I want to automate the creation of virtual android devices (using Android x86 and QEMU/KVM on Linux), the device settings includes screen resolution and density. The common way to set these settings is through adb shell wm size
and adb shell wm density
but it requires the device to be running, while changing /system/build.prop
doesn't, I can mount the virtual disk and make changes there.
Asked
Active
Viewed 2,782 times
hldev
- 143
- 1
- 5
Since you are open to modifying virtual disk you can edit the file settings_global.xml
located under /data/system/users/0/
directory. Among other things, look for these two keys in that file:
display_size_forced
display_density_forced
These keys correspond to wm size WxH
and wm density DPI
respectively. Change their values to your desirable WidthxHeight
and density
Save it. That's it.
Firelord
- 25,084
- 20
- 124
- 286
