Hi helpful People of the World!
i am getting into containerisation and docker and i am trying to create some basic containers. I am running Docker on Windows.
I want to create a container that runs a shell script with a curl command. i have found an image on docker with curl built in.
My Directory structure in windows looks like
Curl_container (folder)
Dockerfile (file)
curl_registry.sh (file)
the curl_registry.sh code is
#!/bin/bash
while :
do
HOSTNAME=$(hostname)
DATE=$(date +'%Y-%m-%d')
TIME=$(date +'%Y/%m/%d %X')
CURL_RESULT=`http://www.google.com | head -1`
echo $TIME $HOSTNAME $CURL_RESULT
sleep 5
done
exit
and my Docker file looks like this
FROM eamonwoortman/alpine-python-curl-zip
MAINTAINER [email protected]
WORKDIR /
COPY . /
RUN ["chmod", "+x","curl_registry.sh"]
ENTRYPOINT [ "./curl_registry.sh" ]
i am able to build the container;
PS C:\temp\Docker\Curl_container> docker build -t curl_container:1.18 .
[+] Building 1.0s (8/8) FINISHED
=> [internal] load build definition from Dockerfile 0.0s
=> transferring dockerfile: 238B 0.0s
=> [internal] load .dockerignore 0.0s
=> [internal] load metadata for docker.io/eamonwoortman/alpine-python-curl-zip:latest 0.0s
=> CACHED [1/4] FROM docker.io/eamonwoortman/alpine-python-curl-zip 0.0s
=> [2/4] COPY . / 0.1s
=> [3/4] RUN ["chmod", "+x","curl_registry.sh"]
=> writing image sha256:497b03c55d8e90e7eff43c8868e420498516477b9225ad6d3bdf0076ebe9d9ed 0.0s
=> naming to docker.io/library/curl_container:1.18 0.0s
However when i run it, I get the following error
PS C:\temp\Docker\Curl_container> docker run 497b03c55d8e
standard_init_linux.go:228: exec user process caused: no such file or directory
I would like to have the script running in a folder /apps, but i thought this was my problem and so tried to put the file into the root directory.
I have tried the ADD command in place of COPY and i got the same result.
the curl_registry.sh is showing as a .sh file in windows.
I have run my sh file through notepad++ and converted to unix LF.
