[SOLVED!!]
  • Server OS: CentOS Linux 7
  • VSCode version (local): 1.59.1
I connected to my server by ssh
ssh [email protected]
I try to open VSCode by local, and using Remote-SSH -> Connected to SSH -> type [email protected]
Then got Could not establish connection to "@ln01.twcc.ai". Error block and output is like as below
[11:37:51.572] Log Level: 2
[11:37:51.574] [email protected]
[11:37:51.574] win32 x64
[11:37:51.575] SSH Resolver called for "ssh-remote+...", attempt 1
[11:37:51.575] "remote.SSH.useLocalServer": false
[11:37:51.575] "remote.SSH.showLoginTerminal": false
[11:37:51.575] "remote.SSH.remotePlatform": {}
[11:37:51.575] "remote.SSH.path": undefined
[11:37:51.575] "remote.SSH.configFile": undefined
[11:37:51.575] "remote.SSH.useFlock": true
[11:37:51.576] "remote.SSH.lockfilesInTmp": false
[11:37:51.576] "remote.SSH.localServerDownload": auto
[11:37:51.576] "remote.SSH.remoteServerListenOnSocket": false
[11:37:51.576] "remote.SSH.showLoginTerminal": false
[11:37:51.576] "remote.SSH.defaultExtensions": []
[11:37:51.576] "remote.SSH.loglevel": 2
[11:37:51.576] SSH Resolver called for host: ssh [email protected]
[11:37:51.576] Setting up SSH remote "ln01.twcc.ai"
[11:37:51.592] Using commit id "..." and quality "stable" for server
[11:37:51.595] Install and start server if needed
[11:37:56.696] Checking ssh with "ssh -V"
[11:37:56.726] > OpenSSH_for_Windows_8.1p1, LibreSSL 3.0.2
[11:37:56.729] Running script with connection command: ssh -T -D 53574 "ssh [email protected]" bash
[11:37:56.731] Terminal shell path: C:\Windows\System32\cmd.exe
[11:37:56.948] > ]0;C:\Windows\System32\cmd.exe
[11:37:56.948] Got some output, clearing connection timeout
[11:37:57.376] >
[11:37:59.421] > ssh [email protected]: Permission denied (publickey,gssapi-keyex,gssapi-with
> -mic,keyboard-interactive).
[11:37:59.434] > 程序嘗試寫入到一個不存在的管道。
[11:38:00.713] "install" terminal command done
[11:38:00.714] Install terminal quit with output: 程序嘗試寫入到一個不存在的管道。
[11:38:00.714] Received install output: 程序嘗試寫入到一個不存在的管道。
[11:38:00.714] Failed to parse remote port from server output
[11:38:00.715] Resolver error: Error:
    at Function.Create (c:\Users\ASUS\.vscode\extensions\ms-vscode-remote.remote-ssh-0.65.7\out\extension.js:1:64659)
    at Object.t.handleInstallOutput (c:\Users\ASUS\.vscode\extensions\ms-vscode-remote.remote-ssh-0.65.7\out\extension.js:1:63302)
    at Object.t.tryInstall (c:\Users\ASUS\.vscode\extensions\ms-vscode-remote.remote-ssh-0.65.7\out\extension.js:1:415135)
    at processTicksAndRejections (internal/process/task_queues.js:93:5)
    at async c:\Users\ASUS\.vscode\extensions\ms-vscode-remote.remote-ssh-0.65.7\out\extension.js:1:294918
    at async Object.t.withShowDetailsEvent (c:\Users\ASUS\.vscode\extensions\ms-vscode-remote.remote-ssh-0.65.7\out\extension.js:1:406463)
    at async Object.t.resolve (c:\Users\ASUS\.vscode\extensions\ms-vscode-remote.remote-ssh-0.65.7\out\extension.js:1:295994)
    at async c:\Users\ASUS\.vscode\extensions\ms-vscode-remote.remote-ssh-0.65.7\out\extension.js:127:110656
[11:38:00.718] ------
Summary
  • When I try to remote-ssh by local VSCode, got the Disconnected from SSH Error
Error Block
wen
  • 825
7 Answers7
Try to delete the fingerprint (a single line that corresponds to this particular connection - not the whole file) saved within the known_hosts file. If in Windows, this is placed at C:\Users\<your_user_name>\.ssh\known_host whereas for Linux that would be within /home/<your_user_name>/.ssh/known_hosts dir.
