If you have a vertex buffer like this:
var vertices = [
0.0, 0.0, 0.0,
1.0, 0.0, 0.0,
0.0, 0.6, 0.0,
1.0, 0.6, 0.0,
0.5, 1.0, 0.0
And simply draw it as it is:
// Create an empty buffer object
var vertex_buffer = gl.createBuffer();
// Bind appropriate array buffer to it
gl.bindBuffer(gl.ARRAY_BUFFER, vertex_buffer);
// Pass the vertex data to the buffer
gl.bufferData(gl.ARRAY_BUFFER, new Float32Array(vertices), gl.STATIC_DRAW);
// Draw the lines
gl.drawArrays(gl.LINES, 0, 5);
It would require two dedicated coordinates for each line segment. With the vertices
as defined above, it would only be possible two draw two lines:
If you have the following indices defined:
var indices = [
0, 2,
2, 4,
4, 3,
3, 2,
2, 1,
1, 0,
0, 3,
3, 1
It is possible to draw lines which intersect the same vertices again and again. This reduces redundancy. If you bind the index buffer and tell the GPU to draw line segments connecting the vertices by the order specified in the indecies array:
var index_buffer = gl.createBuffer();
gl.bindBuffer(gl.ELEMENT_ARRAY_BUFFER, index_buffer);
gl.bufferData(gl.ELEMENT_ARRAY_BUFFER, new Uint16Array(indices), gl.STATIC_DRAW);
// draw geometry lines by indices
gl.drawElements(gl.LINES, 16, gl.UNSIGNED_SHORT, index_buffer);
One can draw complexer figures without redefining the same vertices over and over again. This is the result:
To achieve the same result without indices, the vertex buffer should look like the following:
var vertices = [
0.0, 0.0, 0.0,
0.0, 0.6, 0.0,
0.0, 0.6, 0.0,
0.5, 1.0, 0.0,
0.5, 1.0, 0.0,
1.0, 0.6, 0.0,
1.0, 0.6, 0.0,
0.0, 0.6, 0.0,
0.0, 0.6, 0.0,
1.0, 0.0, 0.0,
1.0, 0.0, 0.0,
0.0, 0.0, 0.0,
0.0, 0.0, 0.0,
1.0, 0.6, 0.0,
1.0, 0.6, 0.0,
1.0, 0.0, 0.0
// Draw the lines
gl.drawArrays(gl.LINES, 0, 16);
Which results in the same image:
Note the huge redundancy in stored vertices.
