Here is a minimal example of a builder-style Groovy DSL for declaring e-mails.
email {
    from("[email protected]")
    to("[email protected]")
    body {
        html("Ahoj")
        // lots of other fields here
For example, I want to extract the body part
    body {
        html("Ahoj")
and reuse it in multiple e-mails. Probably it should look like this
email {
    myBody("Ahoj1")
email {
    myBody("Ahoj2")
I want to preserve IDE autocompletion in the myBody function.
/// This is the (abbreviated) DSL example from
///  http://docs.groovy-lang.org/docs/latest/html/documentation/core-domain-specific-languages.html#TheDelegatesToannotation-DelegatesTo
def email(@DelegatesTo(strategy = Closure.DELEGATE_ONLY, value = EmailSpec) Closure cl) {
    def email = new EmailSpec()
    def code = cl.rehydrate(email, this, this)
    code.resolveStrategy = Closure.DELEGATE_ONLY
    code()
class EmailSpec {
    void from(String from) { println "From: $from" }
    void to(String... to) { println "To: $to" }
    void body(@DelegatesTo(strategy = Closure.DELEGATE_ONLY, value = BodySpec) Closure body) {
        def bodySpec = new BodySpec()
        def code = body.rehydrate(bodySpec, this, this)
        code()
class BodySpec {
    void html(String html) { println "Body (html): $html" }
I am using the above DSL to make the question self-contained. In fact, I am interested in doing the same with the Jenkins Job DSL.
user7610
  • 25,267
  • 124
  • 150
  • Here's one suggestion. Do not use the DSL, use a Java-like API when that is available. The advice is for Gradle Groovy DSL, https://discuss.gradle.org/t/how-to-refactor-common-configuration-code/5050/2. – user7610 Aug 05 '23 at 10:11
Create a helper function
static <V> Closure<V> closureCtx(@DelegatesTo.Target context, @DelegatesTo Closure<V> closure) {
    return closure
then use it to set context for the the extracted DSL fragment
Closure<Void> myBody(String text) {
    return closureCtx(EmailSpec) { ->
        body {
            html(text)
This is sufficient to get the IDE autocompletions to work correctly when editing the fragment.
user7610
  • 25,267
  • 124
  • 150
