const StyledInput = styled.input`w-full focus:ring-indigo-500 focus:border-indigo-500 block p-2 border-gray-300 border-2 rounded-md`;
export const Input = (props: StyledInputProps) => {
    return props.iconPosition === 'trailing' ? (
        <div>
            {props.label && <div tw="text-coolGray-800">{props.label}</div>}
            <div tw="w-full relative rounded-md shadow-sm flex">
                <StyledInput {...props} />
                <div tw="absolute inset-y-0 right-0 pr-3 flex items-center pointer-events-none">
                    {props.icon}
                </div>
            </div>
        </div>
        <div>
            <div tw="w-full relative rounded-md flex bg-white">
                {props.icon && (
                    <div tw="z-10 h-full leading-snug font-normal absolute text-center rounded text-base items-center justify-center w-8 pl-3 py-3">
                        {props.icon}
                    </div>
            </div>
        </div>
No Matter how I try to style the leading input Icon, I always get this: enter image description here
I'm trying to get the icon to go inside the input element, like Put icon inside input element in a form
But Even trying all the normal answers, I can't figure it out, is there something really dumb I'm missing?
    It looks like you might need to add some padding to your input to push the content to the right of your icon. Also, shouldn't you be using the `className` prop instead of `tw` for your Tailwind classes? – Ed Lucas Mar 04 '22 at 22:19
  • tw is twin.macro, its a library to make styling tailwind easier – connorjohnson Mar 04 '22 at 23:29
  • @EdLucas How do I add the padding to the input field using tailwind? what's the selector – connorjohnson Mar 04 '22 at 23:55
  • Isn't it just your `StyledInput`? If not, you could add an example the final rendered markup in your question. – Ed Lucas Mar 05 '22 at 14:50
          <div>
            <label
              for="input-group-1"
              class="block mb-2 text-sm font-medium text-gray-900 dark:text-white"
              Email
            </label>
            <div class="relative mb-6">
              <MdEmail className="pointer-events-none w-8 h-8 absolute top-1/2 transform -translate-y-1/2 left-3 " />
              <input
                type="text"
                id="input-group-1"
                class="bg-gray-50 border pl-12 border-gray-300 text-gray-900 text-sm rounded-lg focus:ring-blue-500 focus:border-blue-500 block w-full pl-10 p-2.5  dark:bg-gray-700 dark:border-gray-600 dark:placeholder-gray-400 dark:text-white dark:focus:ring-blue-500 dark:focus:border-blue-500"
                placeholder="[email protected]"
            </div>
          </div>`
    Your answer could be improved with supporting information as to how this solves the problem. This will help later readers to understand the solution. – Harrison May 19 '23 at 11:25
