I am trying to click on the "Edit" button in the Facebook "Change password" security settings through Python.
 # logs in to facebook
    browser = webdriver.Chrome(executable_path='/path/to/webdriver')
    # Navigate to Facebook
    browser.get("http://www.facebook.com")
    browser.maximize_window()
    # Search & Enter the Email or Phone field & Enter Password
    username = browser.find_element_by_id("email")
    username.send_keys("[email protected]")
    password = browser.find_element_by_id('pass')
    password.send_keys('password')
    submit = browser.find_element_by_name('login')
    submit.click()
    print("logged in")
    time.sleep(5)
    # navigates to security
    browser.get("http://www.facebook.com/settings?tab=security")
    time.sleep(3)
I'm completely new at this, but this code so far runs, and logs into the facebook page, and goes to the security settings. I can't figure out how to click the button, however. Using Inspect, I wasn't able to find an ID and after a lot of googling, I think it may be an issue concerning Frames? Any advice would be helpful!
undetected Selenium
  • 183,867
  • 41
  • 278
  • 352
redbook4
The element is within an <iframe> so you have to:
  • Induce WebDriverWait for the desired frame to be available and switch to it.
  • Induce WebDriverWait for the desired element to be clickable.
  • You can use either of the following Locator Strategies:
    • Using XPATH:
      WebDriverWait(browser, 20).until(EC.frame_to_be_available_and_switch_to_it((By.XPATH,"//iframe[starts-with(@src, 'https://www.facebook.com/settings?tab=security')]")))
      WebDriverWait(browser, 20).until(EC.element_to_be_clickable((By.XPATH, "//td[.//span[text()='Change password']]//following-sibling::td[1]/button"))).click()
  • Note : You have to add the following imports :
     from selenium.webdriver.support.ui import WebDriverWait
     from selenium.webdriver.common.by import By
     from selenium.webdriver.support import expected_conditions as EC
Reference
You can find a couple of relevant discussions in:
undetected Selenium
  • 183,867
  • 41
  • 278
  • 352
