I have a legacy project in ember and when trying to run npm i it gives the following errors:
> [email protected] install
> node scripts/install.js
Downloading binary from https://github.com/sass/node-sass/releases/download/v3.13.1/win32-x64-72_bind
Cannot download "https://github.com/sass/node-sass/releases/download/v3.13.1/win32-x64-72_binding.nod
HTTP error 404 Not Found
Hint: If github.com is not accessible in your location
      try setting a proxy via HTTP_PROXY, e.g.
      export HTTP_PROXY=http://example.com:1234
or configure npm proxy via
      npm config set proxy http://example.com:8080
> node install.js
PhantomJS not found on PATH
Download already available at C:\Users\\AppData\Local\Temp\phantomjs\phantomjs-2.1.1-windows.z
Verified checksum of previously downloaded file
Extracting zip contents
Removing phantomjs-prebuilt\li
Copying extracted folder AppData\Local\Temp\phantomjs\phantomjs-2.1.1-windows.zip-exhantomjs-2.1.1-windows -> node_modules\phanantom
Writing location.js file
Done. Phantomjs binary available at node_moilt\lib\phantom\bin\phantomjs.exe
> [email protected] postinstall node_modules\bdules\core-js
> node -e "try{require('./postinstall')}catch(e){}"
Thank you for using core-js ( https://github.com/zloirock/core-js ) for polyfilling JavaScript standa
The project needs your help! Please consider supporting of core-js on Open Collective or Patreon:
> https://opencollective.com/core-js
> https://www.patreon.com/zloirock
Also, the author of core-js ( https://github.com/zloirock ) is looking for a good job -)
> [email protected] postinstall node_modules\bules\core-js
> node scripts/build.js
Building: C:\Program Files\nodejs\node.exe \\bin\node-gyp.js rebuild --verbose --libsass_ext= --libsass_cflags= --libsass_ldflags= --libsass_libr
gyp info it worked if it ends with ok
gyp verb cli [
gyp verb cli   'C:\\Program Files\\nodejs\\node.exe',
gyp verb cli   'C:\\Users\\\\Documents\\PROJETOS\\\\node_modules\\node-gygyp verb cli   'rebuild',
gyp verb cli   '--verbose',
gyp verb cli   '--libsass_ext=',
gyp verb cli   '--libsass_cflags=',
gyp verb cli   '--libsass_ldflags=',
gyp verb cli   '--libsass_library='
gyp verb cli ]
gyp info using [email protected]
gyp info using [email protected] | win32 | x64
gyp verb command rebuild []
gyp verb command clean []
gyp verb clean removing "build" directory
gyp verb command configure []
gyp verb check python checking for Python executable "python2" in the PATH
gyp verb `which` failed Error: not found: python2
gyp verb `which` failed     at getNotFoundError (C:\Users\\Documents\PROJETOS\RedeCotizadorFroich\which.js:13:12)
gyp verb `which` failed     at F (C:\Users\\Documents\PROJETOS\\node_modu:19)
gyp verb `which` failed     at E (C:\Users\\Documents\PROJETOS\\node_modu:29)
gyp verb `which` failed     at C:\Users\\Documents\PROJETOS\\node_modulesgyp verb `which` failed     at C:\Users\\Documents\PROJETOS\\node_modules
gyp verb `which` failed     at C:\Users\\Documents\PROJETOS\\node_modules5
gyp verb `which` failed     at FSReqCallback.oncomplete (fs.js:158:21)
gyp verb `which` failed  python2 Error: not found: python2
gyp verb `which` failed     at FSReqCallback.oncomplete (fs.js:158:21) {
gyp verb `which` failed   stack: 'Error: not found: python2\n' +
gyp verb `which` failed     '    at getNotFoundError (C:\\Users\\\\Documents\\PROJETOS\\RedeCo_modules\\which\\which.js:13:12)\n' +
gyp verb `which` failed     '    at F (C:\\Users\\\\Documents\\PROJETOS\\\\which.js:68:19)\n' +
gyp verb `which` failed     '    at E (C:\\Users\\\\Documents\\PROJETOS\\\\which.js:80:29)\n' +
gyp verb `which` failed     '    at C:\\Users\\\\Documents\\PROJETOS\\\\nhich.js:89:16\n' +
gyp verb `which` failed     '    at C:\\Users\\\\Documents\\PROJETOS\\\\nndex.js:42:5\n' +
gyp verb `which` failed     '    at C:\\Users\\\\Documents\\PROJETOS\\\\nindows.js:36:5\n' +
gyp verb `which` failed     '    at FSReqCallback.oncomplete (fs.js:158:21)',
gyp verb `which` failed   code: 'ENOENT'
gyp verb `which` failed }
gyp verb check python checking for Python executable "python" in the PATH
gyp verb `which` failed  python Error: not found: python
gyp verb `which` failed   stack: 'Error: not found: python\n' +
gyp verb could not find "python". checking python launcher
gyp verb could not find "python". guessing location
gyp verb ensuring that file exists: C:\Python27\python.exe
gyp ERR! configure error
gyp ERR! stack Error: Can't find Python executable "python", you can set the PYTHON env variable.
