} + t_0\vec{d}$ is the first point of the line segment, and $\vec{b} = \vec{o} + t_1\vec{d}$ is the second one.
EDIT: To clarify you further questions in the comments:
1) a,b in the denominator are the radii along the $X$ and $Y$ axes respectively. In the trivial case where $a=b=r$ we have the canonical equation for a circular cylinder: $$(x-c_x)^2 + (y-c_y)^2 = r^2$$
2) For the intersection between the cylinder axis and the box a rotation is only required if your box is OOBB and you want to use your AABB intersection code.
3) The solution of the quadratic equation is trivial (note, I renamed $a,b$ to $r_1,r_2$ to further emphasize that they are the radii):
$$\frac{(o_x + td_x -c_x)^2}{r_1^2} + \frac{(o_y + td_y -c_y)^2}{r_2^2} = 1$$ $$r_2^2(o_x + td_x - c_x)^2 + r_1^2(o_y + td_y -c_y)^2 = r_1^2r_2^2$$ $$(r_2^2d_x^2+r_1^2d_y^2)t^2 - 2(r_2^2d_x(c_x-o_x) + r_1^2d_y(c_y-o_y))t + r_2^2(c_x-o_x)^2 + r_1^2(c_y-o_y)^2 - r_1^2r_2^2 = 0$$
Let us substitute: $$A = (r_2^2d_x^2+r_1^2d_y^2)$$ $$B = (r_2^2d_x(c_x-o_x) + r_1^2d_y(c_y-o_y))$$ $$C = r_2^2(c_x-o_x)^2 + r_1^2(c_y-o_y)^2 - r_1^2r_2^2$$
Then you have the quadratic equation:
$$At^2 -2Bt + C = 0$$ $$D = B^2-AC$$
If $D<0$ there is no intersection between the ray $\vec{o}+t\vec{d}$ and the cylinder, otherwise:
$$t_1 = \frac{B-\sqrt{D}}{A}, t_2 = \frac{B+\sqrt{D}}{A},$$
give you the two intersections (it is one intersection if $D=0$).
Now let your segment vertices be $\vec{v}_a = \vec{o}+t_a\vec{d}$ and $\vec{v}_b = \vec{o} + t_b\vec{d}$. If $t_a \leq t_1 \leq t_b$ then you have an intersection at $t_1$, if $t_a \leq t_2 \leq t_b$ then you have an intersection at $t_2$, otherwise there is not intersection.
lightxbulb
  • 2,226
  • Sorry for the late reply. How does this boil down to a line-parallelogram intersection, again? Is the parallelogram the profile of the box from the perspective of the cylinder? Does this mean the steps boil down to: 1: Rotate cylinder to the Z axis (somehow) 2: Apply same rotation to the box (somehow) 3: Use the X and Y positions of the box after rotation to get the line segments that make it up. 4: Convert them into parametric form? 5: Plug into the equation, solve for T 6: T >= 0, intersection. Otherwise, false. Does that sound about right? Never worked with parametrics before. – Tyler Shellberg Feb 27 '20 at 20:46
  • If the cylinder is a circular one, a and b become the radius, right? – Tyler Shellberg Feb 27 '20 at 21:01
  • I think I must be wrong about some of those steps. Read over what you wrote again. I don't follow a few things. What rotation are we getting the inverse of? The rotation of the ray? So we rotate the box first...and then the cylinder after? Why the inverse of the rotation? Is there some way to boil this down to a line segment and circle intersection test or is there a reason that doesn't work? I feel very lost. And I think any of this rotation stuff will require quaternions and converting to-from them as well. – Tyler Shellberg Feb 27 '20 at 21:34
  • The parallelogram was for testing the central axis of the cylinder vs box faces, but you could also rotate the coord system and just do ray-AABB intersection in that case. As for the radii for circular cylinder, $a=b=r$, yes. If the cylinder is not aligned to the Z axis, it can be transformed to such through a rotation matrix $R$. Then apply this to your rays before intersecting with the Z aligned cylinder. – lightxbulb Feb 27 '20 at 21:56
  • Why rotate the coordinate system to test for intersection between the center of the cylinder and the box? Wouldn't just doing a normal ray-box intersection work for that? – Tyler Shellberg Feb 27 '20 at 21:58
  • And, do the steps I outlined seem right? Is there something I am missing there? It seems like solving that equation for T is not trivial, not sure how to even approach that. – Tyler Shellberg Feb 27 '20 at 22:00
  • I used Wolfram to solve it, that's a monstrosity. I could maybe put it into code but I'm not even sure if that's really how I should be going about this. – Tyler Shellberg Feb 27 '20 at 22:33
  • Some pseudocode, or even just some of the steps and sub-steps in an ordered list would be an enormous help. – Tyler Shellberg Feb 27 '20 at 22:35
    @TylerShellberg I edited the post to include the segment-cylinder intersection details. Note that if the cylinder is not aligned with the $Z$ axis, you need to find the rotation $R$ that transforms the $Z$ aligned cylinder to yours. Then use that rotation on the edges of your AABB to get the line segments ($\vec{o} = R\vec{o}'$, $\vec{d}=R\vec{d}'$). – lightxbulb Feb 28 '20 at 19:36
