What am I supposed to send as the request body. I keep getting 400 Bad request. I have tried it on Postman as well as in a html file with javascript code in the script tag.
What does it mean by the file's bytes? A file as a byte array?
I also tried using postman with a key (type: file) and a file. Got BAD_REQUEST
I tried creating Blobs and converted them into byte array, append those arrays into formdata and then provide them as request body using JSON.stringify().
The current code however takes a file input from a form html tag.
Nothing seems to be working.
Also how do I write a curl command for this POST method. And how to get a document's metadata.
<!DOCTYPE html>
<html lang="en">
<head>
    <meta charset="UTF-8">
    <meta http-equiv="X-UA-Compatible" content="IE=edge">
    <meta name="viewport" content="width=device-width, initial-scale=1.0">
    <title>Document</title>
</head>
<body>
    <form action="" enctype="multipart/form-data" id="FORM">
        <div>
            <label for="">File Name:</label>
            <input type="text" id="FileName">
            <label for="">File:</label>
            <input type="file" id="File">
            <button type="submit" style="" id="submitB">Submit</button>
        </div>
    </form>
</body>
<script>
const formData = new FormData();
        const formDataTwo = new FormData();
        const formDataThree = new FormData();
        const fileOne = new Blob(["John","117"],{type:'text/html'});
        const fileTwo = new Blob(["Commander", "Zavala"], { type: 'text/html' });
        const fileThree = new Blob(["Ikora", "Rey"], { type: 'text/html' });
        var reader = new FileReader();
        reader.readAsArrayBuffer(fileOne);
        var byteOne = [];
        reader.onloadend = function(e){
            if(e.target.readyState == FileReader.DONE){
                var arrayBuffer = e.target.result;
                array = new Uint8Array(arrayBuffer);
            for(var i=0; i<array.length;i++){
                byteOne.push(array[i]);
        var readerOne = new FileReader();
        readerOne.readAsArrayBuffer(fileTwo)
        var byteTwo = [];
            readerOne.onloadend = function (e) {
                if (e.target.readyState == FileReader.DONE) {
                for (var i = 0; i < array.length; i++) {
                    byteTwo.push(array[i]);
        var form = document.getElementById('FORM')
        form.onsubmit = async (e) =>{
            e.preventDefault()
            const form = e.currentTarget;
            var readerTwo = new FileReader();
            readerTwo.readAsArrayBuffer(document.getElementById('File').files[0]);
            let byteThree = [];
            const formDataNew = new FormData();
            readerTwo.onloadend = function (e) {
                    byteThree.push(array[i]);
                formDataNew.append('additionalProp1', byteThree)
            const obj = {
                additionalProp1: formDataNew
            fetch('http://localhost:8080/o/headless-delivery/v1.0/sites/20121/documents', {
                method: "POST",
                headers: {
                    "Content-Type": "multipart/form-data",
                    "Authorization": `Basic ${btoa('[email protected]:learn')}`
                body: JSON.stringify(obj)
                .then(Response => Response.json())
                .then(json => console.log(json));
        // formData.append('fileOne', byteOne);
        // formDataTwo.append('fileTwo', byteTwo);
        // formDataThree.append('fileThree', byteThree);
</script>
</html>
The Postman api request worked after I modified the key name as instructed. But the html page still won't work. I keep getting Error code 400. My current js code is below. Also find the working Postman request screenshots below.
            e.preventDefault()
            const file = document.querySelector("input[type=file]").files[0];
            const metadata = {additionalProp1: "string" };
            const body = new FormData();
            body.append("file", file);
            body.append("document", JSON.stringify(metadata));
            fetch("http://localhost:8080/o/headless-delivery/v1.0/sites/20121/documents", {
                method: "POST",
                headers: {
                body
John117
  • _"tried using postman with a key (type: file) and a file"_... according to your screenshot you used field name `NewDoc`. Have you tried `file` instead? – Phil Feb 08 '23 at 03:47
Bad API documentation, especially examples can be a real hindrance.
From reading just the description...
The request body must be multipart/form-data with two parts, the file's bytes (file), and an optional JSON string (document) with the metadata.
Update: from comments below it seems that document should also be a file
I would assume you'd need something like this...
document.getElementById("FORM").addEventListener("submit", async (e) => {
  e.preventDefault();
  const file = document.getElementById("File").files[0];
  // this is just an example
  const metadata = { additionalProp1: "string" };
  // create a File object for the JSON document
  const doc = new File([JSON.stringify(metadata)], "metadata.json", {
    type: "application/json",
  body.append("document", doc);
  const res = await fetch("http://localhost:8080/o/headless-delivery/v1.0/sites/20121/documents", {
    method: "POST",
    headers: {
      authorization: `Basic ${btoa('[email protected]:learn')}`,
    body,
  if (!res.ok) {
    throw new Error(`${res.status} ${res.statusText}: ${await res.text()}`);
  console.log("Success!", await res.json());
Note that there is no content-type header added. The browser is able to provide the correct value automatically when using a FormData body. See this answer for more details.
I think you can ignore any examples they offer. They don't appear to match the description at all.
In Postman, you'd use form-data like this
Key Value Description
file NewDoc.txt A file
document metadata.json A JSON file
It would be up to you to ensure document is properly formatted JSON.
Phil
  • 157,677
  • 23
  • 242
  • 245
  • FIrst of all I would like to thank you good sir for your guidance. Postman worked out! But I am still getting error code 400 with the html page. I would post my current code as an answer below. Please help. – John117 Feb 08 '23 at 04:58
  • @John117 I see what you've done wrong. Remove the content-type header. I've updated my answer – Phil Feb 08 '23 at 05:31
  • Yes, the code worked. I stored a .json file in the matadata variable and appended it to formdata. However, if metadata contains that object that you provided in the code above and I append that variable then it returned error code 400 even after JSON.stringify(). Why is it that content-type isn't required for this post request? – John117 Feb 08 '23 at 05:48
  • Ok, just saw your response for content-type header. Thanks for the clarification and all your help. – John117 Feb 08 '23 at 05:52
  • @John117 so you're saying that `document` needs to be a file too? That API really is poorly documented – Phil Feb 08 '23 at 05:55
  • @John117 I've updated my answer to show how to create a JSON file – Phil Feb 08 '23 at 05:59
  • Yes, that code works like a charm. But cannot upload a file with the same filename twice. Error code 409 CONFLICT. However, when there was an additional parameter in body.append("file", file, fileName) which I was getting from input type="text" tag, whenever I changed the input even if the file was same, I was getting success. – John117 Feb 08 '23 at 06:09
    @John117 Nice, sounds like you've got it sorted then – Phil Feb 08 '23 at 06:38
