This is currently a purely theoretical question (related to this one), but let me first give the background. Whenever you run hg gexport
the initial hash will vary from invocation to invocation. This is similar to when you run git init
or hg init
. However, since the Mercurial and Git commits correspond to each other and build on previous hashes, there should be some way to start over from a minimal common initial state (or minimal state on the Git side, for example).
Suppose I have used hg-git in the past and now I am trying to sync again between my Mercurial and my Git states, but without (or very little of) the original .git
directory from the hg gexport
. What I do have, though, are the two metadata files: git-mapfile
and git-tags
There is an old Git mirror, which is sort of "behind" and the Mercurial repo which is up-to-date.
Then I configure the Mercurial repo for hg-git like so (.hg/hgrc
[git]
intree = True
[extensions]
hgext.bookmarks=
topic=
hggit=
[paths]
default = ssh://[email protected]//project/repo
gitmirror = git+ssh://[email protected]/project/repo.git
If I now do the naive hg pull gitmirror
all I will gain is a duplication of every existing commit on an unrelated branch with unrelated commit history (and the double amount of heads, compared to prior to the pull).
It clearly makes no big difference to place those two metadata files (git-mapfile
and git-tags
) into .hg
. The biggest difference is that the pull without these files will succeed (but duplicate everything) and the pull with them will error out at the first revision because of "abort: unknown revision ..." (even makes sense).
Question: which part(s) and how much (i.e. what's the minimum!) of the Git-side data/metadata created by hg gexport
do I have to keep around in order to start over syncing with hg-git? (I was unable to find this covered in the documentation.)
