I have forgotten the PIN of a device but I do have access to a root shell with adb shell
and su
Is there some way I could remove the screen PIN lock or change it?
and su
if your device is not encrypted with login credentials you can delete locksettings.db
adb shell su -c "rm /data/system/locksettings.db*"
However, bear in mind the following files are required for FBE encryption. If you delete these files you won't be able to decrypt userdata partition, all data is lost
/data/system/gatekeeper.password.key
/data/system/gatekeeper.pattern.key
/data/system/locksettings.db-shm
/data/system/locksettings.db-wal
@alexcs solution can work without root / su (sorry I can't comment on his answer) :
adb reboot recovery
(wait for reboot)
adb shell rm /data/system/locksettings.db
and reboot into normal mode with :
adb reboot
A brute force solution existed as I had access to fastboot too.
To remove the PIN, removed the entire userdata partition with fastboot
fastboot erase userdata
as described here: https://android.stackexchange.com/a/175887/320098
