I am using nconf in a NodeJS project, which I want to deploy to AWS Lambda using claudia.js. I have followed this example:
const path = require('path');
const nconf = require('nconf');
function Configuration(){
    nconf.argv().env({ lowerCase: true, separator: '_' });
    let defaultJsonPath = path.join(__dirname, 'default.json');
    console.log(`Using default config at ${defaultJsonPath}`);
    nconf.file("default", defaultJsonPath);
Configuration.prototype.get = function(key) {
    return nconf.get(key);
module.exports = new Configuration();
This code works perfectly fine when testing on my local machine using claudia-local-api.
However, when I try to deploy to Lambda using claudia create .. it simply stops at validating package without any errors.
claudia create --verbose --profile wgmtest --version dev --region eu-west-1 --api-module app
packaging files npm install -q --no-audit --production
npm WARN [email protected] No description
npm WARN [email protected] No repository field.
added 21 packages from 18 contributors in 0.339s
2 packages are looking for funding
  run `npm fund` for details
validating package
5.12.0
If I export a class instead of a function, the claudia create command works fine (see below). I'd like to understand what the issue is here, or at least how I can get some additional log output of the problem.
class Configuration {
    constructor() {
    static get(key) {
module.exports = Configuration;
reikje
  • 2,850
  • 24
  • 44
