I got a phone with custom rom and root and usb debugging activated. I forgot the pin so I tried this idea from @Max : Reset PIN from adb shell
adb reboot recovery
(wait for reboot)
adb shell rm /data/system/locksettings.db
and reboot into normal mode with :
adb reboot
I followed the commands and yes the lockscreen is now gone, but the "Phone is starting" screen won`t go away, normally it stays for max. 5 seconds.
If the phone really needs to be factory reseted it´s okay, I just found out that I still have access to all the files via computer.
I want to ask is there any command/solution to solve this problem?
best reagards bam
su
available) – alecxs May 13 '22 at 13:00