gyp ERR! stack     at PythonFinder.failNoPython (C:\Users\\Documents\PROJETOS\RedeCotizadorFrode-gyp\lib\configure.js:484:19)
gyp ERR! stack     at PythonFinder.<anonymous> (C:\Users\\Documents\PROJETOS\RedeCotizadorFrone-gyp\lib\configure.js:509:16)
gyp ERR! stack     at callback (C:\Users\\Documents\PROJETOS\\node_modulels.js:299:20)
gyp ERR! stack     at FSReqCallback.oncomplete (fs.js:158:21)
gyp ERR! System Windows_NT 10.0.19042
gyp ERR! command "C:\\Program Files\\nodejs\\node.exe" "C:\\Users\\\\Documents\\PROJETOS\\RededorFrontEnd\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild" "--verbose" "--libsass_ext=" "--libslags=" "--libsass_ldflags=" "--libsass_library="
gyp ERR! cwd C:\Users\\Documents\PROJETOS\\node_modules\node-sass
gyp ERR! node -v v12.14.1
gyp ERR! node-gyp -v v3.8.0
gyp ERR! not ok
Build failed with error code: 1
npm WARN [email protected] requires a peer of @babel/core@^7.0.0-beta.42 but none is ind. You must install peer dependencies yourself.
npm ERR! code ELIFECYCLE
npm ERR! errno 1
PS C:\Users\\Documents\PROJETOS\> npm install node-sass
> [email protected] install C:\Users\\Documents\PROJETOS\\node_modules\node
Downloading binary from https://github.com/sass/node-sass/releases/download/v6.0.1/win32-x64-72_bindie
Download complete .] - :
Binary saved to C:\Users\\Documents\PROJETOS\\node_modules\node-sass\vend32-x64-72\binding.node
Caching binary to C:\Users\\AppData\Roaming\npm-cache\node-sass\6.0.1\win32-x64-72_binding.nod
> [email protected] postinstall C:\Users\\Documents\PROJETOS\\node_modules\ass
Binary found at C:\Users\\Documents\PROJETOS\\node_modules\node-sass\vend32-x64-72\binding.node
Testing binary
> [email protected] install C:\Users\\Documents\PROJETOS\\node_modules\brosass-source-maps\node_modules\node-sass
Downloading binary from https://github.com/sass/node-sass/releases/download/v3.13.1/win32-x64-72_bindde
> [email protected] install C:\Users\\Documents\PROJETOS\\node_mophantomjs-prebuilt
> node install.js
Removing C:\Users\\Documents\PROJETOS\\node_modules\phantomjs-prebuilt\litom
Copying extracted folder C:\Users\\AppData\Local\Temp\phantomjs\phantomjs-2.1.1-windows.zip-ex1627499579693\phantomjs-2.1.1-windows -> C:\Users\\Documents\PROJETOS\\noules\phantomjs-prebuilt\lib\phantom
Done. Phantomjs binary available at C:\Users\\Documents\PROJETOS\\node_mophantomjs-prebuilt\lib\phantom\bin\phantomjs.exe
> [email protected] postinstall C:\Users\\Documents\PROJETOS\\node_modules\bolyfill\node_modules\core-js
Thank you for using core-js ( https://github.com/zloirock/core-js ) for polyfilling JavaScript standarary!