Since more detailed, you may also want to check this answer too.
cestpasmoi
  • 505
Here is what worked for me:
  1. Open the command panel on VS code (Ctrl+Shift+P for Windows and Cmd+Shift+P for Mac).
  2. Search for Kill VS Code Server on Host, click it - it will be automatically deleted.
  3. Reload VS Code and establish connection again.
For more details, please visit here.
user3503711
  • 1,623
  • 32
I solved it by writing SSH config files first before remoting.
If you connected to server by ssh like:
ssh [email protected] -p 22
Then config file would be:
Host MyHostName
    HostName 123.456.78.999
    User Amy
    Port 22
reference: https://github.com/microsoft/vscode-remote-release/issues/3968
wen
  • 825
  • this solved the issue for me -- specifically adding the port number to the config file I've been using remote SSH for two years now and until now it was fine, no update or anything that would explain what changed... – Federico Jun 17 '22 at 18:21
In my case the problem turned out to be that there was no free disk space on the server (also logs in vscode were different).
Disk usage can be checked with: df -h
WMax
  • 59
If Kill VS Code Server on Host won't help (after you have tried that!), then make a refresh on local machine by:
  1. Delete ~/.vscode
  2. Delete ~/.config/Code
Then re-install the latest version of VSCode. It will work.
pateheo
  • 430
Yea I was also facing same issue when I updated my VS code to latest version 1.75.1 Facing issue "Connection failed XSH issue"
This is because of proxy issue with you linux machine where your VS code is trying to connect .
Solution:
  1. 'Navigate to Linux machine--> and perform below operation [user @linuxmachineip] : cd .vs code-server/ (navigate to vs code-sever folder)
  2. [user @linuxmachineip .vs code-server] : SU - (login as Root user)
  3. [user @linuxmachineip .vs code-server] : cd / etc / profile.d (navigate to etc/profile.d folder)
  4. [user@linuxmachineip .vscode-server] : mv proxy.sh.off proxy.sh (rename proxy.sh.off to proxy.sh ***** as this will enable your vscode to connect to internet to download all necessary files in profile.d folder )
  5. Now relaunch your VS code and try to connect . (it will connect now) And then again come back to Linux machine
  6. [user@linuxmachineip .vscode-server] mv proxy.sh proxy.sh.off (rename proxy.sh to proxy.sh.off ***** as this will disable again)'
  • Your answer could be improved with additional supporting information. Please [edit] to add further details, such as citations or documentation, so that others can confirm that your answer is correct. You can find more information on how to write good answers [in the help center](/help/how-to-answer). – Community Feb 24 '23 at 13:31
-2
I have faced the problem many times. Restart the vscode program always resolve my problem.
hjc
    This does not really answer the question. If you have a different question, you can ask it by clicking [Ask Question](https://stackoverflow.com/questions/ask). To get notified when this question gets new answers, you can [follow this question](https://meta.stackexchange.com/q/345661). Once you have enough [reputation](https://stackoverflow.com/help/whats-reputation), you can also [add a bounty](https://stackoverflow.com/help/privileges/set-bounties) to draw more attention to this question. - [From Review](/review/late-answers/33479140) – Mike_H Dec 26 '22 at 18:50
  • As it’s currently written, your answer is unclear. Please [edit] to add additional details that will help others understand how this addresses the question asked. You can find more information on how to write good answers [in the help center](/help/how-to-answer). – Community Dec 28 '22 at 07:13
