I have being reviewing the docker engine SDK documentation related with running Docker with Golang (https://docs.docker.com/engine/api/sdk/) I would like to run a container(which is well documented) but I cannot find how can I mount a volume when running the container.
My idea is to use Docker SDK to run the equivalent command: docker run -v $PWD:/tmp myimage But without executing the Golang os exec library.
Is that possible?
Ferrandinand
  • 444
    There are a couple of mount options in the [`HostConfig`](https://pkg.go.dev/github.com/docker/[email protected]+incompatible/api/types/container#HostConfig) structure; is this the piece you're missing? – David Maze Dec 01 '22 at 22:45
The examples section has most of what you need:
https://docs.docker.com/engine/api/sdk/examples/#run-a-container
Important to remember that docker run ... does both
  1. create a container
  2. start a container
and that docker run -v is short hand for docker run --mount type=bind,source="$(pwd)"/target,target=/app
    resp, err := cli.ContainerCreate(ctx, &container.Config{
        Image: "alpine",
        Cmd:   []string{"echo", "hello world",},
      &container.HostConfig{
        Mounts: []mount.Mount{
             Type: mount.TypeBind,
             Source: "/local/dir",
             Target: "/app",
     nil,
If you want just a single file
        Image: "alpine",
        Binds: []string{
          "/local/dir/file.txt:/app/file.txt",
      nil,
related:
deric4
  • 1,095
