Recently my Huawei P8 Lite decided that it doesn't want to play videos in apps anymore. Videos that I tap on on Twitter, Youtube, Youtube Go, and Reddit just load infinitely and don't do anything. Videos in my browser work completely fine, however, and videos that I've recorded myself play just fine, and there's audio, but the screen stays black.
I've tried clearing caches and deleting/re-downloading apps, but nothing seems to work. The only thing I can think of is to reboot my phone. The problem is that my power button is broken, so I have no way of turning it off. My phone doesn't have a Home button, and my volume buttons aren't separate so I can't press them both at once. So I don't think a lot of those fixes are going to work for me.
Do I have any other options? I've seen people recommending apps that will reset my phone for me, but that usually means rooting my phone, and the ones that don't require rooting don't work. I'm not rooting my phone, so those options are out the window.
Is there anything else I can do? I just want my videos to work again.
cd
into platform-tools folder, typeadb.exe reboot
(however, you should more care about what happens if battery is drained completely, see first link) – alecxs Apr 20 '20 at 13:37
