Problem
How do you create a java library jar that both:
  • is java module (has module-info)
  • has a depending legacy (non-module) jar. (like commons-exec)?
The dependency is an implementation detail - should not be exported.
Sources
Having the following build.gradle (using gradle-6.8):
plugins {
    id 'java-library'
group = 'test'
version = '0.0.1-SNAPSHOT'
sourceCompatibility = '15'
repositories {
    mavenCentral()
java {
    modularity.inferModulePath = true
dependencies {
    implementation 'org.apache.commons:commons-exec:1.3'
and the following module-info.java:
module test.module {
    requires commons.exec;
Errors
I'm getting the following compile error:
module-info.java:2: error: module not found: commons.exec
If I don't include requires commons.exec then the error becomes:
error: package org.apache.commons.exec is not visible
import org.apache.commons.exec.CommandLine;
  (package org.apache.commons.exec is declared in the unnamed module,
   but module test.module does not read it)
commons.exec module name?
Running jar --file=commons-exec-1.3.jar --describe-module does output:
No module descriptor found. Derived automatic module.
[email protected] automatic
requires java.base mandated
contains org.apache.commons.exec
contains org.apache.commons.exec.environment
contains org.apache.commons.exec.launcher
contains org.apache.commons.exec.util
So commons.exec looks like a valid module name for commons-exec-1.3.jar. Intelij Idea seem to agree and does auto-complete it in module-info.java. Though it fails at build time.
rzymek
  • 9,064
  • 45
  • 59
  • [related, if not exactly the same](https://stackoverflow.com/questions/63204044/gradle-jigsaw-module-not-found/63457166#63457166) – Eugene Apr 01 '21 at 16:00
I managed to overcome the same issue using java-module-info plugin.
This plugin allows you to add module information to a Java library that does not have any. If you do that, you can give it a proper module name and Gradle can pick it up to put it on the module path during compilation, testing and execution.
plugins {
   id 'java-library'
   id("de.jjohannes.extra-java-module-info") version "0.6"
Add this section into your build.gradle to add the commons-exec module information
  extraJavaModuleInfo {
    module("commons-exec-1.3.jar", "org.apache.commons.exec", "1.3") {
        exports("org.apache.commons.exec")
Add requires org.apache.commons.exec; to your module-info.java
EDIT 1:
Gradle 7.0 comes with full support for the Java module system. Users can now build, test, and run Java modules via Gradle. The mere presence of module-info.java will let Gradle infer that your jar is a module and has to be put on the modulepath instead of the traditional classpath.
Using libraries that are not modules
eHayik
  • 2,981
  • 33
