I am working with SQLAlchemy and I am getting confused between Engine, Metadata, Base, and Sessions.
I did find some useful links: here, here and here, but I think it would help to know why the code below is not working.
import sqlalchemy as sqlalc
from sqlalchemy import Column, INTEGER, Integer,ForeignKey, Table, VARCHAR, TIMESTAMP, MetaData, create_engine, inspect, cast, select, SmallInteger
from sqlalchemy.orm import relationship, backref, sessionmaker
from sqlalchemy.ext.declarative import declarative_base
url = 'mysql://[email protected]/info'
engine = create_engine(url, echo=True)
metadata = MetaData()
metadata.bind = engine
metadata.create_all(engine)
connection = engine.connect()
Base = declarative_base()
Base.metadata.create_all()
Session = sessionmaker(bind=engine)
session = Session()
When I execute, I get the following error:
sqlalchemy.exc.UnboundExecutionError: MetaData object is not bound to an Engine or Connection. Execution can not proceed without a database to execute against.