> [email protected] postinstall C:\Users\\Documents\PROJETOS\\node_modules\begister\node_modules\core-js
> [email protected] postinstall C:\Users\\Documents\PROJETOS\\node_modules\buntime\node_modules\core-js
> [email protected] postinstall C:\Users\\Documents\PROJETOS\\node_modulesoli-sass-source-maps\node_modules\node-sass
Building: C:\Program Files\nodejs\node.exe C:\Users\\Documents\PROJETOS\\odules\broccoli-sass-source-maps\node_modules\node-gyp\bin\node-gyp.js rebuild --verbose --libsass_exibsass_cflags= --libsass_ldflags= --libsass_library=
gyp verb cli [
gyp verb cli   'C:\\Users\\\\Documents\\PROJETOS\\\\node_modules\\broccol-source-maps\\node_modules\\node-gyp\\bin\\node-gyp.js',
gyp verb cli ]
gyp verb `which` failed     at getNotFoundError (C:\Users\\Documents\PROJETOS\RedeCotizadorFronode_modules\broccoli-sass-source-maps\node_modules\which\which.js:13:12)
gyp verb `which` failed     at F (C:\Users\\Documents\PROJETOS\\node_moduoccoli-sass-source-maps\node_modules\which\which.js:68:19)
gyp verb `which` failed     at E (C:\Users\\Documents\PROJETOS\\node_moduoccoli-sass-source-maps\node_modules\which\which.js:80:29)
gyp verb `which` failed     at C:\Users\\Documents\PROJETOS\\node_modulesoli-sass-source-maps\node_modules\which\which.js:89:16
gyp verb `which` failed     at C:\Users\\Documents\PROJETOS\\node_modules\index.js:42:5
gyp verb `which` failed     at C:\Users\\Documents\PROJETOS\\node_modules\windows.js:36:5
gyp verb `which` failed     '    at getNotFoundError (C:\\Users\\\\Documents\\PROJETOS\\RedeCorFrontEnd\\node_modules\\broccoli-sass-source-maps\\node_modules\\which\\which.js:13:12)\n' +
gyp verb `which` failed     '    at F (C:\\Users\\\\Documents\\PROJETOS\\_modules\\broccoli-sass-source-maps\\node_modules\\which\\which.js:68:19)\n' +
gyp verb `which` failed     '    at E (C:\\Users\\\\Documents\\PROJETOS\\_modules\\broccoli-sass-source-maps\\node_modules\\which\\which.js:80:29)\n' +
gyp verb `which` failed     '    at C:\\Users\\\\Documents\\PROJETOS\\\\ndules\\broccoli-sass-source-maps\\node_modules\\which\\which.js:89:16\n' +
gyp verb `which` failed     '    at C:\\Users\\\\Documents\\PROJETOS\\\\ndules\\isexe\\index.js:42:5\n' +
gyp verb `which` failed     '    at C:\\Users\\\\Documents\\PROJETOS\\\\ndules\\isexe\\windows.js:36:5\n' +
gyp ERR! stack     at PythonFinder.failNoPython (C:\Users\\Documents\PROJETOS\RedeCotizadorFronode_modules\broccoli-sass-source-maps\node_modules\node-gyp\lib\configure.js:484:19)
gyp ERR! stack     at PythonFinder.<anonymous> (C:\Users\\Documents\PROJETOS\RedeCotizadorFronode_modules\broccoli-sass-source-maps\node_modules\node-gyp\lib\configure.js:509:16)
gyp ERR! stack     at callback (C:\Users\\Documents\PROJETOS\\node_moduleeful-fs\polyfills.js:299:20)
gyp ERR! not ok
npm WARN [email protected] requires a peer of @babel/core@^7.0.0-beta.42 but none is installed. You must install peer dependencies yourself.
npm ERR! errno 1
npm ERR! [email protected] postinstall: `node scripts/build.js`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the [email protected] postinstall script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! A complete log of this run can be found in:
npm ERR!     C:\Users\\AppData\Roaming\npm-cache\_logs\2021-07-28T19_13_06_459Z-debug.log
But I've already tried everything below:
  1. Remove Node-Modules
  2. Delete Package-lock.json
  3. Install the latest node-sass version
  4. Install the latest version of gulp
But even so the same mistake perpetuates, I believe ember-cli is doing this.
How should I proceed to fix this problem? I use Windows and on an Intranet (Company).
