I am trying to differentiate click and dblclick events by javascript. I tried stopPropagation in dblclick however did not work. hence I coded my own function using setTimeout tries to avoid calling the other when calling one.
/* dblclick differ click
takes two functions as param and one element
to bind the event listener on
function cdblclick(click, dblclick, el){
el.cooled = true;
el.addEventListener('click', function(){
if(el.cooled){
setTimeout(function(){
if(!el.cdblc){el.cdblc = 0}
el.cdblc++;
if(el.cdblc === 1){
if(!el.doubled){
console.log('click')
// click();
el.cdblc = 0;
el.cooled = true;
el.doubled = false;
}, 300);
}else if(el.cdblc === 2){
console.log('double')
// dblclick();
el.doubled = true;
el.cdblc = 0;
el.cooled = true;
}else{
}, 250);
however, it does not work properly. I will be so glad if you ca give me a hand.
Thanks for the suggestions of divide to two elements, however, I must implement both events on the same element
solution
thanks to all the helps.
function cdblclick(click, dblClick, el) {
let clickedTimes = 0;
const incrementClick = () => {
clickedTimes++;
const reset = () => {
clickedTimes = 0;
el.addEventListener('click', e => {
incrementClick();
setTimeout(() => {
if (clickedTimes === 1) {
click(e);
} else if (clickedTimes >= 2) {
dblClick(e);
reset();
}, 300);
