Java Virtual Threads
In Java 19 were introduced Virtual Threads JEP-425 as a preview feature.
After some investigation of concept of Java Virtual Threads (Project Loom), called sometimes lightweight threads (or sometimes fibers or green threads), I'm pretty interested in potential usage of them with reactive libraries, like, for example, with Spring WebFlux based on Project Reactor (reactive streams implementation) and Netty, for making blocking calls efficiently.
Most JVM implementations today implement Java threads as thin direct wrappers around operating system threads, called sometimes heavyweight, OS-managed threads platform threads.
While a platform thread can only execute a single thread at a time, the virtual threads have the ability to switch to executing a different virtual thread when the currently executed virtual thread makes a blocking call (e.g. network, file system, database call).
How do we deal with blocking calls in Reactor?
So, when dealing with blocking calls in Reactor we use the following construct:
Mono.fromCallable(() -> {
return blockingOperation();
}).subscribeOn(Schedulers.boundedElastic());
In subcribeOn() we provide a Scheduler that creates a dedicated thread for executing that blocking operation. However, it means that the thread will eventually be blocked, so, as we are still on the old-fashioned threading model, we'll actually block the platform thread, which is still not really efficient way of dealing with CPU resources.
Here is the question:
So, the question is, could we use the virtual threads with reactive frameworks directly for making blocking calls like this, using, for example, Executors.newVirtualThreadPerTaskExecutor() :
Creates an Executor that starts a new virtual Thread for each task. The number of threads created by the Executor is unbounded.
}).subscribeOn(Schedulers.fromExecutorService(Executors.newVirtualThreadPerTaskExecutor()));
Would it work out of the box? Will we actually get the benefits from this approach, in terms of dealing with our CPU-resources more efficiently and increase performance of our application? Does it mean that we can easily integrate reactive library with any blocking library/framework, for example, Spring Data JPA (which is based on JDBC) and millions of others and magically turn them to non-blocking?