My Versions:
node: v12.14.1
npm 6.13.4
PACKAGE.JSON:
  "name": "xp-investimentos-frontend",
  "version": "0.3.1",
  "description": "Small description for xp-investimentos-frontend goes here",
  "private": true,
  "directories": {
    "doc": "doc",
    "test": "tests"
  "scripts": {
    "build": "ember build",
    "start": "ember server",
    "test": "ember test"
  "repository": "",
  "engines": {
    "node": ">= 0.10.0"
  "author": "",
  "license": "MIT",
  "devDependencies": {
    "broccoli-asset-rev": "^2.4.2",
    "ember-accordion": "0.3.6",
    "ember-ajax": "2.4.1",
    "ember-array-contains-helper": "1.3.2",
    "ember-bootstrap": "0.7.1",
    "ember-browserify": "1.1.9",
    "ember-charts": "1.0.0",
    "ember-cli": "2.5.0",
    "ember-cli-app-version": "1.0.0",
    "ember-cli-array-slice": "2.0.0",
    "ember-cli-babel": "5.2.1",
    "ember-cli-bootstrap-datepicker": "0.5.5",
    "ember-cli-bootstrap-sassy": "0.5.3",
    "ember-cli-clipboard": "0.8.1",
    "ember-cli-d3-shape": "0.8.5",
    "ember-cli-dependency-checker": "^1.2.0",
    "ember-cli-htmlbars": "^1.0.3",
    "ember-cli-htmlbars-inline-precompile": "^0.3.1",
    "ember-cli-inject-live-reload": "^1.4.0",
    "ember-cli-inline-content": "^0.4.1",
    "ember-cli-mirage": "0.2.4",
    "ember-cli-moment-shim": "2.0.0",
    "ember-cli-nouislider": "0.9.0",
    "ember-cli-pagination": "3.1.4",
    "ember-cli-release": "0.2.8",
    "ember-cli-sass": "5.3.1",
    "ember-cli-selectize": "0.5.5",
    "ember-cli-uglify": "^1.2.0",
    "ember-concurrency": "0.7.4",
    "ember-data": "^2.5.0",
    "ember-export-application-global": "^1.0.5",
    "ember-file-upload": "2.5.0",
    "ember-inflector": "2.1.0",
    "ember-inline-svg": "^0.1.7",
    "ember-inputmask": "0.2.2",
    "ember-load-initializers": "^0.5.1",
    "ember-maskmoney": "0.4.3",
    "ember-modal-dialog": "^2.4.4",
    "ember-models-table": "1.7.0",
    "ember-moment": "7.0.0-beta.3",
    "ember-radio-button": "1.0.7",
    "ember-resize": "0.0.12",
    "ember-resolver": "^2.0.3",
    "ember-route-action-helper": "2.0.1",
    "ember-truth-helpers": "1.3.0",
    "ember-uploader": "1.2.2",
    "hashcode": "^1.0.3",
    "ivy-tabs": "2.0.0",
    "jquery-maskmoney": "3.0.2",
    "liquid-fire": "0.27.0",
    "loader.js": "^4.0.1",
    "lodash": "^4.12.0",
    "moment": "^2.17.1",
    "node-sass": "^6.0.1",
    "phantomjs-prebuilt": "^2.1.14"
  "dependencies": {
    "closest-num": "0.0.1",
    "currency-formatter": "^1.4.2",
    "ember-cli-data-export": "^0.1.29",
    "natives": "^1.1.6",
    "ocanvas": "^2.9.1",
    "percent-value": "^1.0.7",
    "socket.io": "^1.5.1"
THIAGO DE BONIS
  • 760
  • 22
This doesn't work because there's no uploaded binary of that node-sass version for node 12.x. It only goes up to node 7. It then tries compiling it for that node version but you do not have installed python2 (and you would also need visual C++, unsure how does this work on windows).
node-sass 6.0 is not the problem here and it's not your module that's problematic. A dependency of some other module requires that version of node-sass. So you'll need to override the dependency somehow. Like doing this. You'll need to update that for every ocurrence of every node-sass 3.13.1 version.
Another alternative is to build the module against that version of node, but you'll need to install visual c++ and python2. I found some further steps here.
Install the current version of Python from the Microsoft Store package.
Install tools and configuration manually:
And the last alternative would be to simply install a node 7 version.
MinusFour
  • 13,913
  • 30
  • 39
Difficult to tell. My guess is this error is related to your network infrastructure. But you may have other issues after workaround this one. Try running your project behind a "owned" infrastructure.
Dharman
  • 30,962
  • 25
  • 85
  • 135
easiest way is
  1. download binary version node "win32-x64-72_binding.node" from below https://github.com/sass/node-sass/releases/tag/v4.14.1 (from v4.12+ available to download).
  2. add it to below folder. ( If folders doesn't exist after npm-cache, just create it.) C:\Users\XXXXXX\AppData\Roaming\npm-cache\node-sass\3.13.1\win32-x64-72_binding.node
Now, try to do "npm install" -> it will work.
check the comments here as well. https://github.com/joliss/broccoli-sass/pull/74
Naresh9
