I'm invoking a supabase edge function with the following
async function getData(plan_data){
console.log(plan_data)
console.log(JSON.stringify({plan_data}))
const { data, error } = await supabase.functions.invoke("create-stripe-checkout",
body: JSON.stringify({
plan_data
console.log(data, error)
// console.log(data)
In the edge function I console logged the request and it stated bodyUsed: false. Essentially the edge function acts like and believes that no value was passed. (A value is passed to the getData function properly).I've played around with the syntax a bit to no avail, am I missing something?
EDIT: Edge function is as follows
import { serve } from "https://deno.land/[email protected]/http/server.ts"
serve(async (req) => {
if (req.method === "OPTIONS"){
return new Response (null, {
headers: {
"Access-Control-Allow-Origin": "*",
"Access-Control-Allow-Headers": "apikey, X-Client-Info, Authorization, content-type",
console.log(req)
const { planId } = await req.json()
console.log(planId)
return new Response(
JSON.stringify({ planId }),
{ headers: {
// "Content-Type": "application/json",
EDIT: I tried running it with supabase's example code and had the same issue.