  • I asked this from another commenter, but what happens if the box is entirely within the volume of the cylinder, but doesn't touch the center of it either? In that case, in 2D, the parallelogram would be inside the circle, but there would be no interesections. Does this method handle that? Also, if the cylinder is infinite and is along the Z axis, how is there a "center" point? Do we just call it (0,0,0)? – Tyler Shellberg Feb 28 '20 at 20:28
  • I think I have found a much simpler solution, which I have added to the OP. I will let you know how that progresses. – Tyler Shellberg Feb 28 '20 at 20:52
  • This checks for intersections between the surfaces, and not the volumes, so no, it will not work. Also your solution has a number of fail cases. – lightxbulb Feb 28 '20 at 21:37
  • I am looking for intersection between volumes, not surfaces. I guess I should have made that more clear in the OP, though I did specify that the box being completely inside the cylinder should count. In what cases would it fail? – Tyler Shellberg Feb 28 '20 at 21:43
  • For what it's worth, I'm sorry that you ended up spending a lot of time on a solution that wasn't what I was looking for. Regardless, I appreciate your time and thoroughness. Thank you. – Tyler Shellberg Feb 28 '20 at 23:27
  • @lightxbulb For a cylinder of finite length, it could happen that the cylinder axis does not intersect the cube, but one of the caps passes through a face of the cube, so I don't see how it's enough to just check just for segment-cylinder intersections. It could also happen that the cylinder axis does not intersect the cube, but because of a significantly larger radius than the cube size, the cube is fully contained inside the cylinder. – Jake1234 Sep 05 '21 at 12:29
  • @Jake1234 My derivations hold for an infinite cylinder without caps. To make the cylinder finite, one would also need to check that $c_z$ is also within some interval. To add caps one would also need to check for elliptical disk vs parallelogram intersections. – lightxbulb Sep 05 '21 at 12:59
"Intersection of Box and Finite Cylinder", David Eberly, Geometric Tools, Redmond WA 98052
Catriel
  • 101
I ended up finding a fairly simple, fairly performant solution.
1: Create a transformation matrix that rotates the cylinder to one of the axis (x, y or z)
(That part is non-trivial)
2: Apply the transformation matrix to the cylinder
3: Apply the transformation matrix to the eight corners of the axis-aligned bounding box.
(Applying a transformation matrix is not too hard, it looks like this:)
newPoint[0] = (original[0] * xform[0][0]) + (original[1] * xform[1][0]) + (original[2] * xform[2][0] + xform[3][0]);
newPoint[1] = (original[0] * xform[0][1]) + (original[1] * xform[1][1]) + (original[2] * xform[2][1] + xform[3][1]);
newPoint[2] = (original[0] * xform[0][2]) + (original[1] * xform[1][2]) + (original[2] * xform[2][2] + xform[3][2]);
4: Get the distance of the corners to (0,0,0). Keep in mind that depending on your method of determining distance (IE, using a 3D distance formula) you may need to zero out the value of the point on the axis the cylinder was rotated to. If the cylinder was rotated to the Z axis, you would need to zero out the Z value for that point.
5: If any of the points report a distance less than the radius of the cylinder, you know there must be a volume intersection.
6: Special case: If the cylinder has a diameter small enough, it could fit inside of the bounding box completely, thus there would be no points for which their distance < cylinder radius. I am unsure of the maximum circle that fits within the projection of a box while not encompassing any points. My best guess is just to check if the diameter is < than any of the box's edge length, or check if the diameter is less than the diagonal of the box, which may be safer. Not sure.
7: If you want the cylinder to have a maximum length, that's not too bad either. Just take one point of the cylinder, a vector representing its direction and its length, and do origin + (dir * length) to get the endpoint of the cylinder. Transform it as well, and make sure any points you have fall within the Z of that transformed endpoint.
Tyler Shellberg
  • 203
    Will still fail in the case where a box edge intersects the cylinder, none of the box vertices are inside the cylinder, and the cylinder's axis doesn't intersect any fact of the box. – lightxbulb Mar 03 '20 at 07:33
  • Shoot. That's a good point! I guess I will need to come up with some workarounds for those cases if I can detect them. – Tyler Shellberg Mar 03 '20 at 15:47
  • Well, the surface intersection should work in that case. The only possibility where the volumes intersect but the boundaries (surfaces) do not, is when one is inside the other. So just use 3 checks: 1) any box vertex is closer to the cylinder axis than the cylinder radius, 2) cylinder axis-box intersection, 3) box edges-cylinder intersection. – lightxbulb Mar 03 '20 at 16:05
