I just initialized a VueJs Project:
npm init vue@3 .
Need to install the following packages:
[email protected]
Ok to proceed? (y) y
Vue.js - The Progressive JavaScript Framework
√ Package name: ... no-interrupts
√ Add TypeScript? ... Yes
√ Add JSX Support? ... Yes
√ Add Vue Router for Single Page Application development? ... Yes
√ Add Pinia for state management? ... Yes
√ Add Vitest for Unit Testing? ... No
√ Add Cypress for both Unit and End-to-End testing? ... No
√ Add ESLint for code quality? ... Yes
√ Add Prettier for code formatting? ... Yes
But now when I do format my code(alt+shift+f), prettier is underlining some things. If I run npm run lint
, things go back to normal.
for example, alt-shift-F seems to try to keep the first property of html element on the first line:
<img alt="Vue logo"
class="logo"
src="@/assets/logo.svg"
width="125"
height="125" />
Where npm run lint have a dedicated line for each attribute:
<img
alt="Vue logo"
class="logo"
width="125"
height="125"
It's especially an issue because the file is formated on save.
I've not a strong preference, but if possible I would like to keep the one proposed by npm run lint
my eslintrc.cjs
contains the following:
/* eslint-env node */
require("@rushstack/eslint-patch/modern-module-resolution");
module.exports = {
root: true,
extends: [
"plugin:vue/vue3-essential",
"eslint:recommended",
"@vue/eslint-config-typescript/recommended",
"@vue/eslint-config-prettier",
parserOptions: {
ecmaVersion: "latest",
What should I do to have the alt-shift-f
command formating properly my code?
