I use gcloud compute engine for my db and app engine for my server. If on the CE I enable ephemeral external IP, my server can connect via the INTERNAL network. I can also reach my server externally. If however I configure my CE with INTERNAL ONLY then my server cannot reach the CE, even though the server used the internal network with the CE configured for ephemeral external IP. The server knows nothing about the ephemeral IP address of the CE instance. In summary:
CE with default network (10.156.0.X & ephemeral external IP) -> App Engine server (via 10.156.0.X) = works!
CE with default network (10.156.0.X only) -> App Engine server = doesn't work
I would have thought simply removing the external IP address wouldn't have an effect on the internal network! I am currently using the Serverless VPC connector on my server to access the GCE. Both are part of the same project.
With external IP configuration:
"networkInterfaces": [
"name": "nic0",
"network": "projects/x/global/networks/default",
"accessConfigs": [
"name": "External NAT",
"type": "ONE_TO_ONE_NAT",
"natIP": "xx.xxx.xx.xx",
"kind": "compute#accessConfig",
"networkTier": "STANDARD",
"setPublicPtr": false
"subnetwork": "projects/x/regions/europe-west3/subnetworks/default",
"networkIP": "10.156.0.6",
"fingerprint": "tkgs6oiAL8E=",
"kind": "compute#networkInterface"
Without external IP
"name": "nic0",
"fingerprint": "uWRkQpIa-fs=",
Database firewall configuration:
"allowed": [
"IPProtocol": "tcp",
"ports": [
"0-65535"
"IPProtocol": "udp",
"ports": [
"0-65535"
"IPProtocol": "icmp"
"creationTimestamp": "2020-03-23T08:36:03.630-07:00",
"description": "Allow internal traffic on the default network",
"direction": "INGRESS",
"disabled": false,
"enableLogging": false,
"id": "x",
"kind": "compute#firewall",
"logConfig": {
"enable": false
"name": "default-allow-internal",
"priority": 65534,
"selfLink": "projects/x/global/firewalls/default-allow-internal",
"sourceRanges": [
"0.0.0.0/0",
"10.128.0.0/9",
"10.8.0.0/28"
"sourceServiceAccounts": [
"[email protected]"
Server firewall configuration:
Priority
1000
Action on match
ALLOW
IP Range
10.156.0.6
Description
Something
App Engine configuration:
runtime: nodejs16
env: standard
instance_class: F4
handlers:
- url: .*
script: auto
- url: .*
script: auto
env_variables:
ACCESS_CONTROL_ALLOW_ORIGIN: 'https://x.com'
DB_PATH_INTERNAL: 'http://10.156.0.6:8529'
automatic_scaling:
min_idle_instances: automatic
max_idle_instances: automatic
min_pending_latency: automatic
max_pending_latency: automatic
network:
vpc_access_connector:
egress_setting: private-ip-ranges
service_account: [email protected]
