I just setup cruise control on my server for my projects . But now i am little bit confused how these rake task and capistrano work . I tried lots of settings but still no success . If somebody help how to run all rake task and after successful build how can i deploy my application .
You don't ned to use capistrano for cruise-control. Your cruise control should be checking source-control for new versions, and building when it finds one. – Jesse Wolgamott Sep 06 '11 at 14:27
Yeah it builds well when it finds new versions in source-control . It just invoke these commands only -: [CruiseControl] Invoking Rake task "db:test:load" [CruiseControl] Invoking Rake task "db:migrate" [CruiseControl] Invoking Rake task "test" but it didnt deploy my app .. – Vivek Parihar Sep 07 '11 at 08:50
CruiseControl isn't supposed to deploy your app.
When you want to deploy your app (after many successful cruisecontrol tests against many commits to source control, you'll then:
cap deploy
- 40,197
- 4
- 83
- 109
Ok guys thanks after looking into code i find out that we can deploy -:
1.Either you can use ccrb_cap_deployer.rb plugin to do so , but it is little bit buggy so i made some changes in the path and pushed the code into git again here
https://[email protected]/webonise/cruisecontrol.git
# in mean time I add some more plugins and features . Also add the wiki for proper step how to setup cruise control server and how make it customize as per your need
Now we had to add these two lines inside the project configuration file /.cruise/projects/your_project/cruise_config.rb
project.cap_deployer.emails = ['[email protected]'] #here add the email to notify given user if deployment is successful or not
project.cap_deployer.stages = ['staging','production'] #here add the where you want to deploy test , staging or production
Also this plugin only let deploy the code into respective servers when the build is successful . Cheers
2.Second way is to create one shell script named it as build_script.sh to this path /.cruise/projects/your_project/work/
After that add
#!/bin/bash
# conditionally install project gems from Gemfile
bundle check || bundle install || exit 1
cap deploy
lines into the build_script.sh and save , Then add project.build_command = './build_script.sh' inside the project configuration file /.cruise/projects/your_project/cruise_config.rb
Now everthing done and works fine but in second method the problem is that if the build fails as well then also your code is deployed to server . SO i think that is a bad approach .
Thanks for help everyone.
- 2,318
- 18
- 18
